 1993 mass air flow sensor wires?
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
Does anyone know where the iat sensor wires are at? are they part of the mass airflow wires? If they are, which ones are they?
Thanks for the help guys!!
Paul Wall
Q45 Enthusiast
Online
1993 Infiniti Q45 133,000 Miles
Ipswich MA
12-22-2007
 « Re: 1993 mass air flow sensor wires? (jasonhirt23)
What to you mean by "iat"?
If you mean Intake Air Temperature (IAT) Sensor, there isn't one on 1990-1996 Q45's
There is MAF AKA Mass Air Flow sensor
You can try this ans see if it help:
This is what the MAF sensor look like and we usually take the black cover circled in the white off to see id the MAF sensor is good or not:
If you have a VOM AKA Volt, OHM meter you can try the below:
But this is much easier with a laptop consult connector by Blazt or a real Consult which the dealership and specialty shops have.
This is where the MAF sensor is located in the engine bay:
Welcome to NICO.
My Youtube videos
My items for sale on Ebay
1995 Q45 Partout - many parts cheap!!!
1990-1996 Q45 Parts for sale list-Will trade for computer parts!
New Genuine OEM Nissan, Infiniti and Datsun parts cheap.
Restore your active suspension and belt pulley bearings cheap.
Paul
1993 Q45 Green 11/92 Hybrid of 1990 and 1994 Q45, Soon to be Nissan President
Mods done: 1994 auto dimming mirror, 1994 Q45 tweeters, 1994 Q45 trunk net, 1990 Q45 Seat controls and more to come.
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
 « Re: 1993 mass air flow sensor wires? (Paul Wall)
What color are the wires and which one is ground and so on?
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
Well I think the standard color of a ground is black. But you can find the wiring diagram in the FSM: http://www.nicoclub.com/FSM/Q45/1994_Q45/
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
What was also weird was the fact when I opened the wire up, there was a black goop like substance in it. Anyone know what that is?
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
Can you how us pictures or better describe it? Because all I can think of is the black RTV (Which is rubber).
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
Well, there is the wire "sheath" or cover if you will. Then I opened it up to look at the wires and it was just black goo or something black and sticky in side. Before I opened it, the cover was never touched, cracked or opened. It looked like no-one ever messed with it.
Raxephon
'04 RX8
Fl
7-27-2004
Liquid electrical tape maybe?
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
I don't understand the wiring diagrams. I'm not good at electrical. I can put a car stereo system together but that's about it!! LOL! Can you give me some more detail as to which wire is what and maybe what it does or if this is hot or now and so on!!
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
I don't understand the problem your trying to solve.
Do you think your MAF harness, connector or sensor is actually bad?
What problems are you having.
Q45tech
Q45 Guru
1990 Q45 323,000 miles 19.5 years ownership
Marietta , Georgia
4-30-2002
90-95 VH45 don't have a separate IAT sensor infront of or inside MAF to provide a double check on MAF function. THe function of IAT is performed by ECU mathematically by viewing coolant temp, and AC on signal.
After all the O2 sensors provide final trim at cruise and WOT is always SUPER RICH. Whether the intake air deviates from STANDARD 70F much..................... 130F [-6% density] or 10F [+6% density].
If WOT AF ratios is 11.00: 1 at 70F then 10.34 @ 10F and 11.66@ 130F* is inconsequential in acceleration.
* 130F probably means summer traffic and AC on signal and above 195F coolant stat decreasing ignition advance to protect engine so a IAT GUESS is almost as good as a sensor reading.
Only OBDII requires multiple backup sensors for every function.
Copyright 2009. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
 « Re: 1993 mass air flow sensor wires? (Q45tech)
Well, I don't really have a problem with the maf sensor. I was merely trying to hook something up through it and was trying to figure out the wiring.
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
Oh, the 5% resistor to add 30 HP?
Doesn't work.
Brian
1995 Q45 & Q45t & 2000 Q45
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
 « Re: 1993 mass air flow sensor wires? (maxnix)
Act
Quote, originally posted by maxnix »
Doesn't work.
Actually this one is or looks not to be a resistor. It is a box but I guess the same idea. I will give it a try anyway, so which wires would I hook up to? The white, black with stripe, or black? It hooks to 2 wires.
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
Didn't it come with instructions?
SleepinTXQ45
1994 Infiniti Q45
San Antonio Texas
3-8-2009
black is ur ground
black/white is ur signal
white is ur 5v reference
jasonhirt23
1993 Q45
Tacoma Washington
2-16-2009
 « Re: 1993 mass air flow sensor wires? (SleepinTXQ45)
Quote, originally posted by SleepinTXQ45 »
black is ur ground
Thanks alot! I appreciate it. The instructions are a little vague but I think I can manage.
SleepinTXQ45
1994 Infiniti Q45
San Antonio Texas
3-8-2009
Jason, i fed up.....
black/white is ur 5v ref
white is ur signal
sorry for the problems
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
Since Q [90-95] doesn't have an IAT, kind of impossible to connect the dubious destructive box. Thank goodness.
Kiven422
93' Q45, 94 Q45t
Hayward CA
8-23-2007
Hello Jason,
I am having this exact same problem right now with my 1993 Q45. Must do myself to have it done right.
Thanks for making the post.
93 Q45 Black
JDM V8 Swap. Ultimately the fastest.
94 Q45t White
93 Factory Intake Mod, Magnaflow Dual-Exhaust (incl. high-flow cats, mufflers), Eibacks\Tokicos, JWFSTB, Active RSB... It seems I have more power now at 207k miles. The torque above 65mph is amazing.
qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
white is ur signal
Third time's a charm...
Black = ground
white = 0-5.12V output
Black/white = 12 volts
This one doesn't use the 5 volt reference like some vehicles. it's 12 volts.
More info...On the MAF the socket is labeled 'B' 'D' and 'E'
B = white: 0-5.12V output
D = black: ground
E = black/white: 12 volt supply
Oh, and Jason...don't bother with that resistor in a fancy box. Trust me and the others, that's all it is and it won't do anything but make your car run crappy or not at all.
» Return to Q45 Forum / Cima Forum
