nissandrftr88
6 240'S, 2 rx7's, 80 z28
montgomery alabama
3-5-2007
| « Re: NICO's Fastest: Top Drag Racing Times (cnichols) | 11:58 PM 11/23/2008 |
RB25 s14,80 shot,stock motor .05 r/t 1.801 60' 7.446 1/8 @100 mph 11.44 1/4 @ 124
 s13 rb20det,57trim,444cc injectors,tune 11.8 @ 114 in 1/4 @ 2:40 http://video.google.com/videop...hl=en
cnichols
96 Nissan 240SX, 99 Infiniti Q45, 93 Ford Fastiva
Balling Green KY
8-6-2002
Do you currently own both cars?
nissandrftr88
montgomery alabama
3-5-2007
| « Re: (cnichols) | 4:30 PM 11/24/2008 |
| Quote, originally posted by cnichols » | | Do you currently own both cars? |
Yes i do!
cnichols
Balling Green KY
8-6-2002
Awesome!Do you have more detail on the S13's pass? Need it out to at least two decimals and an 1/8th mile time. Copy of the time slip would help.
nissandrftr88
montgomery alabama
3-5-2007
| « Re: (cnichols) | 2:31 PM 11/25/2008 |
11.802 @ 114.401.82 60' RB20det/57trim/pump gas
audtatious
Nom Nom Nom
2008 G37s Coupe - 2007 G35s Sedan
Jeff/Louisville
10-27-2002
| « Re: NICO's Fastest: Top Drag Racing Times (cnichols) | 7:08 PM 11/25/2008 |
No G37's yet?Then I be first  13.835 @ 101.89 IB slow compared to U guys.....
kzoosho
Turboed 1997 Nissan Maxima SE
Grand Rapids michigan
12-26-2007
| « Re: NICO's Fastest: Top Drag Racing Times (audtatious) | 8:38 PM 11/25/2008 |
Um my best so far is a 12.5@113 but i cant find the slip. I do have a slip for my 12.9@106 run. This is a 97 Nissan Maxima.
Modified by kzoosho at 12:38 PM 11/26/2008
1997 Maxima Holset hx52| Built 3.56| 6sp | 2 stage N2O| More to come 1991 Maxima low and slow 1997 Maxima Level Ten transmission | more to come 1996 Honda Accord ( I know, Its a Honda)
audtatious
Nom Nom Nom
Jeff/Louisville
10-27-2002
| « Re: NICO's Fastest: Top Drag Racing Times (kzoosho) | 10:29 PM 11/25/2008 |
Sweet. I love turbo Maximas
RED_DET
Super Moderator
2004 6 speed G35 Sedan, 2002 Sentra SE-R Spec V, 1992 Nissan Sentra SE-R SR20DET
Louisville, KY
5-13-2003
b13 sentra/U12 motor/GTiR T28 and slipping clutch12.3@111mph with 1.7 60' video is of a 12.3 pass @ 110mph same day. http://www.streetelite.net/vids/Nismo_B13.mpg
 Factory Service Manuals can be found here
Presscott707
1999 Maxima 5spd 1999 QX4
Brunswick Maine
1-15-2006
| « Re: (RED_DET) | 10:23 AM 11/26/2008 |
I'm the slowest guy here but its ok.14.793 at 93mph 60ft 2.352 R.T. .508 all motor 99 maxima
1999 Maxima 5spd tein coilovers centerforce duel friction clutch fadenza flywheel Stillen ram intake cattmen header y pipe and cat back with e-bay high flow cat. EDIT: Max sig image size is 600x200. Thanks R.I.P Dhione Loyola Watkins
kzoosho
12-26-2007
| « Re: (RED_DET) | 4:07 PM 11/28/2008 |
I added my 12.9 slip. I cant find my 12.5 so o well. ill be faster this year.
Team kaotik
300zxtt X 3,300zx NA X 1, 240sx X 2, mr2 x 1
augusta ga
12-5-2008
| « Re: NICO's Fastest: Top Drag Racing Times (nissandrftr88) | 6:09 PM 12/10/2008 |
what tires and rim combo R you running and what WHP/Tq range are you in I cant hook at all
-Dual intake -550cc deatchwerks injectors --EGR REMOVAL/0 EMISSIONS -CUSTOM EXHAUST/DIVORCED DOWN PIPES -stage3 6 puck, AMS radiator and pulley set -God speed intercoolers -UPGRADED GARRETT TURBOS -2+2 CONVERSION/WEIGHT R
mexicanracer03
95 S15FRONTEND SR20DET and 97 2JZ T78
Kill Devil Hills Nc
11-9-2006
| « Re: NICO's Fastest: Top Drag Racing Times (cnichols) | 3:09 PM 1/11/2009 |
do you have a clip of your run at the strip ??? I tried one link you put up but It didn't work.
cnichols
Balling Green KY
8-6-2002
http://www.youtube.com/user/streetelite240
Imissmyturbo
Car's, Turbo's, sking
Lancaster PA
1-3-2003
| « Re: (cnichols) | 8:41 AM 3/17/2009 |
92 Hatch with a 2jz pt67 turbo R-154 trans @ 15 psi made 442 whphttp://www.youtube.com/watch?v=ICV9dDNefPU I have run a 12.1 @ 121 but this video was @ 120. I have since put 1000cc injectors and running e85 once I get it running well @ 1 bar I plan to up the boost till I run out of fuel. My 60ft time was 2.0 on that run
Modified by Imissmyturbo at 9:22 PM 3/18/2009
92 240sx 2jz swap PT67 turbo
cnichols
Balling Green KY
8-6-2002
Nice run! I'd probably go 2J if I was building a drag car. Which tranny are you running?
Imissmyturbo
Lancaster PA
1-3-2003
| « Re: (cnichols) | 11:04 AM 3/23/2009 |
R154 from an MKIII turbo supra I am using a 1jz bellhousing to bolt it up to the 2jz. It's a 5 speed.
HxC_Nismo
Original? Creative? Eh.
98' Nissan 240sx SE R33 RB26DETT
Columbia MO
9-23-2006
| « Re: (jmac39) | 8:02 PM 4/14/2009 |
my last pass with my stock turbos 16psi 360rwhp 12.21 et @ 112mph 1.82 60fti now have alot more power and a couple of chassis mods and im going to try to make it to import face-off at kcir drag strip in kansas city, mo on may 3rd. im shooting for low 11's high 10's
 -Hans- 98' 240sx SE R33 RB26DET-Under Construction 02' Sentra SE-R- Daily Driver
nissandrftr88
montgomery alabama
3-5-2007
| « Re: (HxC_Nismo) | 1:01 AM 4/17/2009 |
12.5 @ 122 rb20det/pump gas/street tires
jc0526
houston tx
2-11-2008
| « Re: (nissandrftr88) | 10:04 PM 7/9/2009 |
'74 260z1/4 jc0526 - 11.898 @ 115.11 - 60' - 1.833 260z with L28et http://www.youtube.com/watch?v=bbEvoeOVUqY Right lane
cnichols
Balling Green KY
8-6-2002
| « Re: (nissandrftr88) | 4:35 PM 7/28/2009 |
| Quote, originally posted by nissandrftr88 » | | 12.5 @ 122 rb20det/pump gas/street tires |
Need timeslip or video, etc.
Jime
5-20-2004
1995 Maxima 3.5 swap. 200 shot nitrous.10.85 @ 125.55 Video and timeslip on my homepage. http://www.jimesmaxima.com
Mastaflash
cars
Cincinnati OHIO
11-29-2003
my 11.8 at 124.75 2.0 60ft. in my s13 240sx. 20psi gt3582r, et streets, pump gas. it has more in it. this was the first run of the year and i have some bugs to work out. it had a fuel starvation issue on the launch.
MrLith
Nissan Skyline R33 GTS25t
Porirua Wellington
8-19-2009
Here's my best run so far from my R33 GTS25t, stock block running GT3076R and 14psi at the time with niggly boost and ignition issues - hope to finally have some clean runs this season (starts in NZ soon):12.82 @ 110mph: http://www.dragtimes.com/Nissa....html
Mastaflash
cars
Cincinnati OHIO
11-29-2003
same setup as last time.
60 - 1.733 330 - 4.968 1/8 - 7.482 mph - 98.71 1000 - 9.595 1/4 - 11.385 mph - 125.59
