Command Prompt is just the fill-in for a proper DOS prompt since Windows doesn't operate on top of DOS anymore. It's a crappy fill-in, too, since it's not really DOS, just access to the Windows command line.Anyway, if you have "command prompt" you have windows since it's a "feature" of windows, so you can just make the partition through Windows' disk management.
Looneybomber wrote:
Really? Both the info on the C: drive and restore info on D: drive? Will it save it as a single ISO file which I can put on the new HDD's C: drive? The new HDD is not partitioned.
Oh, I didn't notice the drive distinction there. No, it won't do both. You can do them both separately, though, then just partition the new drive into C: and D: and manipulate the files from there...even delete the partition once you've got everything where you want it if that leaves D: empty.
