emiliog2276 »
https://forums.nicoclub.com/emiliog2276-u88021.html
Thu Jun 25, 2009 11:00 pm
Just used it two weeks ago and if you use it you should be able to feel a noticeable difference in the performance of your car. Now if you add it to your oil make sure to do an oil change within 100 miles or so. If do the induction method using the brake booster hose will get sea foam thru only 1/4 of the intake manifold. Here are some instructions for the induction method.1. (While looking at your engine from the front bumper.) Look on the left side of your passenger side throttle body for a small air hose that connects to a very small control unit just upstream of the intake manifold piping.*NOTE* there are 2 hoses on the passenger side throttle body, use thesmaller diameter one.
2. I used 2 cans of sea foam for this because it makes it easier. With the left over, you can stick it into your fuel tank
3. Disconnect that hose from the control unit. The total length of this line is approx 5-6 inches. *NOTE* if your engine is old, this line might break so be very careful with it wiggling it off the control unit its connected to.
4. Now, you need to stick the open end of this air line into the sea foam product. you will not be able to do this using the stock sea foam bottle it came in. Heres what I did instead.--->Grab yourself a small water bottle comparable to a dasani bottle (the smaller ones, 12 oz). Cut this in half and wedge it in between the passenger side throttle body and teh AC compressor lines, put the air line into this before you wedge it in. Pour sea foam into this container. your all set on passengers side now.
5. Locate the Drivers side throttle body and look on the right side of it for a small air line. This air line runs to the front of the car around the radiator area. Disconnect this hose from the radiator area nipple its connected to. Grab your other can of sea foam, or whats left of your first one, and stick this tube into the bottle. The length of teh Drivers side throttle body vacume tube is approx 18-20 inches so you have plenty to play with.
6. Right now you should have both of the throttle body vaccume lines disconnected from their respective control units and stuck into 1 can of sea foam, and the other into a container containing the sea foam product on your passenger side. This next step can use an optional 2nd person.
7. Start your car. The vaccume lines will not have sufficient vaccume to suck up the liquid until approx 1500 RPM's.
8. Have you or a buddy rev the car up to 2000 RPM's and try and hold it there. Have the other person monitor the cans of sea foam to make sure you only put half the can of each into each throttle body vaccume line.
9. when the liquid starts to get sucked up, your car will sputter hard and THICK white smoke will billow out of your tailpipe. Keep the car running until you have successfully took in half a can of sea foam per throttle body (1 full can total). Tell your buddy at this point to let off the accelerator and your car WILL die out.
10. Let the car sit for 10-15 minutes.
11. Hook up the vacume lines that you disconnected at this point...
12. Wash hands during this time and smoke. *Note(sea foam is flammable. The order of events in step 11 should be followed closely )
13. After your 15 minute wait. Try to start teh car. It will not start immediately. You might have to try it a few times. Get it started anyway you can and hold a rev of about 4500-5000 on the tach. THICK white smoke will be billowing from the tailpipe at this point. AFter about 1-2 minutes the smoke will slow down, let car rev back to idle and take the car out on an open road and drive the ****er like you stole it for a good 3-7 miles. I was redlining every gear I could.
14. Done.
