tfvesquire »
https://forums.nicoclub.com/tfvesquire-u83121.html
Fri Jan 30, 2009 6:09 pm
Hi there:
It's been awhile since a posted a thread for some help so here goes. My 98 Q has had an intermittent problem with the shift lock solenoid "clicking" when you press the brake with the car in gear, like sitting at a stop light. It literally sounds like the shift lock solenoid is short circuiting. When I investigated the area around the shifter, I discovered the PO must have spilled a large soda all onto the shifter and the liquid got into the shift lock solenoid switch and surrounding electrical connections. I cleaned the area out as much as I could and used compressed air to dry everything. I did not have any problems until a few months later.
After the clicking came back, it was after I had driven the car in heavy traffic and had to press the brake constantly. I thought the shift lock solenoid must be heating up and malfunctioning. It went away (so I thought) when I liberally sprayed the shift lock solenoid switch and connectors with electrical cleaner and dried them with compressed air. FYI, I have thoroughly read the FSM, but do not have the proper know how on auto electrical work.
Recently, the annoying clicking came back, and not just intermittently, but every time I drove the car. I located an entire replacement shifter unit from a parts car. It came with the shift lock solenoid and detention switch (this switch activates the PRND21 lights on the dash and in the TCM. After installing the replacement shift assembly and resetting the computer, the clicking was still there.
I located a replacement shift lock control unit from another 98 Q and installed it. It still clicks. I cleaned out the brake switch and connector, no good. I just purchased a replacement brake switch and shift lock control unit and installed them two nights ago. Reset the computer and no click. I thought, great I fixed it, but after driving the car less than a mile around town, the clicks returned.
At this point, I don't know what else to do except take it to the dealer and have them diagnose what the problem is. Am I over looking something simple? Is it possible that the shift lock solenoid on the replacement shifter unit is bad and causing my issue? ( I looked it over before installing it and it looked really clean to me) I even traced as much of the wire harness that I could from teh shifter to the shift lock control unit and did not see any loose or grounded out wires. Is it possible my BCM or TCM units are going bad from the constant switching of the shift solenoid? The car runs great and everything else works properly so I am baffled. I am a mechanical DIYer, but electrical is not my forte.
If anyone has any good suggestions on what to check before surrendering my baby to the dealer, let me know.
Thanks and hope all is well with all of you.
Ted, Chicago
