 Backup sensor not turning on? And driver side window won't stay up?
RyanY
2006 Nissan Quest Special Edition
hoschton ga
4-4-2009
Hello there,
Just picked up a 2006 Quest S Special Edition today. We like it alot.
One item I am having trouble with is the backup sensor. The button has the off light on and it will not turn off (meaning it is in "off" full time). Anyone have suggestions?
Also, when you roll the driver's side window all the way up it then immediately opens by 1/4. The only way to get it to stay up is to hold the switch in the up position for 5 - 10 seconds after the window is all the way up.
basskronick
Supporting Member
I drive a pontiac, and i love it, but i have nissan in my heart, I'm also the owner of a first gen q
smyrna TN
3-25-2006
 « Re: Backup sensor not turning on? And driver side window won't stay up? (RyanY)
Im not quite sure about the backup sensor, but the problem with the window sounds like a stretched regulator ribbon. Replace the window reg and you shouldnt have a problem after that.
<IMG NAME="icon" SRC="http://images.nicoclub.com/forums/images/smilies/bash.gif" BORDER="0">
CPS
Mobile AL
6-7-2008
 « Re: Backup sensor not turning on? And driver side ... (basskronick)
Actually, I would have the window re-timed before you go replacing parts. This typically happens if somebody replaces the battery with the window not completely closed or if the vehicle is jumped off with the window not completely closed.
On the switch thing, check the manual. You may have to hold the button down for some length of time before it turns off that way you don't accidentally shut it off.
Big-Bird
Supporting Member
2000 Xterra on 'Roids & 2004 Quest SL
Calgary AB
8-3-2006
 « Re: Backup sensor not turning on? And driver side ... (CPS)
If the "holding of the switch" doesn't work you may either have a faulty relay or the switch itself is damaged.
Anyone got a wiring schematic for this fellow Quest owner?
I wanna be like my 'older' brother when I grow up.... <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/images/smilies/tongue.gif" BORDER="0">
ricebike
89 240sx se 5spd 93 Honda Nighthawk 02 Quest
south or central Jerzee NJ
2-15-2003
 « Re: Backup sensor not turning on? And driver side ... (Big-Bird)
Quote, originally posted by Big-Bird »
http://www.nicoclub.com/FSM/quest/2006_Quest/
~219,xxx & going strong! @ South Jerzee Piggy-Powa!
WTB/WTT: http://forums.nicoclub.com/zerothread?id=199601 &
http://forums.nicoclub.com/zer...08505
jetroy240
S13, AE86
Sacramento CA
1-6-2008
for the window problem, I agree w/ CPS, have it re-timed first before replacing the motor.
for the backup sensor, if there's no beep sound at all when on reverse w/ an obstruction at the back, you may have a bad backup sensor tiny speaker, located at the dash.
» Return to Quest Forum
