Wiring will be fun to say the least. On the vq35de you need a body control module, the nissan anti theft antenna with a key, and the drive by wire electric gas pedal.
zer...age=1
zerothread?id=351373
But there might be a way not to need all that and run it on a JWT retuned maxima ecu. The vq30det does not have the variable valve timing.
zer...agram
As for semi cheap i'd say you will spend more on the vq. there is the engine, the 6-speed, modifications to the engine crossmember, modifications to the shifter assembly, modifications to the transmission crossmember, custom driveshaft, custom y-pipe and headers for NA or custom headers and downpipe for turbo, a high flow fuel pump, then the wiring.
The SR is made to bolt in and has lots of parts available, but to get near the stock vq power levels will require upgrades.
