My EX is experiencing very loud tire noise after putting about 30,000 miles on my Dunlop tires. Is anyone else having this problem? The service dept. checked out everything last week and suggested that there was some "cupping" on the tires that might be the source of the noise. The tires look fine, there is plenty of tread left, but the noise is bothersome both at low and high speeds. Any thoughts or confirming opinions would be appreciated. I have never had Dunlop tires...maybe this is common. I would hate to buy new tires at this point, but may have to in order to return to the quiet ride i expect.
You probably know that as a tire gets older, it gets louder. My Lexus did the same thing requiring a tire change at 22K mile. At 30K miles I suspect your tires are worn in certain areas and a new set would cure your noise problem. 30K on a set of tires is pretty good these days for a softer compound with a softer and more quiet ride
I should have mentioned that the 30,000 miles are all highway miles and the tires show very little wear. Based on my experience with Michelins on my Lexus I would get a mimimun of 50,000 (the Lexus is still going strong at 275,000 and I think I am on my fourth set). Maybe this is unrealistic on the Dunlops. I am definitely thinking about a new set.
I use to own Dunlop and after 28K miles, they sound awful. I went to Michelins and now get 60K miles without any tire noise. Dunlop to me is plane crap. Only my opinion, not to poke fun to anyone.
I hear that a lot with dunlop tires. Unfortunately there aren't many choices for alternative tires. What I did when my dunlops wore down on my altima, I just did my own skidpad run at an empty parking lot and a near tire squealing speed, both clockwise and counterclockwise directions to wear out the tread a little and smooth it out. If you want quiet you could switch to Michelin Primacy tires, but they aren't V rated and dont grip quite as well as the Dunlops. Or you could go to a 245/50R18. I dont think there will be fitment issues. Dont quote me tho...
You are lucky... mine were toast after 14,000 miles
2008 EX35 (Loaded Except Nav) Platinum Graphite : Tint (5% Front Double 5% Rear 20% Windshield) : All Interior and Puddle Lights Blue LED : 10,000K HID D2C MOD :HID Fogs & Hi-Beams : Blue Rear Turning Signal Bulbs : Blue LED Parking Lights: Blue LED License Plate Lights : Blue LED Trunk Lights : Red LED Side Marker Lights:Hardwired Cobra Radar/Laser Detector : Resonator Delete : Stock 18's Wrapped With Wider and Super sticky 235 series tires
:Finally Got My +2 Mod (Ask Me For Details):
WISH LIST: Stillen Intake : Black Grill : Graphite Rims : Smoked/Tinted Taillights and Signals :Hawk HPS Pads: Bully Dog Tune :
Replaced tires after 14,000 yikes. What did you get for replacements? Anyone else have a tire recommendation (a quiet tire recommendation) besides the Michelins?
I have exactly the same noise problem with my Dunlop tires after 43,000 kilometers. I will suffer with them till winter as I have set of winter tires waiting. next year I will buy 245/50R18. Dont know yet what make I will buy. I have a set of Falken tires on my other car and I'm very happy with them.
How have you been rotating them. I would say run your hands over the surface of the tire with an open palm towards the tread. If you feel raised edges on the inside edge of the tires you are starting to develop feather edging. This is a normal byproduct of alignment and is not a design flaw. With frequent cross rotation the wear can be balanced. I would also suggest getting a 4 wheel alignment. Your front toe should be set to between 0.02 and 0.04 each side. This will allow for less chance of featheredging without sacrificing road feel.
This is one of my primary reasons for strongly recommend asymmetrical tread designed tires. Keeping to a strict ~7k rotation schedule will get the most out of your tires.
Quote, originally posted by RioD007 »
You really do drive the hell out of that thing don't you.
======-------------=----==--===== -------------------------------- Nissan Sport Magazine
thanks for the advice Steve the Tech. I had been rotating around 10,000 miles....when i look for new tires (which will probably be soon) i look for asymmetrical design. Thanks for your thoughts.
To prolong the life of your future tires rotate them at every oil change. It may sound excessive but using the X rotation pattern will have significantly different results.
This is one of those instances where a little more proactive maintenance will save you money down the road.
1. Try not to hit the bumps when parking. 2. Rotate them every 2 oil change interval. 3. Keep your Tire Pressure matched. (around 28-32 psi is ideal for me) 4. When replacing tire is required try to change all 4 or at least 2 at a time. 5. Check the shape of your treads by touching it with fingers/palm, if tires make noise, it means your tread is wearing out unevenly, unless you have bad suspension/hub bearings.
Changing tires are very expensive. If you maintain them well, you will save money. I have set of Falkens on my car and with 60k miles on them i still have plenty of treads left and it still rides like a new car.
I have the same tires on my Ex35 and had trouble getting the dealer to admit there is an issue with these tires. I had them replaced at 25,000 miles with the same tires (split the cost with the dealer) and now at 45,000 they need to be replaced again. It really sucks when you pay good money for a car and they put crap tires on it. I will keep these until I cant stand the noise anymore and then get Michelins........
Steve: On the whole, I agree with your tire rotation scheme, but only because I change oil at 7500 mile intervals. I only use Moble 1, and a high amount of my miles are on cross country interstates. I've been using the X pattern on the OE Michelins , however I'm going to replace them with Nokian WR's, which is a directional tire, the rotation oif which is only fr to rear.
Just wanted to add my voice to the dissatisfaction over 'cupping' and tire noise with the OEM Dunlops. Mine started at 30k even though the tires have been rotated by the dealer every 6k. Just back from having a 4 wheel alignment (37k) - perhaps should have done it sooner but the tech. said it was not that bad.
So I'm also interested in the best recommendation for replacement tires (for all season use). Is Nokian WR the way to go?
I had Nokians on a Highlander, and they were excellent - low noise, good ride, excellent in the winter. They are a all season tire, that is winter rated. The only problem is finding them. They made in Finland, where they know about snow!
Solution to your problem, don't go too fast nor too slow.
Speaking of Falkens, we have the 18" wheels, and we replaced the Dunlops about 2 months ago (at about 25k miles) with Falken Ziex ZE912. Looks like they're the only performance tire of the same size, they're about 2/3 the price of the Dunlops, and that model was recently ranked by Consumer Reports as the best high performance all season tire. That's the good news.
The bad news is that with only 2k miles on them, they're starting to show the same problem that started with the Dunlops at about 14k miles. The problem is not "cupping" or "feathering" - as many service managers and even techs would and have incorrectly called it - but heel and toe wear on the outside tread blocks only. When viewed from the side, there is a sawtooth like shape to the tread blocks, with the leading edge being slightly higher than the trailing edge. It can be felt by running the palm of your hand along the outside circumference. I wonder if that's actually a problem others on this forum are experiencing but mislabeling?
We bought the car with 12k miles on it, and it drove fine (although not 100% sure the tires hadn't already started to wear abnormally - in fact, they may have been relatively new, I never checked the tread depth). Went on a long road trip and about 2k miles in, started to get vibration in the front, mostly passenger side. Got 4-wheel alignment, balance and rotation halfway into the trip, but tires never "corrected" as they said hopefully would happen. Couldn't stand the vibration after a few more months and 10k miles, so bought the new tires (but skipped the alignment, which was likely a mistake).
After replacing the tires (bought at DiscountTire.com, installed at dealer), the ride was vastly improved, but oscillation on braking was more pronounced (just more noticeable since it was isolated?). Next visit led to resurfacing front and rear discs, then replacing front discs, at no charge to me (this is at about 26k) AND another tire balance, which they admitted wasn't done properly the first time. All seemed well.
Another 1k miles or so and we're on a Sunday drive yesterday - had very slight vibration again, but I figured maybe just the road/my head? On the way back, vibration was much more pronounced, so I checked the tires when we got home and noticed the early stages of the heel and toe wear. This went from barely noticeable to pretty annoying in a hurry (less than 60 miles).
Very ticked off, and very concerned that there's more going on than a slight alignment problem. I mean, can very slight heel and toe wear cause such a noticeable vibration, especially after only 2k miles? Besides, can't the car hold an alignment for more than 6 months? I've noticed mention on this forum of a steering rack issue, but the dealer says that has nothing to do with my symptoms. Anyway, it's back to the dealer tomorrow, probably for an alignment, and then I don't know what...
Sorry for the long first post - I'm new to this forum, but have been reading for a while, thanks for all of the useful info over the past year.
I completely agree with you, it seems that all the infiniti dealerships pay their service personnel to annoy and intentionally confuse customers, they like to spurt out a solution (an excuse that their is no TSB for the problem, so it doesn't exist) to a problem before any inspection, i have heard all kinds of stories on the road noise from it is the tires, to the vehicle mixed with the aliment, the suspension type and etc.. Its just plain irresponsible management and it needs to be made known, i am going to complain to infiniti customer relations after my next visit to the dealership. This poor service is not warranted on a vehicle of such a cost and perceived value/reputation.
the Ziex 912s are a great tire. I had those for a bit before i swapped to Potenza S-02 pole positions on the TL -
however it would seem you expect to not need an alignment for X amount of miles. There is no set period of when you need one. It depends on where and how you drive. I used to drive my TL like a bat out of hell, as a result, i needed new tires almost every 9000 miles and i was changing my oil probably every 3500 not out of habit, but because the engine oil was running that low already ~ 35%.
anyway, you may not drive like i did then, but the environment around you may require that you do an alignment more often than you would like. Also, things like a bent rim (one really bad pot hole can do that) or slightly bent rim will also cause bad heel/toe rash and vibrations.
i think everyone should be doing this on any car they buy, firestone has a one time fee for lifetime alignment on that car. it pays for itself very fast...
anyway, if you can check the quality of your rims, actually make sure that the tires are really all evenly worn or better yet all equally new, tire pressure, and alignment, i am sure you will discover that the noise goes away.
Another very common thing is if youve had a flat and only replaced that one tire, you will get road noise as well...so there are a few factors to all of this.
This is a perfect description of what I have been experiencing since about 30,000 km. I want to get new tires but I'm concerned that it's a car problem not a tire problem and, like you, will be back in the same situation after spending a bunch of money for nothing.
[QUOTE=TheWife’sEX] The bad news is that with only 2k miles on them, they're starting to show the same problem that started with the Dunlops at about 14k miles. The problem is not "cupping" or "feathering" - as many service managers and even techs would and have incorrectly called it - but heel and toe wear on the outside tread blocks only. When viewed from the side, there is a sawtooth like shape to the tread blocks, with the leading edge being slightly higher than the trailing edge. It can be felt by running the palm of your hand along the outside circumference. I wonder if that's actually a problem others on this forum are experiencing but mislabeling?
deflate one of the tire to see what kind of warning it will give you. i don't think it matter position of the tire but i think it will tell you which tire is low.
Sorry, I initially responded because of the mention of Falkens, and the general tire issue, but perhaps the "Tire Noise" thread wasn't the right place for me to describe my issues/concerns - because in fact, I'm most concerned about the short life-span/premature wear/heel and toe wear than anything else. The vibration seems to go hand in hand with that problem, and seriously detracts from the driving experience. The tire noise is relatively slight, and is at this point the least of my concerns.
Quote, originally posted by JCL622 »
...however it would seem you expect to not need an alignment for X amount of miles. There is no set period of when you need one. It depends on where and how you drive. I used to drive my TL like a bat out of hell, as a result, i needed new tires almost every 9000 miles and i was changing my oil probably every 3500 not out of habit, but because the engine oil was running that low already ~ 35%.
Living in the Northeast, I would agree that I'm more likely to need more frequent alignments than some down South or out West. However it would seem that an alignment should last more than 6 months an 8-9k miles, especially over the summer months (i.e. - April thru Sept). Since I had one in April, and the new tires on in Aug, I figured I'd go through the winter, then get one in the spring. Especially since the car drives/handles fine. I realize a car out of alignment specs can seem to drive OK and have imperceptible impact on the tires, but I find it hard to believe that it could cause so much damage to the two front tires in only 2k miles, and on two occurrences with two different tires (Dunlops and Falkens) in around 25k miles.
While I drive fairly aggressively ('06 S4 Avant and '98 M3 Conv.), this is my wife's car, and I know she's not taking off ramps at 75mph and/or weaving in and out of traffic. I've gone through tires in 25-30k miles before, but never less - and unless we're talking about hard driving on max performance summer tires, I would expect (perhaps naively) most tire sets on a fairly new vehicle with no mechanical issues to last 10's of thousands of miles, not a few thousand.
Thanks JCL662, and you were probably speaking to the thread in general, but to be clear in my case, these are 4 new tires, pressure is fine. Not sure how to check the rims (visibly they seem fine) to see if there is a slight bend to them.
I'm bringing the car in tomorrow to see what the dealer says. My limited research on heel and toe wear seems to indicate that it is caused by out of spec caster settings. The caster was within spec on the alignment back in April and was not adjusted - and from my experience, it is the least likely of the three alignment settings to get knocked "out of whack". So...it will be interesting to see what the dealer tries to claim is the cause. I'm considering going to an independent shop for an alignment first, for an unbiased measurement - but that also opens it up to the dealer claiming it wasn't done properly, so I may just have to hope the dealer does the right thing and doesn't "fudge" any readings. I know....
Interesting. I suspect we aren't the only two, and some others that have complained about early tire wear are perhaps experiencing the same exact problem, but it just isn't being described the same? I think someone else raised the concern that it might be a suspension geometry issue, which would REALLY stink...
Kind of a stab in the dark here, but other possible design/quality issues could be related to the steering rack (seems to be a known issue, but not tied with tire wear...yet) or I was thinking maybe a problem with the front/rear torque split in the ATTESA system, causing uneven rotation rates at the corners and thus a sort of "pushing" on the tires???
Just curious, have you spoken to the dealer about it? Keep an eye on this post (or maybe I should start a new one titled "Tire Wear"?!?) and I'll let you know what I learn (or don't learn) on my upcoming visit.
This thread has progressed in an interesting manner.
First of all I would like to welcome TheWife'sEx to the group.
There are a few things that I feel have been brushed over with little attention payed to them. The Caster setting is actually one of the angles most effected by a collision or impact. Think about the inclination of the vertical axis of the front wheels centerline. Most of the force of an impact is dissipated through these components. The problem with caster is there is not only no adjustment there is no way lie about it. The caster measurement procedure may be flawed in the machine but there is no way to screw it up if camber and toe are not completely out of specification.
When I teach a new tech alignment procedures on these cars I always try to show them that these cars will tell you what is wrong right from the tires and their wear patterns. The majority of tire wear noticed on these cars if featheredging caused to excessive total toe and wear caused by incorrect inflation. The spec seems a little on excessive side and even keeping it in the green is not enough. To the untrained eye tire wear can be misread and I have actually watched several service writers misdiagnose problems and just pull things out of the air.
Total toe is more important and the closer to 0(zero) of the thrust angle the less tire wear that will be noted.
Caster is not adjustable not and will never be adjusted. We (Infiniti forum member, moderator) have been dealing with this for years with other models. Several members in the G and M forum have experienced this for a while and there have been several threads calling for all types of action to resolve this. The fact of the matter is these cars were set up to allow for the maximum performance of the AWD system. Whether your car has awd or not the suspension is not different (geometry wise) from rwd models with the exception of shock rate and slight variance in ride height. The camber caster and toe settings in the front are the same and are designed to allow for seemless torgue split with no Acura esque torque steer.
The tires will never wear from the awd system it just does not work in such a way that that is a viable option for the wear. If there were enough of a problem with the awd system you would know about it well before the tires had a chance to wear.
The roads in Massachusetts suck and many of them are going to make noise. I notice this in my own car as well as my wife's when we head up to that area. Increased tire lead and noise are noticed more in this type of vehicle. The German cars are not as prone to this but in skimming some of their forums tire issues are not at all uncommon. This is not a design flaw and will not be changed by the company as any significant alteration to the suspension will have a significant ripple effect.
The best thing for an EX that is not being put through the paces on a daily basis is a good set of Tier 1 asymetrical tires like a Goodyear, Michellin, or Bridgestone. Kumhos are not going to work well on this car no matter what when they start to break in they will get noisy.
What is the toe setting on your most recent alignment sheet?
Thanks for all of the information (and forum welcome) Steve.
Interesting thread progression indeed - and it's very interesting that you mention a collision as being one of the few causes of caster misalignment. In the interest of full disclosure, I offer this bit of history:
I mentioned that we bought the car with about 12k miles on it (and less than 1 year old). You can never be 100% sure when you buy used, but the car seemed fine when we first checked it out (clean CarFax, although they're nearly useless). Turns out, there was light paint work done, although the selling dealership denied any work had been done (I know, never believe a thing they say).
After a little hand-wringing, we bought the car. During the next week, I took the car to two separate Infiniti dealers, who put the car in the air, checked it from top to bottom, and declared that it was fine and did not appear to have any frame or (major) body work done to it (original VIN tag on all panels). I was under the car both times, and it looked OK to me.
Using some very neurotic research skills, I was able to determine that the car was driven by a Nissan exec in MI before being sold through auction to the Infiniti dealer we bought it from. It turns out it was almost certainly THE auto show (and likely road test?) car that you see in all of the pictures of the EX35 display at the US auto shows (rare Scarlet Silver/Chestnut w/all options). A celebrity I guess?!?! Pretty sure this [http://blogs.motortrend.com/6221234/car-news/infiniti-prices-its-2008-ex35-base-models-start-at-32015/index.html] is the car in my driveway....not happy about that, but at least now I know what happens to all those cars I see at the shows and in the magazines I read every month...
But I couldn't stop there, so I tracked down the Nissan exec (did I mention I could be a bit neurotic?) - and after I calmed down her very agitated husband - I was told that the car was terrific, but she had hit a bird on the highway that took out the mirror and required a new mirror and light paint work. So....I figured not great, but no big deal, that was it. Maybe, maybe not, huh?
All that given...I still think it's unlikely some previous collision is the cause of my tire woes.
Glad to hear that it is not likely/impossible that the AWD system is the culprit.
To answer your alignment reading question, the alignment done 6 months ago wasn't very severe. And interestingly, now that I'm looking at it VERY closely....it's a little disconcerting that the heading at the top says Infiniti: FX35 : 4X2: 2003-08. I seriously hope the FX and EX specs are the same....
Anyway, the camber and caster, front and rear, were fine "before" - so not adjusted. Toe front and rear were both in the red, although not outside the range, so they were adjusted a few minutes and brought back to the center of the range. Fronts were set to +0.05 left and +0.06 right, rears were set to +0.10 left and +0.11 right. Seems like the alignment wasn't (still isn't??) the problem....
Dealer couldn't take the car today, so it'll go in early next week.
I currently have my second set of Dunlops on my EX35, same problem as before with wearing and tire noise. P225 55R18 97V. I am looking at Michelin Primacy MXV4 for my next set. They only come in 60R vs 55R. Are these ok to use.....Any comments on michelins????? Thanks.
just checking back in on the tire noise...since first posting this topic. While it is reassuring to see that my problem was not unique...and underscores the my concerns with the Dunlops...I still haven't broken down and purchased new tires yet. Thanks to StevetheTech for all the suggestions and info. I am thinking I will follow his suggestion and purchase Michelins...so if there is anyone out there that has already done this...let us know how they sound.
As regards Michelin tires, I have them on my 08 EX, AWD, with 24k miles. They were OEM, and I have noticed no unusual wear, however I'm going to have to replace them before I go back east in Feb. They have slowly become noisier over time, which is to be expected. After some research, I've narrowed in on the Goodyear Triple Tread, which is very similar to the Nokian WR, which I would favor, but can't find. Tire Rack rates them very highly, in all conditions of driving.
I personally think the Triple treads area great tires for a camber neutral car which the EX really isn't. The tread compound and design are aggressive enough to cause some noise over the life of the tire.
Long term noise levels are going be the best with the Primacies. Before your post I did not know that cell phone companies made tires. Although I only recently learned of Vredstien tires so apparently I am behind the curve. Having the ability to cross rotate the tires is really important with these cars especially with the awd models.
I really have to be honest with you guys. Now that EXs are starting to get some miles we are all learning how the tires are going to wear. One definite PRO to the Dunlops is that if you run your open palm over the tread from front to back and feel some resistance you can mount the front tires on the opposite sides rear wheels to curb any longterm wear. I have been doing this with many of the M owners I work with for a while and it really helps noise and tread wear over the life of the tire.
To TheWifesEX- Impressive borderline creepy level of dedication to finding the original owner. It sounds like you have a decent rarely abused EX. The interior color is very unique and I personally think I could grow to really love it on a day to day basis. Looks like you made the right choice.
Any concern that TripleTred is 97H vs 97V on the Dunlops? Also, I note that the TripleTreds are 'directional' tires (front to back rotation only, not what Steve the Tech has recommended above).
Like you, I'm trying to narrow in on the best "all conditions" replacement.
What ever the speed rating, I am not driving above about 85 MPH, so the speed rating is of no consequence. As to the directional point, it was never a problem on the Nokians I had on a Toyota Highlander. You just have to remind the tech. Also, much as I like this car, I don't think I'm going to keep it beyond warranty!! I'm afraid it could become very expensive to maintain. (can't they all?)
