 240sx Squealing belt tutorial
vancouverbc
Tutorial Man
Online
1991 240sx
langley
10-30-2003
Back to TUTORIAL Index
The squealing is usually the belt slipping on the pulley. With the engine running rub a bar of soap on the side of the belt. You may have to get under car for the alternator belt. Give it at least 20 seconds. Even bad squealing will go away for a few weeks with application of soap. This will tell you which belt is the problem. You can also try spraying water on the pullies one by one but not as effective.
1. loose, damaged, or wrong belt (belts should not have more than half inch of deflection)
2. glazed belt or pulley(sand pulley and belt)
3. oil or liquid leaking on belt( drive shaft seal, water pump weep hole)
5. alternator bearings shot(idle goes down when interior heater on; squeals when interior heater turned on)
6. power steering pump shot(does turning make noise worse)
7. Idler pulley
8. fan clutch shot Fan Clutch
9. water pump shot
10. radiator blocked??? not sure about that one
11. pulley out of alignment(straight edge metal ruler)
I bought a ten dollar stethoscope which helps you determine if noise is coming from alternator, water pump, power steering pump
Modified by vancouverbc at 1:54 AM 2/4/2009
Modified by vancouverbc at 1:59 PM 1/9/2010
1989-1998 240sx TUTORIALS
Factory service manuals 3
Factory service manuals BEST
Factory service manual2
Factory service manual 1989
Old FAQ
INSTALLS
Pictures of parts
positron_
240SX Padawan Learner
1993 Nissan 240SX Coupe SR
Starkville MS
3-21-2005
 « Re: 240sx Squealing belt tutorial (vancouverbc)
This is most excellent information bro'!
"All Your Base Are Belong To Us!"
S13 300ZX Rear Brake Install
S13 Wheel Stud Replacement
S13 Fender Brace Install
S13 Subframe Collar Install
S13 Power Folding Mirror Install
S13 KA24DE Engine Removal
S13 SR20DET Prep
S13k
Nissan 240sx 91 s13
Hayward CA
12-21-2008
Out of the nine problems you said, i think i have atleast three: alternator bearing, loose belts, and the fan clutch. thanks man that really helped me a lot
S13_love
Bright Orange '89 240sx
Missoula MT
9-2-2008
 « Re: 240sx Squealing belt tutorial (S13k)
What about the idler pulley too?
Project 240 http://forums.nicoclub.com/zer...t-240
Mathdes8718
nissan 240sx 1995 and cadillac CTS 03
Montreal QC
4-26-2008
 « Re: 240sx Squealing belt tutorial (S13_love)
hey thanx for the info ill try that when the snow leaves and I can get my car out , i had squeeling noises back in september so that might help it!! thanx!
