 Transmission FlushFirst  1 2 >  Last
pirenuri
1998 Q45
New York NY
10-9-2008
  Transmission Flush
I have been having some shifting problems and I was recommended to flush the fluid.
Jiffy Lube offered me two options;
1- 69$ service that flushes only half of the fluid.
2- 139$ service flushes all (including fluid in Crankshaft).
But neither of them includes opening the pan and cleaning parts or replacing the filter.
They told me that there is no need to do that for 98 models.
Should I try either one of the options? if so which service worth spending $$? Or should I try different service center?
Thanks
pirenuri
1998 Q45
New York NY
10-9-2008
 « Re: Transmission Flush (pirenuri)
I forgot to mention;
1998
Q45
with 140K
I have no knowledge of any prior transmission service.
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
http://www.bgfindashop.com
Call and ask a shop if they will perform the service as specified on this board.
Parts from Joe's crew:
http://www.infinitpartsusa.com
B&M ATF cooler from
http://www.summitracing.com
Brian
1995 Q45 & Q45t & 2000 Q45
tfvesquire
1998 Q45
Chicago IL
12-6-2007
 « Re: Transmission Flush (maxnix)
At 140K with no history of trans service I don't think a flush is a good idea. What may happen is that all of the crud and varnish on your clutches and seals may get washed away and it will slip, stutter even more.
You should try to drain and fill the system yourself (or have a shop do it)and see if just putting in fresh fluid helps. If the fluid looks a little dark, but doesn't smell burnt, then you might get lucky. However, if the fluid is really dark or brown and smells bad, you might have to start saving for a lower mileage trans to swap in.
Any other members feel free to chime in. IIRC, a complete drain and fill to get all/a majority of the old fluid would take about 11 quarts.
Ted , Chicago
mxr662
1990 Q45 Desert Sand 70k
Rocklin CA
2-11-2007
What I did was pull the transmission pan, cleaned the pan, replaced the filter, installed the pan with new bolts from the kit. Then added fluid and took it to a http://www.bgfindashop.com/locator/index.php.
Made sure I was able to watch while they did the flush. The machine shows the fluid color as the flush is taking place. If it does not get clean have them flush more while the machine is still connected.
maxnix
NICO Supporter
Austin TX
7-22-2002
 « Re: Transmission Flush (tfvesquire)
Quote, originally posted by tfvesquire »
1.) At 140K with no history of trans service I don't think a flush is a good idea. What may happen is that all of the crud and varnish on your clutches and seals may get washed away and it will slip, stutter even more.
2.) You should try to drain and fill the system yourself (or have a shop do it)and see if just putting in fresh fluid helps. If the fluid looks a little dark, but doesn't smell burnt, then you might get lucky.
1.) This is unwarranted speculation! To follow this to the logical conslusion, it is better to operate an automatic transmission with crud and expired ATF in it than new ATF. If this is so, why do not AT come with old fluid and varnish pre-installed?
2.) Color change from new is in direct correlation to ATF degradation. What sense does it make to leave 60% of a degraded fuid in the AT by doing a drain and refill? Not removing, inspecting and replacing the interior screen filter and O ring is a sin or omission.
People are entitled to their opinions and deciding their own course of action or inaction, but the fallacies of their reasoning must be exposed.
96Qowner
Supporting Member
1996 Q45
Fargo ND
9-7-2004
Yeah, I think this may qualify as an urban myth. In years of reading this forum, not once has an Infiniti transmission suffered any problems from a flush.
My local Jiffy Lube franchise is great - one of the first 100 and VERY well run. I've trusted them with my cars for 15 years. But ... not all are great. If you trust your local Jiffy Lube, their flush is virtually identical to a BG flush.
1996 Q45 -217,000 miles
1990 Accord - 398,000
1966 Thunderbird Q code - 87,000
oldmako
'99 Q45 156K Black&Tan '96 Silverado 5.0 235K '89 23' Irvette CC F351
virginia beach virginia
12-3-2007
 « Re: Transmission Flush (96Qowner)
I am so paranoid about my transmission and fluid degradation, varnishing, sloughed off clutch material etc that I just drained it completely and run it dry.
Just kiddin'. I went the Full Monty and sprang for 14 quarts of M1 and had a local bg shop do the work. The trans is an expensive Achilles heel and will probably send my car to doggie heaven when it goes, so to my mind the expense was well worth it. Did it help? I dunno but it probably had 120K on the factory jizz when I bought it so it was way overdue.
Modified by oldmako at 10:30 AM 1/7/2009
Since purchase Dec 07: Front struts-mounts-springs & rubber, Tension Rods, Stbd Tie Rod End, Front Brakes & Shims, All Belts, Mondo 245 tires, Spark Plugs, RR Diff with M1, RR Brake Fluid with my three dollar gizmo, RR PS fluid, RR coolant, RR Blinker Fluid M1, B/G TrannyFlush w/M1 and super jizz, Tranny Cooler, Misc wrenching and what not, 130!
bullittandy
1997 Q45, 243K miles, 1999 Q45 touring 170K miles, 1997 Q45 186K miles (junk)
Atlanta GA
7-21-2005
You will find several people who disagree with me but I would not sweat changing the filter or dropping the pan. I have dropped the pan and replaced the filter on a 97 Q45 with 215K miles and other than a small placebo effect gained little IMO. The "filter" is a small wire screen that only filters large visible chunks of contamination.
If you really want to drop the pan and you wanted to save some money you could clean the "filter" and blow out the debris. BTW, I also reused the pan gasket and pan bolts and have had no leaks in 30K miles but this is also not recommended.
I would change all the fluid and hope for the best.
Good luck!
pirenuri
1998 Q45
New York NY
10-9-2008
 « Re: Transmission Flush (bullittandy)
Thank you all for your replies.
Q45tech
Q45 Guru
1990 Q45 323,000 miles 19.5 years ownership
Marietta , Georgia
4-30-2002
The only question is what chemical solvent is used AS THE FLUSH and how long it is allowed to circulated, how the shifts are done to make sure THE FLUSH SOLVENT reaches every nook and cranny, BEFORE THE FLUSH SOLVENT is removed by replacement ATF.
Because time is money many shop short cut the 20-30 minutes of FLUSH recirculation. Because time is money many shops fail to recommend another complete cycle when the process doesn't deliver clean as new ATF due to excess clutch material or internal out of standard cross leaks.
Copyright 2009. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
qship96
Online
1996 Q45
Timonium,Md
11-24-2002
Quote, originally posted by pirenuri »
Thanks
Purchase 16 quarts of ATF from your local auto emporium and a 99 cent drain pan, get out your wrench and simply unscrew drainplug, let the 4qt drain, replug and refill....go for a 5 mile drive...........repeat entire process 3 more times, and you will have effectively replaced 85% of your old fluid- fast,easy,cheap,safe, and effective.
maxnix
NICO Supporter
Austin TX
7-22-2002
 « Re: Transmission Flush (qship96)
Quote, originally posted by qship96 »
And 15% of the old contaminated fluid and 100% of the varnish and all of the detritus that won't flow out under gravity.
I see no savings here, only partially mitigated abuse.
qship96
Online
1996 Q45
Timonium,Md
11-24-2002
Quote, originally posted by maxnix »
Brian, you might want to let the engineers at Nissan know that, as they ONLY recommend the drain/fill procedure{ no machine flushes} for the G50 and Q41, and you can also let my 222,000 mile perfectly operating original tranny know that also!
miata007
2009 Cube 6sp, 2005 G35 sedan
Sacramento CA
8-11-2005
I did the following over the weekend.
1. Drain ATF at pan and refill (~5 qts).
2. Drain rest of ATF at radiator return line until color matches new fluid. (took 13 qts). At the same time another person is putting in new oil.
Note:
The fluid coming out of radiator return line is extremely fast. So be sure to have new ATF ready to be poured.
Doing the above is another option if you don't want to flush. The old fluids are pretty dark compare to the new ones (Castrol ATF for import).
The care seems to drive normal. I can't feel any improvement though.
007
JOHNQ
99 QT/00 AE
NORTH BERGEN COUNTY NJ
1-18-2008
a drain and fill is all you need to do. maybe repeat it once more and add redlubegard and if desperate the lucas trans fix but if your trans shows no improvement then your trans is toast and will not get better with a 100% fluid flush.
Denver90Q
1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
Denver co
12-30-2007
 « Re: Transmission Flush (JOHNQ)
Anyone try AutoRx for transmissions? Some on bobtheoilguy forum rate it highly.
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
LMAO! My tranny is still operating great with 194k miles and no tranny cooler. I'm doing this to see how long it last againt other board members who say that this is greatly needed. If my tranny goes at 215k (which I doubt), I'll just get a remanned one. There is no way I will complain about a tranny after it last well over 200k. My next tranny service is scheduled at 205k but I won't go with M1 this time around.
Tech, you speak about the "things" that should happen with shifts, but never gave a time period. That info would be great for people to know when dealing with flush machines. If you are speaking about the 3-5 solvent flush in each gear...then I'm good because I did that at 175k.
1998 Infiniti Q45. 212k and counting on original motor and transmission...
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
 « Re: Transmission Flush (NightRiderQ45)
Many members confuse the 90-93 tranny design with the improved reliability 94-96 or the further improved and less engine stressed Q41 97-01. The ~~10% lower peak engine torque of the 97-01 does wonders for the improved life of the design.
Along with dual heat exchangers and extra atf filter.
Really not possible to correlate 90-93 with later years.....................unless you duplicate the dual coolers and external filter and have a oem factory remanned replacement.
My 1994 replacement lasted 200k+ with an external cooler and frequent ATF replacements which might compare to ATF filtering. Tranny #3 with 120k+ is operating fine with zero signs of problems yet and I expect 200k as did the previous one even with the 20% higher torque than the Q41
Miles is such an effimeral concept without knowing the exact number of shifts per mile and the power output coupled thru each shift!
qship96
Online
1996 Q45
Timonium,Md
11-24-2002
 « Re: Transmission Flush (Q45tech)
What I find MIND BAFFLING is that hardly anyone replaces the factory EXTERNAL fine particle paper filter......they keep talking about replacing the in-pan chunk stopping coarse screen.......
Paul Wall
Q45 Enthusiast
Online
1993 Infiniti Q45 133,000 Miles
Ipswich MA
12-22-2007
Could the 1994+ filters work on the 1990-1993 Q45's?
My Youtube videos
My items for sale on Ebay
1995 Q45 Partout - many parts cheap!!!
1990-1996 Q45 Parts for sale list-Will trade for computer parts!
New Genuine OEM Nissan, Infiniti and Datsun parts cheap.
Restore your active suspension and belt pulley bearings cheap.
Paul
1993 Q45 Green 11/92 Hybrid of 1990 and 1994 Q45, Soon to be Nissan President
Mods done: 1994 auto dimming mirror, 1994 Q45 tweeters, 1994 Q45 trunk net, 1990 Q45 Seat controls and more to come.
qship96
Online
1996 Q45
Timonium,Md
11-24-2002
 « Re: Transmission Flush (Paul Wall)
yes, but if you only have 1 in-radiator tranny cooler, or an aftermarket cooler it is cheaper to purchase an aftermarket tranny filter kit that uses an oil filter element, or easiest is to just purchase a MAGNEFINE tranny filter kit
http://www.magnefine.com
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
The problem with a small filter is it could get clogged and you would never know it until the reduced flow caused the rear planetary to fail..............the reason for the two oem heat exchangers in parallel is to prolong the chance of one clogging [common failurepoint in early designs, also on J30 where there is TSB].
A magnafine might be worse than no filter at all unless you use chemical flushes to dissolve the friction material periodically or change filter BEFORE it causes any restriction?????????? BIF oil/paper type can hold more crud so maybe two in series parallel
Study J30 TSB for RE4R01A.
qship96
Online
1996 Q45
Timonium,Md
11-24-2002
The 94-96Q factory filter is BEFORE the dual in-radiator coolers, helping to keep them clean and unclogged.....I would plumb the magnefine filter the same way......Magnefine filter has a BYPASS valve that opens and prevents restricted atf flow if one would leave it on long enough to clog ......I assume the factory filter on the 94-96Q also does, considering hardly anyone here has ever changed theirs!
maxnix
NICO Supporter
Austin TX
7-22-2002
Quote, originally posted by Q45tech »
The FGY33 has neither of the latter, just the coke can in the bottom of the radiator heat exchanger design (more cost cutting).
The dual heat exchangers on the later G50 do help stabilize the ATF temperature, but on hills, at high speeds, or in hot summers in the south, the owner installed auxilary ATF cooler is beneficial in avoiding ATF temperature spikes into damamging heat ranges.
Seems like an external ATF microfine filter changed annually or more often would work fine.
oldmako
12-3-2007
Has anyone installed a stand alone "spin on" type of filter on the Q41?? There seems to be quite a bit of discussion on the G models but little on the Barbie-Qs.
I did the BG flush / M1 jizz / Lubri-guard routine and installed a cooler. I'd gladly pony up the minimal bucks and time necessary to add a filter. However, I don't want to just toss crap on my ride that might do more harm than good.
As you all know I bought mine at 120K and would like it to go to 220K (at least...there are many guys here who have gotten that longevity out of their cars without major surgery). Since it's used primarily for interstate driving my shift per mile quotient is very low. Or would that be ratio???
miata007
Sacramento CA
8-11-2005
JOHNQ,
A drain and fill replaces maybe 1/4 to 1/3 of the ATF. If I do it again, it simply is going to mix old ATF with new ones.
I bought my car (Y33) with 120K and now is 193K miles. Not sure when ATF got replaced last time so I've decided to replace all. I've used a bottle of lubegard red and don't see any improvement compare to when I got the car 4.5 years ago. I am confident it will make it to 200K and can get lucky (250K).
007
Quote, originally posted by JOHNQ »
JOHNQ
99 QT/00 AE
1-18-2008
 « Re: Transmission Flush (miata007)
if you dont have too major of a problem to begin with then there is little room for improvement. i was answering to the OP.
but if you too want to make your shifting more smootherand did what you stated then try the lucas trans fix and let us know what you think
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
I wouldn't put lucas in the tranny.
tfvesquire
1998 Q45
Chicago IL
12-6-2007
"A drain and fill replaces maybe 1/4 to 1/3 of the ATF. If I do it again, it simply is going to mix old ATF with new ones."
If you disconnect the trans fluid return line from the radiator and do the drain and refill while the car is running by draining the old fluid into a bucket or drain pan and adding fluid until the return line fluid looks new again, then you should get 95%+ of the old fluid out.
As far as my suggestion against doing a flush on a trans with no work history being an urban myth, that is just what it was, a suggestion. I have wrenched on more cars than I can remember and even when I was dealing with my 4th Gen Maxima, it was not recommended to flush a trans with high miles when it had not been flushed before or with unknown history. In fact, there are plenty of reputable places that ask consumers if they know the last time the trans fluid was changed or whether a flush was ever performed just in case the customer's transmission starts having problems or dies shortly after performing a flush.
Now, if the Y33 trans is a better design and doesn't suffer from sludge and/or varnish like other transmissions, then I still suggest doing a flush at your own risk. I do agree that if there is a major problem with the shifting that a flush won't help anything. It would be cheaper in my opinion to simply replace the fluid yourself and save the $100+ trans flush fee.
Good luck.
Ted
miata007
Sacramento CA
8-11-2005
Any reason why lucas is not recommended?
0007
NightRiderQ45
1998 Infiniti Q45
Birmingham AL
4-11-2007
Quote, originally posted by miata007 »
0007
Go to bob is the oil guy and search post from people who actually mix/test the fluid. I saw a test where the oil stabilizer didn't even mix into the actual oil!
Nice Pants, full of bacon and win
LETS GO VANNING
ITS A PARTY IN THE USA
5-5-2003
Keep a bottle of Lucas in the trunk if you have an old transmission. It will "revive" the seals just enough to help you limp home. A friend's Maxima got an extra month of use.
Also good as a temporary fix for leaky ATF.
Quote, originally posted by MinisterofDOOM »
Get out of my gene pool. And take your ES350 with you.
BUY INFINITI PARTS - 1-888-216-5328 | NICO Porn Thread | http://www.q45.org | http://www.vh45de.com
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
 « Re: (Jesda)
Lucas is sold in 55 gallon sizes to 2nd and 3rd tier used car lots where it can make a junker behave long enough to be sold and maybe 30 days thereafter. Beware of most additives that swell seals [after they swell they start to fall apart] but in an emergency on the side of the road anything that gets you home or to a shop.
Paul Wall
Q45 Enthusiast
Online
Ipswich MA
12-22-2007
 « Re: (Q45tech)
So even there power steering seal leak repair product should be avoided?
I wonder if there is a product that they make that is 100% safe to use without any negative side affects such as BG44K.
mattd1979
1990 Pearl White Q45 plain Jane with 162,000 miles. Replaced knock sensors, knock sensor harness, fu
Jacksonville Florida
10-29-2004
 « Re: (Paul Wall)
The input shaft seal on the steering rack went bad on my car. It was leaking so bad that it would dump a quart of oil in 1 minute. It didn't leak that bad at first. I usually would have to top it off once a week. It just happened one day after I had my car detailed and it was just idling there for about 10 minutes. When I got in to drive off, I noticed that there wasn't any power steering. I thought that maybe some of the shine that was put on the engine got on the belts and the pulley was slipping but nope. I popped the cap and it was flat empty. I proceeded to the trunk and got a quart of trans fluid and poured in it and almost as quickly as it went in, it went out. I limped the car over to the closest gas station to get another bottle of fluid and dumped it in, drove to the closest auto parts store and bought 2 bottles of the lucas power steering stop leak and put one bottle in and headed for my brothers house which was about 25 minutes away. Once I got to the house, I checked the fluid and topped off with the other bottle of stop leak and the leak stopped. I was surprised. I didn't expect it to work that good. I pulled a steering rack off of another Q we had at my brothers house and took it back with me to Jacksonville which is a 3 hour drive. That was about 4 months ago. So far the fluid has stayed above the full mark. If things go south, I do have a replacement rack though.
1990 Pearl White Q45 with 162,000 miles(now at 218,000) and the Robert Bowen edition 3 level switchable ECU. Replaced knock sensors, knock sensor harness, fuel injection spider harness, all under plenum hoses and fuel lines. Previous owner had the timing chain and guides replaced at 111,000 miles by dealer. 1st gear start TCU and B&M tranny cooler mounted between condensor and radiator. It is a Work in Progress.
maxnix
NICO Supporter
Austin TX
7-22-2002
 « Re: (Paul Wall)
Quote, originally posted by Paul Wall »
1.) So even there power steering seal leak repair product should be avoided?
2.) I wonder if there is a product that they make that is 100% safe to use without any negative side affects such as BG44K.
1.) Yes, unless you want to clean the components between fluid exchanges. Think about it. Gunk is not good.
2.) BG Power Steering Conditioner or as an alternative, a small amount of MMO if changed annually.
mattd1979
10-29-2004
As far as the fluid exchange. I have my third tranny in my car (The second one lost all but reverse and 1st gear.). The one I have now had around 68,000 miles on it when I installed it. It was the second transmission that was in the car that it came out of. The car had 88,656 miles on it when it was replaced. When I got it, the car at that time had around 156,000 on it. My car had around 210k When I installed this tranny. Anyway, It doesn't appear that the fluid had ever been changed since this tranny was installed in the other car by the dealer. The fluid is almost yellow but it doesn't seem to smell burnt. I am contemplating on if I should do the fluid exchange my self by using the 6 step process or have the Infiniti dealer do the exchange.
maxnix
NICO Supporter
Austin TX
7-22-2002
 « Re: Transmission Flush (mattd1979)
Most dealer's (99%) don't perform a mechanical fluid exchange but merely drain and refilll, ensuring >60% of the contaminated fluid remains, and all the varnish and sludge not in the pan. No dealer I have ever heard drops the pan and replaces the filter, O-ring, gasket and one time use bolts.
If your fluid is yellow, something is terribly wrong. Used transmissions are for those who have to mcuh time and would rather perform repeat labor on their car than enjoy driving it.
mattd1979
10-29-2004
Well, the transmission was available and worked very well and shifted very nicely in the other Q before it was totaled. I was in Zephyrhills and had a 3 hour drive to get back to Jacksonville in 2 days, so I pulled it from the other car and installed it in mine. It has worked nicely since and has given me no problems. I just wanted to do what was right. I just wanted an experts honest opinion on what to do. I am also currently unemployed and am collecting unemployment, so I could not afford to spend $3,000 dollars on a fresh reman from Nissan. I took what I could get. And yes, I guess you could say I do have some free time. I have had this car of mine since November of 2005 and it has gotten me everywhere. There were times when I could have junked it and gotten myself something more economical but I am just attached to it. I guess you could say that it is a part of the family. I couldn't bring myself to do that. Speaking of my family, my Mom has a 1991 Q with 218K and my brother has a 1990 Q with 160K. Of all of the stuff that I have done to this car, I guess you could say that I have stripped it down to the unibody and reassembled it. I know it from the inside out. So I intend to keep it for as long as I can. I continue to learn more about it as I go. Yeah I also enjoy working on it in addition to driving so I fall in that category also. I intended on dropping the pan and changing the screen as I did in the other transmissions that I had in the car (which didn't show any debris in the screens in either one of them and nothing in the pan other then what little bit was on the magnet.). I guess if I have it exchanged at the dealer then I will just have to drop the pan again after they do their thing and replace the screen again. I am using a Magnafine filter on the return line to the transmission. Sorry for the long winded post. I just wanted everyone who reads this to know where I stand. I never did get a response on what would be the best method.
 First  1 2 >  Last
» Return to Q45 Forum / Cima Forum
