jaimesix »
https://forums.nicoclub.com/jaimesix-u66653.html
Fri Apr 10, 2009 11:30 pm
The easiest way to have your B210 in good order until you gain a little more knowledge about auto mechanics would be to take it to a friend's shop, or a garage you know for a tune up.
Your caburetor might need adjustment, the bowl could be sticking as it was said, also the points/condenser could be worn out. I am sure it is nothing serious, but it is better to pay someone to do it rather than mess things up while trying.
If you want to try it, buy a set of points/condenser, spark plugs, cables, cap and rotor and air filter, and install these parts. Well, I think you already got those parts huh? Remember to gap the spark plugs. Set the timming and the points correctly.
Again, if not sure, go to a mechanic, or ask at this forum for someone that lives close to you for help with this.
Jaime.______________________________________________
