 Intermittant Steerin Wheel Vibration
packer_edge
2004 Quest
abbotsford bc
4-29-2009
  Intermittant Steering Wheel Vibration
Just bought a 2004 Quest from the dealership (preowned obviously). There was something wrong with the steering column as I was getting a clunking noise inside it. They replaced it under warrenty and that fixed that issue. Unfortunately, it didn't resolve an intermittent steering wheel vibration that I get ... usually between 80 and 100 km/h (which was there before the steering column was replaced). The problem is that the majority of the time it's fine, so when I go to the shop, they can't replicate the problem. But when it happens, it's very noticeable ... the steering wheel shakes side to side quite significanly. The front end of the vehicle appears to be good, according to my mechanic. I had the front tires balanced too. No one can explain the issue. Anyone come across this problem? Is this normal operating for this vehicle?
Modified by packer_edge at 6:26 PM 4/29/2009
Rockford
2007 Quest SL
Toronto ON
4-28-2009
 « Re: Intermittant Steering Wheel Vibration (packer_edge)
Not normal for this - or any - vehicle. I just bought a used '07 and noticed a shake/shudder at anything upwards of 115kph. It got worse the faster you went. I took it back and they balanced all 4 tires. Problem solved. Not sure what your problem could be. If it's intermittment you'd think it WOULD NOT be a balancing issue. If t were you should have it all the time, right?
Sorry, not much help. Just thinking out loud here. Do you still have the clunk in the steering coloumn?
basskronick
Supporting Member
I drive a pontiac, and i love it, but i have nissan in my heart, I'm also the owner of a first gen q
smyrna TN
3-25-2006
 « Re: Intermittant Steering Wheel Vibration (Rockford)
My guess would be a problem with the rack and pinion, does it do it under certain circumstances? uphill? around a curve? under a load?
<IMG NAME="icon" SRC="http://images.nicoclub.com/forums/images/smilies/bash.gif" BORDER="0">
Poyzinous
NICO’s Loco Tech
2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Latitude 38.8 Longitude 77.1
2-2-2009
Its intermittent, so it definitely isn't a balancing issue or a drive constant. If the warranty still applies to it, have the steering rack checked for leaks, pressure issues. The problem needs to be isolated. your Tech should drive it from low speed to high speed back and forth untill the issue is replicated.
Quote, originally posted by Poyzinous »
Dude, check out my awesome sig!
Click here for an oil change how-to
My Xbox gamer tag is also Poyzinous
» Return to Quest Forum
