xkrisx
91 240sx HB
Lahaina Hawaii
6-30-2006
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 1:01 PM 12/12/2008 |
I am planning on using this. I bought 4 quarts each of prim, paint, clear I haven't painted it yet though, color choice im going with is Jet Black, probably wont be painting it for months though.I am also interested in end results. I've seen a silver one in my searches of pictures, but didn't look like he cleared it edit: heres the link to pictures of the silver one I seen http://forums.nicoclub.com/zer...t-job
xkrisx
91 240sx HB
Lahaina Hawaii
6-30-2006
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 1:41 PM 12/12/2008 |
there is also this video http://videos.streetfire.net/v...5.htm
Salem240
'05 Pathfinder
Greensboro NC
9-1-2008
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 4:22 PM 12/12/2008 |
I was going to use this but I tried a test panel. It layed down good with my HVLP gun but as he says in the vid durability is not good, it scratches really easy
s13gebala
99 maxima , 91 sr hatch
Chicago il
4-15-2008
im considering this paint for engine bay, but maybe after better reviews :]
roadboy240sx
Online
2 many 240ds
The New Hollywood Mi
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 6:27 PM 12/12/2008 |
i dont sugest it #1 you have to remove all the old paint, or primer the whole car (or it will crack) #2 it still will crack no matter what #3 its lacquer not enamel and it will still need about a good solid weeks worth of wet sanding and all the cracks are still visable it did this on the fenders and roof and a huge spot on my passenger door
and what it looks like before wet sanding ( like a matt finish)
 you can some what see the spot under the mirror
 i say you can try but dont expect anything great
"50 maybe pimpin in his escalade but i'll be livin in my whip til im paid" R.A.C.I.N.G: Because Baseball, Soccer, Football, Basketball, Tennis and Golf only require 1 ball. 91 240sx Hatch Drift project 89 240sx coupe daily D 87 300zx headace 01 sable/grandpa gold pimp whip
xkrisx
91 240sx HB
Lahaina Hawaii
6-30-2006
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 7:14 PM 12/12/2008 |
roadboy, did u use any clear?also what type of primer did you use? I was told you need to use their primer or end results wont be that good.
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (xkrisx) | 7:20 PM 12/12/2008 |
i used duplicolor primer, but the rattle can type. and there are 4 coats of clear on that thing and about a week of wet sanding the second pic was before the clear.
assassin7420
1998 Nissan 240sx SE
Savannah GA
8-5-2007
WTF, Did you even prep the car before doing paint?
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: (assassin7420) | 7:43 PM 12/12/2008 |
yes
ReaperBJJ
'95 Sentra '89 240 hatch
Crosby MN
11-26-2007
| « Re: (roadboy240sx) | 9:37 PM 12/12/2008 |
I'm using PPG to do my 240 because I really want to make sure I get a good finish, but also because the paint shop stuff doesn't come in any colors I want to paint it. However I'll probably pick up about a gallon or so to do my dad's truck this coming summer after him and I do some body work.
 1995 Nissan Sentra XE- 35mpg 1.6L shopping cart FTMFW 1989 Nissan 240sx- sitting in my garage since February '08 FTL
mRodiek
Racer X
Stock Hatch
Chicagoan in LA
3-7-2008
| « Re: (ReaperBJJ) | 8:10 AM 12/13/2008 |
http://forums.nicoclub.com/zer...age=1his turned out really well..im just rattle cannin mine flaaaattt black
| Quote, originally posted by mrgreeneyes » | | its for "off road use only" now. cool. good thing i drive on streets and not roads. |
 Shootin for the s***-box look. Daily Drift Build
OutToWinPAHC
240sx Moderator
1991 240sx Hatch with LS6/T56, 1992 F2
Philadelphia PA
5-31-2007
| « Re: Duplicolor Paintshop, Anyone use it? (roadboy240sx) | 10:21 AM 12/13/2008 |
roadboy is that a paint crack or just a bondo crack? looks like body filler.
2002 F-Body LS6, Port / Polished 243 heads with Patriot Racing dual gold springs, Magic Stick V.3 Cam 237/242 .603/.609 114LSA, 1.7:1 Rockers, TR 7.40 Hardened pushrods, LS7 lifters, Ported LS6 oil pump, Comp Cams timing gear / chain, 37# Racetronix injectors, BBK 80MM TB, T56 Spec stage 3More power then a C6 Z06 in a S13.5
BLKTOPS14SR
1995 Nissan Silvia S14 (Usdm),1969 Boss 302, 2008 Yamaha R6
Terre Haute IN
1-18-2006
| « Re: Duplicolor Paintshop, Anyone use it? (OutToWinPAHC) | 10:46 AM 12/13/2008 |
You're not suppose to use rattle can primer with that type of paint. It will turn to crap! Also, anyone that has ever done paint and body work knows that prep is everything! Going cheap using rattle cans will get you cheap results! I've help paint and do body work to alot of cars and the #2 rule is no rattle can paint anywhere! #1 is prep of course.
Salem240
'05 Pathfinder
Greensboro NC
9-1-2008
| « Re: Duplicolor Paintshop, Anyone use it? (BLKTOPS14SR) | 2:37 PM 12/13/2008 |
I had no problem with the quality of the finish on my test panel with Primer/Base/Clear all laid with a HLVP gravity feed and sanding between coats and a final sand and buff on the top coat. The finish looked like glass but even after two weeks the finish would scratch really easy even with a finger nail.....go with urethane PPG, R-M or whatever else you'll have better luck with .
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (OutToWinPAHC) | 2:48 PM 12/13/2008 |
| Quote, originally posted by OutToWinPAHC » | | roadboy is that a paint crack or just a bondo crack? looks like body filler. |
no, the only body work i did was on left rear quater panel, and it turned out just fine.
| Quote, originally posted by BLKTOPS14SR » | | You're not suppose to use rattle can primer with that type of paint. It will turn to crap! Also, anyone that has ever done paint and body work knows that prep is everything! Going cheap using rattle cans will get you cheap results! I've help paint and do body work to alot of cars and the #2 rule is no rattle can paint anywhere! #1 is prep of course. |
oh well live and learn i guess, its not to bad of a finish
burntricer
90 S13 SR20DET Redtop
Thunder Bay ON
1-2-2007
| « Re: Duplicolor Paintshop, Anyone use it? (roadboy240sx) | 4:07 PM 12/13/2008 |
if you go all out on prep you will have a good finish. its your primer that determines your finish.
BLKTOPS14SR
Terre Haute IN
1-18-2006
| « Re: Duplicolor Paintshop, Anyone use it? (burntricer) | 4:49 PM 12/13/2008 |
Roadboy, Nah man not bad man. Especially cause you did it youself! At least you tried it. Kinda hotrodish. Burntricer, exactly!
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (BLKTOPS14SR) | 11:21 PM 12/13/2008 |
| Quote, originally posted by BLKTOPS14SR » | | Roadboy, Nah man not bad man. Especially cause you did it youself! At least you tried it. Kinda hotrodish. Burntricer, exactly! |
i dont like the red on it that much at all, its gonna be satin black as soon as the weather warms up, but ya it was my frist time painting a car, so i think it turned out pretty good. it served its purpose of being a decent, quick, cheap, paint job for a car show
s14tan
95 ZenKi SE w/ S14 SR GT28r and bolt ons
Dallas Tx
6-17-2007
| « Re: Duplicolor Paintshop, Anyone use it? (roadboy240sx) | 11:43 AM 12/14/2008 |
How much did you spend total?Primer, Color, Clear.
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (s14tan) | 2:00 PM 12/14/2008 |
| Quote, originally posted by s14tan » | | How much did you spend total? Primer, Color, Clear. |
around $150-$200 4-black 4-red 4-clear
J0SHYee
91' 240sx fastback
Hercules Ca
4-13-2008
| « Re: Duplicolor Paintshop, Anyone use it? (roadboy240sx) | 2:54 PM 12/14/2008 |
| Quote, originally posted by roadboy240sx » | | i dont sugest it #1 you have to remove all the old paint, or primer the whole car (or it will crack)
Well duh you always has to prep the body before any paint job
roadboy240sx
Online
2 many 240ds
3-30-2008
| « Re: Duplicolor Paintshop, Anyone use it? (J0SHYee) | 2:57 PM 12/14/2008 |
| Quote, originally posted by J0SHYee » | Well duh you always has to prep the body before any paint job |
i know, i typed before i thought
