 How many of you floored the EX35 ... pedal to the metal ?
ayap888
2008 Black & Graphite, EX35, Premium, Xenon, 18 Wheels. My other car - 2006 Audi A6 Avant
Whitsett NC
2-20-2009
Frankly, I have not floor the EX35 to the metal. Due to its raw power, it's just a situation that has not happened yet .. have you done it or not ???
Online Poll » Results
Yep - All the way down to the metal (86%, 33 votes)
Almost but not quite due to driving obstacles (10%, 4 votes)
Nahhh, just would not voilate the speeding law (2%, 1 votes)
Did rev it up but got scared & pulled up (0%, 0 votes)
(38 total votes)
RioD007
EX35 Platinum Graphite
Paradise Valley AZ
2-26-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (ayap888)
Quote, originally posted by ayap888 »
There has not been a time sence i have had my ex that i have not floor'd it... no joke.
and it go's like hell.
2008 EX35 (Loaded Except Nav) Platinum Graphite : Tint (5% Front Double 5% Rear 20% Windshield) : All Interior and Puddle Lights Blue LED : 10,000K HID D2C MOD :HID Fogs & Hi-Beams : Blue Rear Turning Signal Bulbs : Blue LED Parking Lights: Blue LED License Plate Lights : Blue LED Trunk Lights : Red LED Side Marker Lights:Hardwired Cobra Radar/Laser Detector : Resonator Delete : Stock 18's Wrapped With Wider and Super sticky 235 series tires
:Finally Got My +2 Mod (Ask Me For Details):
WISH LIST: Stillen Intake : Black Grill : Graphite Rims : Smoked/Tinted Taillights and Signals :Hawk HPS Pads: Bully Dog Tune :
jmess
Portland Oregon
4-7-2008
The lack of a limited slip combined with the computer nannies makes the EX pretty tame. I find full throttle acceleration above 60 to be slower than what I would have expected.
RioD007
Paradise Valley AZ
2-26-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (jmess)
Quote, originally posted by jmess »
A LSD in my dreams.
AWGD8
EX35 AWD JOURNEY (
WI
9-10-2008
Early morning going to work, I always take the same route below:
I start from the bottom of the PIC to the top left. The last turn is the
hardest one bec. once you come out of the apex , the straightway is not
90 degress but it kinda bend down more like a boomerang. The fastest I
turn there is around 50-55 MPH and it`s kinda oversteer sometimes after
the apex.
I guess bec. I`m still driving the car with a winter booth and I normally
turn the VSC off.
This is a one way road that leads to a highway or airport express highway and connects to an Interstate 94 at the very end.
In the morning, you could hardly see cars travelling this road.
The fastest I drove to this airport express highway is aroung 125 MPH.
Modified by AWGD8 at 8:05 PM 4/8/2009
AWGD8
EX35 AWD JOURNEY (
WI
9-10-2008
 « Re: How many of you floored the EX35 ... pedal to the metal ? (RioD007)
BTW, I leave my spare tire at home.
SteveTheTech
Technical Moderator
95 Infiniti J30
Alexandria VA
8-16-2008
 « Re: How many of you floored the EX35 ... pedal to the metal ? (AWGD8)
Great use of Google there Allan. I too would drive as fast as humanly possible on such a road if this magical place existed in my area.
I was driving a customers EX once and could not get this noise to duplicate until I went for a ride with him. We pulled out of the dealer and he proceeded to mash the throttle. To replicate the conditions I had his permission to drive it in the same manner. The problem was resolved and the long term shift logic had adapted to constant full throttle acceleration so the car was indeed pretty quick for what it is.
-------------------------------- Nissan Sport Magazine
RioD007
Paradise Valley AZ
2-26-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (SteveTheTech)
Quote, originally posted by SteveTheTech »
My shift logic is more then likely like this but is there any way to reset my ex's tranny logic and beat the hell out of the car in order to assure this?
Without having the ecu kill my Plus 2 ?
SteveTheTech
Technical Moderator
95 Infiniti J30
Alexandria VA
8-16-2008
There is no way to adjust or reset those values. However; there is an electronic reset for the Longterm Fuel Trim in the ECM and that might have an effect on your shift logic. Disconnecting the battery may work but I doubt it. In the loaner cars at my dealer we frequently reset the self learning to try and make these cars drive slightly slower (IDK why all of our loaner G35s can break loose on the 1-2 shift).
The transmission control module will recognize lighter driving and adjust accordingly. It has a hard stored "economy" mode so light (<1/8) throttle input will incur short shifts and almost full TCC lockup at ~43mph.
AWGD8
EX35 AWD JOURNEY (
WI
9-10-2008
After removing the negative battery cable, will our audio system needs a
code in order to reactivate? I remember Honda uses 5 digit codes in order
for the audio to work again when the battery or neg. has been removed.
MY 08 Toyota didn`t need one. I don`t recall any audio codes from my
Infiniti manual or paper work......
SteveTheTech
Technical Moderator
95 Infiniti J30
Alexandria VA
8-16-2008
Nope no code. You will loose all your presets and maybe some other things stored in the audio system.
AWGD8
EX35 AWD JOURNEY (
WI
9-10-2008
That`s good to know Steve.
Besides wetting my pants, is there any negative outcome in the long run
using Manual mode 99% of the time ?
gloa2000
04 Maxima SL, 08 EX35 LuxNav
Garden Grove CA
7-19-2008
trip to Vegas, wanted to see how EX could handle at high speeds, went up around 125mph, it really got sealed to the ground, i felt i was driving semi-sports car such as BMW 3 coupe, and finally got scared to get a ticket, let the foot off the accelerator and did couple lane changes at around 110mph, i was happy i did not choose RX350. With firmer suspension, this car can run tracks without any problem.
gloa2000
Garden Grove CA
7-19-2008
I dont think it should give you anymore negative outcome from car being run at M mode all the time, unless you make the engine to go over redlines all the time or put in gear where has not enough torque to pull the car without haggling. Sometimes I drive in M mode and forget to push to 2nd gear, leting the car drive above 6k RPM for a while, faster RPM will make Engine to run hotter and give more resistance between piston and blocks causing wears, so runing high rpm all the time will kill the engine sooner than others driving normal.
mcheddadi
Photoshop God
2008 Blue Altima coupe 3.5SE 6MT [Premium & Technology Package & VDC] with Blond leather
Montreal QC
5-17-2007
hehe, you should, it's a nice feeling
_______________▼Click me and Vote for me!▼
ayap888
Whitsett NC
2-20-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (mcheddadi)
Maybe it will be much more fun .. if you did it with me ... hehehe
mcheddadi
Photoshop God
Montreal QC
5-17-2007
LOL!
EibachMBZ
EX35
La Palma CA
2-3-2009
I am not sure if you guys are familiar with the ECU setting in a 350Z and G35. Even you pedal to the metal, stock ECU is set to only open 90% of the throttle and will slowly closing at higher RPM.
I am pretty sure the EX is doing the same thing...
Maybe a month later I will start messing around with ECU tuning and see what the EX is capable of!
ayap888
Whitsett NC
2-20-2009
Quote, originally posted by mcheddadi »
LOL!
mcheddadi ... I think that if there's anything more exhilarating than flooring the Ex35 .... it's taking you for a ride in this little hotrod.
tazdevl
EX35 Journey AWD Plat Graph/Stone - Fully Loaded
2-20-2008
Question doesn't make much sense... I've owned all manner of cars and I don't think there is a situtation where your average doesn't foor their cars on a weekly basis, unless it's the overly paranoid during the break-in period.
cjre1
Infiniti EX35 Journey
Canyon Country CA
5-17-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (tazdevl)
+1,
Everyone who floored this, does the engine accelerate in a smooth fashion, or did it rev high and then shift gears. What was the noise like? Did it feel like the engine was going to fall out?
Please explain. This is helpful.
BROUDIE
2008 EX35 AWD JOURNEY, 2002 TOYOTA MR2 SPYDER
WHITE PLAINS NY
5-15-2009
I need to learn more about this. My car (AWD Journey) is getting unusually low fuel economy 23-24 on long highway stretches. I suspect its been abused during test drives and the fuel trim is set for overly aggressive driving. How do I do the electronic reset? Can my dealership do this?
http://www.roadtripluggage.com
Jon_
2008 EX35 Journey AWD
San Carlos CA
2-2-2008
Recently had overnight drive from San Francisco to Salt Lake City. There is nobody on 80 in Nevada at 3 am.
First, my AWD Journey maxes out at just under 145mph. But not even close to a redline. So, obviously, the speed nannies (who are in this case probably more than correct in doing so) don't really want the thing fully exercised.
Shifting was fine all the way up. No redline at any speed.
As others have said, acceleration above the speed limit is, let's say, not what I have seen on Formula 1 on TV. No other experience to base it on, but I note it's a lot harder to make 3500 lbs move 70 - 140 than 0 - 70.
The most surprising thing was how solid things felt at these high speeds (above 120). Handling was fine. MUCH less noise or vibration than you might expect. Even the sunroof wasn't too bad.
Only complaints (beyond the disappointment that I couldn't get to 150) were that a few grasshoppers (locusts) got in from the sunroof and that it turns out high speed further compromises 3G reception (already weak in the middle of nowhere) to point hat Pandora cut out on me in the middle of a fine Elvis tune.
All in all a fine time getting away from getting away from it all. I'll probably never do it again.
BROUDIE
WHITE PLAINS NY
5-15-2009
 « Re: How many of you floored the EX35 ... pedal to the metal ? (Jon_)
Doing 145 on a public road while clowning around with your mobile phone? You should never do it again.
dividedhighw
EX35 Expert
2008 EX35 AWD (Technology Pkg)
Ottawa ON
4-22-2008
Quote, originally posted by Jon_ »
FWIW, Apr 2008 issue of C&D listed 2008 EX35 AWD Journey at 4032 lbs.
googleman
boston ma
9-8-2008
 « Re: How many of you floored the EX35 ... pedal to the metal ? (dividedhighw)
Why does this topic keep moving up on the forum page even though there are no new posts?
sg77
2008 Infiniti EX35
Santa Barbara CA
9-19-2008
 « Re: How many of you floored the EX35 ... pedal to the metal ? (googleman)
Quote, originally posted by googleman »
I'm guessing that it happens when someone votes in the poll.
EXceptional
2008 Aspen Pearl EX35 Freakin Loaded !
Alberta Canada
4-6-2008
 « Re: How many of you floored the EX35 ... pedal to the metal ? (sg77)
I did 180 kph today... the car was smooth all the way up and seemed to be still pulling.
Dean...
Alberta, Canada.
2008 Infiniti EX35 AWD
Aspen Pearl/Black Leather
Loaded with all the Toys.
My other Vehicle...
2003 GMC Sierra Denali
w/AWD & QuadraSteer.
» Return to EX35 Forum
