audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sat Feb 21, 2009 3:25 pm
Doing some work in the storage room of the basement there was a water line hanging around that used to be part of the old heater. By looking at it I knew it had been the water line that went to the built-in humidifier from the old oil-based furnace. As it was in the way and not in use I went ahead and decided to put my new pipe cutter to use. As I'm sure you can guess, it was a gusher.
Water went everywhere. Wife grabbed an empty bucket to start catching the flow and was spittin and sputtering as it was flying in her face. CLASSIC. So, I turned off the main water shutoff and it only slowed by 1/2....Guess I need to have a new shutoff valve installed as water was still pouring out of the 1/4" pipe.
I traced it back to the main water pipe and it did have it's own old shutoff valve.....Which the idiots that initially threw in the ducting had blocked off with a metal pipe. 20 minutes of screwing with it and I had THAT shut, but it only decreased the water drain by another 1/2....Oh my!
I went ahead and installed another coupler to the old electric solenoid that I had removed from the pipe and the water leak was gone. What a pain in the butt!
So, I guess we are going to contact the guys who put in the new heater as they should have removed that line and patched the pipe. If they don't take care of it I will have to bill them for another plumber. Will have to get the main shutoff taken care of as well.
Fun fun fun on a Saturday night
