ultimate wire tuck guide
White Comet
Car: fc, s13 and mazda6, Sierra
this is just meant to be a refernce to anyone wanting to do a similar type of wire tuck. there are many ways to do it, but i just figured i'd share mine since it is very extensive and may be useful to others. i was going to post this i my build thread but i thought this would be easier to fine for anyone searching for wire tuck info.
Now this may be a little crazier then some people want to go, but enjoy anyways. i want to point out that a lot of the credit goes to mrgreeneyes. he did most of the wiring work and is a walking encyclopedia when it comes to s13 wiring. (he has literally told me what a certain wire is for based on its color and where its at )
large part of this project focused on the body harness. One day i got the crazy idea to remove the section of the body harness that runs in the engine bay, the one that runs down the fender, across the rad support, up the other fender and into the smj. i thought i'd rather have that harness connect at the smj and run across the dash bar next to the wiring already located there. this project started back at the tail end of summer, so on a nice day in september we laid the entire harness out in the yard and stripped out everything not needed, and when i say stripped out, we completely removed stuff back to the smj and pulled the pins. after everything was removed and the harness was stripped of the split loom and tape, we laid everything inside the car to mock it up. we came to the conclusion that only a few wires need to be run outside of the cockpit. on the passenger we ran wiring only for the headlight, headlight motor, wiper motor, washer motor, bumper lights and fender markers. the only thing i still need run on that side is a single wire for the sohc sensor in the lower rad hose. but for the most part, the bundle on that side looks like thisas you can see its much smaller then the original bundle that runs there and the little lip was bent so that the wires can run on the side of the fender area instead of underneath, so there is no chance of them being rubbed through by tires.the wiring inside went from thisto this mess
that was it until now since i was focusing on other parts of the project, but we started up again last week, and it was time to tackle the mess in the dash area. i don't have any pics of this step, just the finished product. we unbolted the dash bar and took the harness with it. we laid the dash frame against the wall and used it as a reference to mock up the wiring for how long everything needs to be. every single wire was individually untangled and cut to the proper length. this got rid of lots of excess wire and we somehow found more stuff to completely remove. after everything was mocked up we bolted the frame into the car and made sure everything fits perfectly. i then lengthened the wires for the driver side (headlight, headlight motor, fender marker and bumper light) i still have to run a wire for the horns. with everything extended all that needs done is some loom and mounting a few factory fuses that are being reused for other things. this is currently how its sitting thoughthe plan has changed slightly. i was going to mount the fuse block in the glovebox, but keegan convinced me to mount it to the dash frame and it'll work out nicely.
with the body harness taken care of (for the most part) it was tie to tackle the engine harness. keegan spent 8 hours alone just on that. everything was untangled, lengthened, shortened or removed individually. the entire harness was untangled and is insanely clean. i had done a semi tuck on it before but everything was changed just a little. the injector wires run in the intake manifold along with wires from the mafs, cas and tps. the only wires you'll really see are the cas and mafs running across the front of the motor. everything else is cleanly taken care of. on to the picshow the coil pack wiring will gothe master at work. we ziptied the ecu plug to the engine stand so everything could be mocked up nicely.the tangle we started with
the injector wiring i mentioned
very tedious work
everything slowly getting there
after everything was done outside of the car we laid everything in and bolted up the ecu and snaked everything through the firewall grommet. i forgot to mention but the wire harness for my avcr was wired into the engine harness. ^ i love these pics. thats with all the body harness run, so those in the bay are the only wires that will be in the engine bay at all. and that makes me happy.
there is still a little more to do, but everything should be done next week. i still have to order a few little wiring goodies though. feel free to ask any questions and i hope this comes in handy
Modified by White Comet at 1:14 AM 2/21/2009
Modified by White Comet at 1:17 AM 9/18/2009
LOVERboy
Car: 1997 240sx se KAT
awesomeness!
93240cooool
Car: 1993 240sx
your shirt <3
duffman1278
Car: 89 240sx Hatch, the wildcats!
Good work! I'll be doing this to my S13 soon but I'm just rechecking the wiring, and basically memorizing the S13 FSM's wiring diagram. Are you going to be using sleeving or wire loom? Because imo sleeving comes out REAL clean.
BUTT CONNECTORS?!!? lol
White Comet
not my shirt, that greeneyes in the pics, but it is a sick shirt
spooled240
Car: kouki s14
good stuff can't wait to see the final engine bay shot
MySXisSlowerThanUrs
Car: Toyota Mr2, Nissan 350z, 89 Piggy 240sx
spooled240 wrote:good stuff can't wait to see the final engine bay shot
Oh for sure its going to looks sick!
White Comet
thanks guys, i'm anxious for the final outcome too. eventually when i get a tune im thinking i should get a power fc d jetro, then i can get rid of the mafs
!Zar!
Car: Countless.
Why are there so many butt connectors?
It looks like you soldered/heat shrinked everything else.
Logan76
Car: Junk
Nice, Im at the same phase as you in my civic, wire tuck. I want to attempt a brake line tuck also, and since my funds are too low to finish buying my fuel system, ill just keep tucking/cleaning until I stumble across a little stimulus lol.
White Comet
!Zar! wrote:Why are there so many butt connectors?
the harness is from someone elses car, teh butt connectors were already there, but they were eliminated when everything was cleaned up
Logan76 wrote:Nice, Im at the same phase as you in my civic, wire tuck. I want to attempt a brake line tuck also, and since my funds are too low to finish buying my fuel system, ill just keep tucking/cleaning until I stumble across a little stimulus lol.
yeah i thought about a brake line tuck, but i'm fine with the way they are. i think i'm gonna mount my boost solenoid under the vents at the bottom of the windshield
Hijacker
Car: '92 240sx Convertible
'94 F-150
Looks pretty good so far, WC. I'll link this in one of the stickies
Logan76
Car: Junk
in with the wiper motor? that mad stealthy, most of my **** is going under the dash, no factory A/C thers a little room under there for improvement.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
nice work
White Comet
Logan76 wrote:in with the wiper motor? that mad stealthy, most of my **** is going under the dash, no factory A/C thers a little room under there for improvement.
yeah in where the rods connect to the wiper arms. keegan keeps coming up with some pretty good ideas and we're both perfectionists who refuse to cut corners so this is what happens. theres gotta be at the very least 25 hours in just the wiring
Hijacker wrote:Looks pretty good so far, WC. I'll link this in one of the stickies
awesome, i hope it can be helpful to someone, i've noticed a few wiring tucking threads poping up lately
sebazztard wrote:nice work
thanks, wait for the end result. i got ordered $40 worth of techflex and other stuff today. i went with 2nd day shipping
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
wow thats amazing dude
im definately strippin all the systems i dont need. i doubt ill put the engine bay harness in the cabin but its definately sweet
White Comet
it very time consuming but god am i pleased with how its looking. keegan is like an artist when is doing his thing, no lie
noobdrftr
Car: of crap...just pure crap
that is awesome, i am going to do a wire tuck when i swap in an SR...lol at your shirt
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
This is awesome!!! I'd like to one for KA24de - RB25det swap!!!
White Comet
^ the body harness part would be exactly the same regardless of the engine, and the engine harness wouldn't be hugely different
MySXisSlowerThanUrs
White Comet wrote:^ the body harness part would be exactly the same regardless of the engine, and the engine harness wouldn't be hugely different
I dont know if you mentioned it above but when are you going to be done with it and have pics for us to see?
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
we were up til 4:30am the other night doing this...
nice thing is, once we draw up the pin layout for every plug on the engine harness, de-pin, and flez loom, ill have those diagrams for my sr swap...
its been a lot of work, but only having one 1/4" harness and one 5/8" harness in the bay... will be amazing. and my body harness will have nearly 1/4 of yours if only youd let me delete the light motors... lol... i know i know...
monday i have off. hit me up
and the F(ail)WD shirt is mine. that sexy beast is me. altho jeff managed to make me appear stoned in all those pics... i wasnt stoned, i was all hopped up on green tea...
and i swear to god, someone say something else about the effing butt connectors. THEY ARE GONE!!! i dont do that crap. its ALL soldered and taped with high quality supplies (mmmm, plymouth tape and pro-grade solder...)
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
In your pics you look all blazed, your eyes look all low. Its probably from all that thinking and concentration.
White Comet
hahah you're never gonna let me live down keeping the light motors. yeah i didn't notice it before but you do look pretty baked in the pics, probably just because they were taken between 2 and 3 am. it's ok thoguh, i managed to fall asleep while sitting on a stool
cmoody2006
Car: 1993 Nissan 240sx vert
Wanna do my wiring for me? lol jk That's what I'm stuck on now but Looks really nice. Just wish you had a ka for a better reference!
Car: 1996 240sx kouki
What's a wire tuck?
click the picture to see more. LOL!
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Wow. Wiring is such a PITA to me that I usually have someone else do it, just like Keegan is doing yours This looks like it will be quite nice once finished. I ote for flame/heat resistant/repelent sleeving as well for the engine bay wiring, esp. since your wires are inside of the intake mani.
1sikS13
Car: 1992 S13 240sx
mrgreeneyes wrote: ill have those diagrams for my sr swap...
You have sent me into a state of depression with just this one statement.
White Comet
homeslicej2 wrote:Wow. Wiring is such a PITA to me that I usually have someone else do it, just like Keegan is doing yours This looks like it will be quite nice once finished. I ote for flame/heat resistant/repelent sleeving as well for the engine bay wiring, esp. since your wires are inside of the intake mani.
yeah it's funny, wiring scares the **** out of a lot of people, but once you get in there is relatively simple (for the most part). i'm pretty confident in most of what we did, i even did a lot of cleaning up the harness with out keegans help (this was a few months back when i did a mild tuck) but i seriously just turn him loose on it, even the stuff i could do myself, he does it better and faster. yeah the sheaving should be here on monday so i'm really excited.
keegan- i think i can get my monday shift covered and hopefully the wirecare stuff will be here by then
cmoody2006 wrote:Wanna do my wiring for me? lol jk That's what I'm stuck on now but Looks really nice. Just wish you had a ka for a better reference!
like i said, the main bulk is universal, just teh engine harness is sr specific and even then its similar; lengthen injector wires, tuck in mani, etc
driftneil
Car: A pile of cars.
Wow bro, shtuff looks awesome!! I need this in my life!
