 Smog Emission test failuer
joejoe015
1999 nissan frontier
Rialto CA
4-29-2009
I recently had a smog test done to my 1999 frontier and didn't pass one portion of the test. The portions that i did pass was the 25mph test CO2, O2, HC, CO, NO. I was ok with the 15mph CO2, O2, HC, CO but where it failed was the NO test.Can somone point me in the right direction
Ka24de 99 frontier
RT
1991 nissan king cab pick up
montgomery al
5-20-2008
 « Re: Smog Emission test failuer (joejoe015)
You may try googling about smog tests and see what cause the NO to be off, may just be a tune up or something simple that can cause it. First you have to find out what it means and what causes it. I live in alabama we have no smog tests so NO means nothing to me.
C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
Did the smog tech note and OBDII codes? If so, that might point you in the right direction.
NOx emissions though, are generally a result of high combustion temperatures. The EGR valve (or a cam timing equivalent) is typically what helps reduce the NOx emissions.
You might post up a copy of the report itself as well. Sometimes, other emissions leves can be higher than it should but still within passing range. Short of multiple smog device failures, seeing the broader range of emissions might help to more easily diagnose the source of the problem.
"Bad Driver's Famous Last Words:
Watch This!
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
 « FN-QR
check to see if your EGR valve is functioning properly... if not then i personally don't really know where to point you
all i know is my NOx gases fail by over 500%!!!!
good thing i don't have to get tested!
Quote, originally posted by krimsonviper »
Oh yeah? Well, I saw a Razi on the freeway sitting under a Pezi. I was jealous.
dulobast25
2000 frontier
spring valley ca
5-1-2007
 « Re: FN-QR (PEZi720)
if u have hi nox? make sure the hoses going to and from your egr valve are not clogged or leaking.
next check the bpt valve and be sure it has strong vacuum going in and out of it. then check the hoses going to and from the bpt valve for clogs or leaks.
the bpt is located right above the egr and looks like a disk with 2 hoses on top
the b esure the hardline from the egr to the exhs manifold isnt clogged or leaking.
between each check the nox should be going down if faulty. we chased down a noix probl;em on a hb for 2 yrs after switching the bpt valve 3 times.
a mod of the bpt valve took nox from 1300 to under 700 in i hr.
cats have an effect but try testing b4 replacing.
remeber as nox goes down, co2 often goes up.. its a balance
PEZi720
Datsun Moderator
1985 720 pickup
colorado springs CO
12-11-2008
 « FN-QR
i made my EGR not open on purpose lol... i don't have to get tested so i don't let the EGR open and i have no cat
» Return to Nissan Trucks Forum
