chixwithtrix »
https://forums.nicoclub.com/chixwithtrix-u97769.html
Sun Jun 14, 2009 4:11 pm
At a drift event today testing out the new 3076 externally gated turbo and associated different setup parts with that on my track car. Boosted to 1 bar (boost controller was not working earlier in day and it boosted to a bit over 2 bar so we removed the controller and ran the 1 bar spring). Later we had a problem I cannot fully pinpoint
SetupRB25detGT 3076Apexi PFCTial 38mm wg, 1 bar springstock manifold modified for wg flangeZ32 MAFNismo FPRGreddy intake mani
Beginning of the day idle was very rough and surged (like the PFC was trying to learn it, but stayed like that to rest of the time). Before this turbo swap the idle was smooth, no surge and no burbles. Would smooth out in high RPMs. One run went through 1st, 2nd, 3rd, bam, car shuts off still going in a straight line before the 1st initiation point. Shut off, no warning, no nothing, but all electronics (gauges, etc) were still on.
Rolled back to pits, tried to start but all it would do is fire over and quickly die (start, vroom, die, try again, start, vroom, die, etc). Checked fuel and it was getting it, it got spark because it was firing over and then dieing. Had one of the tech guys out there check over the car and the PFC said the MAF signal was not reading...? Tried checking the ground and put a multimeter on the maf sensor plug signal wire and the pinout at the ECU and it completed a circuit. Only thing left is to check if the MAF is bad?
Any other things that would cause it to do this other than the MAF? Would dieing abruptly be caused by a bad MAF? Unplugged the MAF and tried to start and it still did the same thing. The tune was not changed from the previous turbo setup and I'm pretty sure if it needs a tune as well.
Its a lot, but I've put so much damn work and money into this car and need some input because I'm stuck.
Modified by chixwithtrix at 8:03 PM 6/14/2009
