 HP GAIN
nissan newby03
6speed 03 maxima
pasadena california
4-14-2009
  HP GAIN
HOW MUCH HP DOES A CATBACH EXHAUST ADD TO A 03 6SPD MAXIMA??
DJ Raijin
1992 300ZX 2+0 T Top NA
Chambersburg PA
8-22-2008
 « Re: HP GAIN (nissan newby03)
1000000WHP DEPENDING UPON HOW MANY STICKERS YOU HAS KTXHBAIBLE
Q45tech
Q45 Guru
Online
1990 Q45 326,400 miles 20.1 years ownership with original engine
Marietta , Georgia
4-30-2002
 « Re: HP GAIN (DJ Raijin)
Always good to measure things to see where you are before buying aftermarket components.
Measure current back pressure after cats. Each psi is ~~ 2 HP restricted.
Most very very loud cat backs can improve things 5-10 HP if properly designed.
Whether 0.1 second improvement in quarter mile is worth all the noise and tickets is questionable.
Copyright 2010. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
Glider33
2004 3.5 V6 Pathfinder SE
Shirley MA
3-24-2009
 « Re: HP GAIN (Q45tech)
If you use a quality muffler like a walker ultra flow or a magnaflow it shouldnt be too noisy and you should get some type of gain. If you go with some 20 dollar fartcan you probably wont see any gain and definitely tickets.
Q45tech
Q45 Guru
Online
Marietta , Georgia
4-30-2002
 « Re: HP GAIN (Glider33)
Important to define [from a restriction standpoint] EACH tiny piece of exhaust system from engine out to atmosphere SINCE the farther a restriction is from the engine the less important it is because of expansion area.
MIK3
02 A33 6MT
Phoenix AZ
5-18-2009
There was a dyno prototyped exhaust that Cattman did (his 3" cat-back) that showed significant gains in both HP and TQ. There was an average of I think 15whp OVER the his 2.5" cat-back. So, over stock, I would assume you are looking at around a 20hp gain? Granted, this was only one dyno, but there had been no previous modifications from switching the exhausts and the dyno runs. I'd definitely look into it. Two more back-orders and this makes it into production:
Click Here:
http://forums.maxima.org/5th-g....html
-----Want the best cat-back exhaust for a 5th gen out there?-----
--------------------JOIN THE CLUB-CLICK HERE--------------------
-----------------We only need 2 more backorders-----------------
A32MadMax
New York City NY
7-12-2009
Quote, originally posted by DJ Raijin »
lol
Orphan
UZZ31 Soarer
Brisbane QLD
12-9-2008
 « Re: HP GAIN (A32MadMax)
Stickers are definately important to improving performance :P
On a serious note i'm guessing that maxima has a VQ35DE in it? If so you will get very little power gain though you may get a bit more response, for an N/A 3.5L you really don't need that big of an exhaust to get maximum power out of the engine, header design does come into play quite a lot but from the pictures i've seen the standard headers aren't THAT bad for stockies. Overall its a waste of money unless your just trying to burn money.
If your car had a VQ30DET in it then I would say definately do it as well as a new dump pipe and cat which will mean FAR less back pressure on the exhaust turbine meaning it will spool faster and be more efficient thus generating more usable power and torque at lower revs.
The ideal exhaust size for turbo engines is quite different to N/A as in the case of a turbo the exhaust is more concerned about getting the gas from the back of the turbo out of the pipes where as in N/A platforms exhaust sizing can greatly affect torque curves in conjunction with header design and exhaust piping of too great a size and have negative effects on performance in some cases.
On a standard VQ35DE I can't see you getting anymore than 10-15whp more out of it on a standard tune. If you want it just for the sound i'm sure you can get a half decent muffler much cheaper that will give you the noise you want.
» Return to VQ30DE / VQ35DE / VQ35HR Forum
