Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Oct 25, 2003 3:01 pm
Have one [24mm] sitting out in the back yard. This was part of my first Stillen/Goldrush upgrade to the Q back in 1994.................drove with it [in various assorted couplings] till 1999 when I downgraded to the 20 mm rear bar! Toyed with the 15.9 mm one for 2 days, along the way.
It would be great if someone had the facilities to actually measure the 20 mm rear bar stiffness [alone and as oem mounted]...........instead of relying on my mathematical approximations and some simple tests I did years ago.!
My 160 pounds per bar inch [20mm oem] could be wrong by 10-20%.
Unfourtunately because Nissan chose the mid point lower rear arm and perpendicular/ endlink mounting method.......there doesn't seem to be the room to triple drill the 6" arm [5,6,7"] [+20, zero, -14% correction] for adjustablity.....the angles would be difficult with urethane and rubber defeats the purpose.
So we must get the bar diameter/arm length perfect, unfortunately everyone idea of just right is different, as Stillen found out with the maximal 24 mm solid bar.
