M45Runner »
https://forums.nicoclub.com/m45runner-u131048.html
Thu Jun 18, 2009 10:24 am
I would go with OEM if you do not race / drive very aggressively. The OEM is designed to be quiet, with minimum brake dust and can stop the car relatively quick. Most generic brand will cost less, but, will not perform as good on a luxury car that weights 4000 lbs. It is either lack of stopping power, or not as quiet, or generate a lot of dust - which will cover your wheels pretty bad.
Be careful when changing the pads and make sure you do not mess up the ABS sensor though...
