Well... I'm afraid I hear it too... but in my case its definitely not associated with cold weather! I live in the Southeast and last week it was 80F in the shade. For me... it's a dry scrapping, plastic on plastic sound. I took delivery of the car in warm weather and its been warm everyday since so I can't speak to the cold. My fear is when it does get cold and the plastic will get stiff, the sound will resonate higher... and thus generate the squeak you are describing. I'm thinking a wire tie or wire harness shield internal to the steering assembly is dragging against the steering column. It bugs me to hear such a sound considering its still a new car (only 260 miles on it.) But... I'm hoping it will wear itself out eventually. (My luck it will wear thru a wiring harness and short out every electrical system in the car!)Couz wrote:I'm getting a very light creaking plastic type sound when I turn the steering wheel, its 100% coming from inside around the steering column.
Its not loud and at times you hear nothing but at times you can hear it, I suspect when its colder I hear it, and being how I am it kinda bugs me.
Its definitely a plastic type sound, like a rub of plastic.
I don't think I hear it when its nice and warm, its like the plastic softens and in the cold the plastic is stiffer and it creaks.
Is this gonna be louder in winter when its freezing.
Howdy Couz....Well... its not looking good. I just stumbled across another thread in the Rogue forum discussing the same issue! We might be in for a struggle. Based on the three of us having the problem... plus what you can read from another member in this link... I'm guessing its a known problem with the Rogue.Couz wrote:Elton, My car is two months old and I've been hearing it on and off since I got it too,definitely when reversing and turning also.
I too attributed it to a brand new car sound, just plastic needing to break in or something.
Anyways, my first servicing I'm gonna bring that up with a couple of other little issues that annoy me considering its brand spanking new car.
Hi kerrton, When I stated its probably a "known problem" I was basing it on the fact that four of us alone in this forum have described the same issue. I wasn't trying to suggest that Nissan wouldn't fix it or even that it was serious... just that it Nissan has to know its a consumer complaint (i.e., problem). I live my the adage "One is a Trend!" Maybe instead of calling it a problem I should have said, "It's a known issue."kerrton wrote:Guys I don't think it's anything to really worry about, just tell your service department to fix it on warranty, no big deal!!
And I disagree that this is a "known problem". If it was, there would be a known solution or workaround, and that other thread that you referenced was my thread, I just outlined the same thing that I did in this thread.......not to worry, they'll fix it!!
Maybe its not a problem to us the consumer from a "mechanical" standpoint... however if I take my car to the service department over and over complaining about a squeaky steering column... then from Nissans perspective... a consumer complaint is a problem.sydenhamrogue wrote:I just picked up my Rogue SL AWD this morning (woot!!!!!!) and while the sales rep was going over the car with us he actually mentioned that we may hear a creaking sound from the steering wheel column. He said it was caused by debris getting caught between the magnets used to differentiate between all of the controllers on the column. The important thing is that this is something that they are very much aware of and he said to bring it in if it happens...under warranty of course.
I haven't yet. Actually, I probably won't take it in specifically for that one problem but I will mention it on my next visit to the service department so I have it on record. I'll also make a point of mentioning it on every visit just to make sure they get the message. I figure eventually Nissan will release a TSB (technical service bullitin) outlining the problem and the fix.kerrton wrote:Ok, no argument about all that, but the bottom line is, have you or do you plan to take it to the dealer to have the problem fixed??
My only suggestion might be to mention to them that another Rogue owner on the Nico forum was told by his dealership there is a issue with debris in the magnets etc. If nothing else at least it will give them a place to start.kerrton wrote:I tried 3 times, they gave it a valiant effort each time to no avail, and I'll try for a 4th time but if somebody discovers the solution I'd sure like to have it as a suggestion the next time they attempt another repair....
Grimy wrote:I had mine "re-lubed" when I was getting my oil changed and that did the trick....for about 4 weeks. Then that noise was back once again! I had my wife take it in and they claimed it the was transmission!!! I now have a transmission sitting at the dealership waiting to be put in my vehicle. I am sure this is not the problem but I also starting getting this "rattle rattle ping rattle" sound(15.5km just started) like a spring winding up and popping and that could possibly be the transmission but others say its the ABS doing its test. Note this happens only on cold starts and at parking lot speeds right after put in drive.
Sad thing is I know my steer wheel column is still gonna make this noise after this.[/QUOTMan, you went in for a creaky steering wheel and they said it was the transmission.Grimy wrote:I had mine "re-lubed" when I was getting my oil changed and that did the trick....for about 4 weeks. Then that noise was back once again! I had my wife take it in and they claimed it the was transmission!!! I now have a transmission sitting at the dealership waiting to be put in my vehicle. I am sure this is not the problem but I also starting getting this "rattle rattle ping rattle" sound(15.5km just started) like a spring winding up and popping and that could possibly be the transmission but others say its the ABS doing its test. Note this happens only on cold starts and at parking lot speeds right after put in drive.
Weird, maybe they diagnosed a whole new problem.
And as for the spring popping sound if it happens right after you takeoff from starting your car it is the self test for the ABS...I get that on and off since I got the car, the self test seems to vary in its noises but the spring noise is common for the ABS test...I get it.
