 Odometer/Gas Gauge partial display missing
05questowner
2005 Nissan Quest
Huntsville Al
4-27-2009
I have a 2005 Nissan Quest and part of the display and odometer numbers do not display. Over the course of the day they come back. They will eventually all come back. Anyone else have this issue? or know what could cause it? Also my gas gauge seems to beact weird. It will read correctly for a while the drop to about half a tank then come back up to full.
Thanks!
renee0069
2005 Nissan Quest
Littleton CO
6-2-2009
 « Re: Odometer/Gas Gauge partial display missing (05questowner)
My 2005 Quest has the same problem. Sometimes it works and sometimes not - more not Also, we just replaced the timing chains so be careful because it happens right around 60-65k miles from what I am told and it is very expensive. Let me know if you find anything out on the odometer because they want to charge me $500 to fix. Thanks!
ricebike
89 240sx se 5spd 93 Honda Nighthawk 02 Quest
south or central Jerzee NJ
2-15-2003
to the OP, you have a "short" somewhere... there's an online manual on this site for your vehicle...
to renee, i thought these run on timing BELTS... then they need to be changed in a timely manner or the INTERFERENCE engine will bend valves when the belt breaks... on my 3.3L engine that is... 105,ooo mile interval
i dunno about the 3.5L if they switch to timing CHAINS...there should be no interval changes for a chain...
edit: you got ripped off if you changed out the timing chains on your 3.5L 2005 quest this early in the game!
Quote »
It uses a detuned Z engine of 3.5 liters and twin overhead cams. The timing belt is gone, and a chain now does the job of moving camshafts. Will our customers change the oil enough times to keep the chain in shape? Time will tell.
keep the oil clean so the hydraulic tensioner will keep the chain "tight"
ps: also heard the rear spark plugs are a biatch for this engine
Quote »
I researched the service procedures and when the rear spark plugs were removed, it starts with "drain the coolant." I am not liking this. The rear spark plugs are now a major job, which is a real step backward. Were technicians thought of when this new van was designed? I would say no. It is futuristic but that future is not the one a technician dreams about. We want to have access to those parts that normally wear out, need replacement or service. As I have said so many times before, a little thought ahead of time would save techs time, customers service dollars, and warranty claims would be less expensive.
Modified by ricebike at 11:11 AM 6/10/2009
~219,xxx & going strong! @ South Jerzee Piggy-Powa!
WTB/WTT: http://forums.nicoclub.com/zerothread?id=199601 &
http://forums.nicoclub.com/zer...08505
wbaradio
Chesapeake VA
12-26-2009
Hey, my 2004 Quest just did the same thing. Odom/Gas gauge/Water Temp has partial display. We had a recent Nor'Easter that blew rain almost latterally, so I thought it might be caused by moisture in the display?
Did you repair... if so can you tell me what you did to fix it?
norcalnewbie
Oakley CA
2-24-2010
 « Re: Odometer/Gas Gauge partial display missing (wbaradio)
Hi guys new to the forums. I just joined and I happened to run across this thread while looking for a fix for my window gettting stuck at times.
I had the same problem as the OP. I purchased my Nissan Quest from a public auction in my area and I got it for a good deal because the miles didn't show. I guess people don't like to buy cars without miles not really sure. I ended up taking the car to Antioch Nissan and they refered me to Speed o tech in concord, ca(could be speed O tach) I'm kind of deaf sometimes lol. I took it out there and they were able to fix the display problem with in a couple of hours. I paid roughly $160 and some change with a 1 year warranty . They seem to be a reputable company because they had dealers and some retail customers dropping off speedometers and radios while I waited. Its been a little more than a year and it seems to be working fine. The display segments haven't gone away so I can safely say they fixed my speedometer. Just thought I'd give you the heads up.
Off topic: anyone know what could be wrong with my driver side window? It doesn't seem to want to roll down. It sucks going through a drive through. Any info would be great!!!
Modified by norcalnewbie at 8:50 AM 2/24/2010
Modified by norcalnewbie at 11:58 AM 2/24/2010
lino
1991 Q45a FED-SPEC
East Coast
8-15-2005
 « Re: Odometer/Gas Gauge partial display missing (norcalnewbie)
The guys in my signature have been selling instrument clusters for very cheap. They may have full clusters or just the separate parts available.
The cheapest place to buy New Genuine OEM Nissan, Infiniti and Datsun parts.
Try to beat these prices:
http://stores.shop.ebay.com/em...mrsZ1
» Return to Quest Forum
