I screwed up
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I spilled a bowl of cereal on my open laptop... Wiped it up as fast as possible, even turned it upside down, but didn't help. Now my keyboard is all screwy.. Any suggestions??
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Since you're going to be reckless and eat on your computer, this will help.http://www.tigerdirect.com/app...d=142
You can also take your laptop apart and start cleaning everything.
Warped161
Car: 90 s13 the never ending project
well the only way to clean the keyboard would be to remove it from the computer, and im sure some milk got onto the motherboard underneath the keyboard. Next time buy accidental coverage.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, you'll have to crack the laptop open. As long as there's no power (which includes capacitors, unfortunately) water can't damage electronics. Depending on how the laptop is designed you may be able to remove the keyboard with out actually opening the laptop itself.I suggest the following:-Crack it open if necessary-Remove keyboard-remove keys (most laptop keyboards have scissor type keys...they'll just pop off and pop back on easily. Try prying with a butter knife.)-wash keys if needed-rinse keyboard with lots of alcohol. The alcohol will absorb any moisture and then evaporate quickly, leaving you with nice, clean, dry electronics.
I have a really old Del I use for legacy gaming, and I've cleaned that keyboard with alcohol many, many times. Never spilled any milk in it, though.
marlin29311
Car: 2008 Infiniti G35x
Lenovo FTW.
fun240
Car: 95' S14, 91' NX1600
get an external mouse and keyboard.
Plug it in.
Disable your mousepad on the laptop.
Done.
PyR0NiAk
$30 GOT IT REPLACED
