Well as much as I hate to do this, and will probably hate myself after the car is gone...I've been throwing this around too much to not at least get the car out there. If I don't get what I'm asking, it's not going to hurt me, so if you want to throw small offers out there don't bother. I'm not hurting to sell the car, but I have considered beginning a new project.
Info: 95 base model 240sx
Car was originally a 5spd, 4 lug.
has around 160k on the odometer, a few thousand on it since the swap.
Mods:
Engine/Drivetrain:
2jzgte(not 100% sure of mileage on it when I bought it, but the car runs extremely well), new water pump, thermostat, misc sensors. Twins were setup to run together all the time.
Competition stage 5 clutch
1jz flywheel
R154 5 spd
Tech 2 mount kit/driveshaft
Tech 2 Shifter Extension
LSD out of an S13
FMIC with tech2 IC piping kit
Wiring done by Joel at ForcedFab
Koyo Radiator
Flex-A-Lite Pushers
Walbro 255 fuel pump(all fuel lines ran on driver side of the car)
Tial BOV
Battery relocated to trunk
Exterior:
Kouki Tail lights
German Glass Headlights
JDM window visors(uninstalled, will include)
Suspension/Brakes/Rims
Stock z32 rims. Yokohamas on front, 255 Mickey Thompson's on back
Z32 Aluminum 30mm calipers. Rears are also converted to z32 and the E-brake DOES work.
Cross-Drilled/Slotted Rotors
Has aftermarket pads, I'll have the brand name tomorrow
Stainless Steel brake lines all around
Circuit Sports complete kit(RUCAS, Toe links, Traction rods, Tension rods)
Tokico Blue struts
Espilir springs(2'' drop)
Z32 Master Cylinder.
R33 E-Brake cables
S14 5 lug hubs
Interior(not much here):
Eclipse head unit
Prosport boost gauge
AEM wideband
BAD:
Car needs paint, it's starting to peel in places quit badly, and has a few knicks/dings.
Tends to overheat if left idling for too long, I'm still trying to solve that issue
No shifter boot/plastic
Speedo does not work, but I have all the wiring to get it working.
Just needs some TLC over all, car has tons of potential, and most of the hard work is done.
Has HID kit, I believe it just needs bulbs replaced(Xenith) They are not hooked up, just mounted/wired.
I'll update this more often as I'm sure there's a TON I'm forgetting. If there's any interest at all. Trades I'm open to, but I do NOT want an S13.
Asking price as of right now is $12.5k. FIRM. Again, I'm not in a rush to sell, but I want to get it out there to keep my options open until I decide fully what to do. Several people can vouch for this car. Car is definitely fast for being on a stock engine/stock tune.
Video of car running:
http://www.youtube.com/watch?v=cZv76V0YdYk
As it sits right now:
Modified by Deftec at 12:54 AM 6/16/2009
13.70@116mph on 215's. Exhaust/FMIC ONLY. Engine Completely Stock
