naladude911 wrote:So I have some more ideas-in-car breathalizer, my teacher said it was done already.-tire pressure adjuster - built in car airtank that automaticly adjusts tire pressure due to road conditions or temp-allignment indicator - warning light that indicates which wheel is unaligned-sunvisor button - switch on wheel so you dont have to pull your visor down-tread monitoring system - regulates tire wear.-detachable solid body panels - body panels which look flush against the car, but can easily be broken due to an emergency. EX, pushing the roof off to get out if all the doors dont work.-semi-ruberized barriers - absorb highway impact, need to be researched so they wont expand or contract.
1)no2)nitrogen is cheaper and does the job better3)alignment indicator is when your steering wheel is jiggling4)sunvisor button... it can't be that distracting to pull it down by hand5)tread wear... not possible to sense it6)detachable parts only make the car more dangerous, especially at an roll over7)plauseable
not bad for thinking these things up..
however.. the MOST effective way to make the roads safer is the change the DRIVER. Guns don't kill people, only the person holding does. Same concept with the car.
-Requiring everyone to take a extensive driver's ed class.
-second opening more public places for youth to thrash their cars keeping them off the streets
-third raise the age of driving to higher age, already proven that higher ages are less likely to have an accident.
-govern the car to sense road speed at posted speeds and limits the car to that speed
-take away licenses from older people once they reach a certain age.
-complete computerized driver would be a more safer route, however not guarantee that there won't be any accidents. even computers crash..
There has to be a social need for a society to change. There is not easy pill that will take that away. No matter how great we can invent a car or road system, people fall though the faults.
But to throw one innovation idea. fill the inside of the body with gel. Once impacted the gel hardens up. Like a helmet, once impacted it protects the head, and you have to buy a new helmet.
Here's the concept. Have 2 friends hold a bed sheet top and bottom. You.. throw some eggs at the bed sheet as hard as you can.
You will observe that you will not break the egg, because the sheet absorbs the impact. Same concept for this gel that hardens on impact.
But however, I still stand by that it's a society that needs to change, not the car.
Modified by Rare_f8 at 6:59 PM 2/6/2009
