94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 9:07 AM 10/30/2008 |
I'll be damned. Yes, they do look identical. Nice find!! Q45 e-brake from FSM
 Z32 e-brake
TerminalVelocity
1995 Zenki S14
Las Vegas Nv
2-4-2007
hot dang! nice job
1unar3clipse
93 240sx HB, 01 Dodge Dakota SLT
Santa Susana Field Lab. CA
11-23-2006
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 3:19 PM 10/30/2008 |
Awesome find!gotta remember this one come this weekend
| Quote, originally posted by srellim234 » | What people do in their own homes is their business. It only becomes a public issue when they bring "under the influence" into the public domain. |
Rest in Peace 480sx
jdm_master_X
"Hard Gay"
92 Nissan 180SX LHD!...LaWL
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (1unar3clipse) | 3:49 PM 10/30/2008 |
good news!I went to the junkyard and swapped the Z32 TT knuckle onto the Q45 and vice versa. IT IS A DIRECT BOLT ON : drum brake, rotor, aluminum upright, etc. BOTH ARE EXACTLY the same! rotor diameter is identical as well. fighting the good fight! thanks for the heads up, boys!
1unar3clipse
11-23-2006
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 5:10 PM 10/30/2008 |
You just lowered the price of z32 rear e-brakes I am so emptying my local junkyard this weekend, they have HEAPS of Q's
jdm_master_X
"Hard Gay"
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (1unar3clipse) | 6:34 PM 10/30/2008 |
haha same here. but why would anybody abuse the Q45? their such great cars...
1unar3clipse
11-23-2006
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 8:02 PM 10/30/2008 |
You'd be surprised. The junkyards I frequent have copious amounts of Q45's... through out the years also. Its kinda sad yeah but I almost adopted one because it was literally a $50 barely running car, but I really don't have the time or funds to put into one right now.I suggested it to my GF but the response was
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (1unar3clipse) | 6:41 AM 10/31/2008 |
I wonder how anchor bolts look like on Q45's e-brake. z32 has 2 different types of anchor bolts. Thin one and thick one. Thick one that is held by small bolt that has star shaped head is what you want.
adrians_s13
Supporting Member
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 11:22 AM 10/31/2008 |
sweet!
jdm_master_X
"Hard Gay"
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (94_240sx) | 12:08 PM 10/31/2008 |
The Z32 brakes that I got were from a 91 with that huge 27mm for the drum anchor. The Q45 shares the same setup (G50 vs Z32 is what the comparison is based on). I have yet to see the torx bolt style anchor that you spoke of. In this case I'm not worried since I just opted to run the entire aluminum knuckle.
94_240sx
'Vert Encyclopedia
94_240SX
DFW TX
2-28-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 1:49 PM 10/31/2008 |
| Quote, originally posted by jdm_master_X » | | The Z32 brakes that I got were from a 91 with that huge 27mm for the drum anchor. The Q45 shares the same setup (G50 vs Z32 is what the comparison is based on). I have yet to see the torx bolt style anchor that you spoke of. In this case I'm not worried since I just opted to run the entire aluminum knuckle. |
I'm talking about these. You need one on the right side(thick one) with stock s13 and s14 hub. You can use the other one, but you need z32 hub with a spacer on top to fill the gap. Or you can cut the spacer out and weld it to the anchor bolt on the left(thin one).
 You see the hub on the right side? That one is meant to be used with anchor bolt on the left side(thin one). We don't have that extra spacer on s13 and s14 hubs.
jdm_master_X
"Hard Gay"
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (94_240sx) | 3:24 PM 10/31/2008 |
Of course. It's just that most of the Q45s that I've tested so far, I haven't encountered the torx bolt on the anchor. I'll keep looking through the Qs I work on and let you know if the Q has such a deal.
supreamS14
96 240sx S13-blacktop Sr20deT
pinellas park florida
1-4-2007
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 5:03 PM 1/19/2009 |
| Quote, originally posted by jdm_master_X » | | Obviously we already know Z32 TT and Q45 also utilize the same axle spline pattern and share the same hubs. |
Will this work for my 26mm z32 n/a brake swap? I thought the tt z32 rear brake parts wasn't usable for us 240sxers.
jdm_master_X
"Hard Gay"
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (supreamS14) | 6:21 PM 1/19/2009 |
| Quote, originally posted by supreamS14 » | Will this work for my 26mm z32 n/a brake swap? I thought the tt z32 rear brake parts wasn't usable for us 240sxers. |
the differences between the NA and TT/Q45 e-brake hardware lie within the hub. The S13/S14/S15/Z32 NA have a 29 spline hub while the Z32TT/Q45 use a 30 spline hub. Otherwise they are the same. As 94_240sx had explained above, the other difference would be the spring anchor for the drum brake assembly. As you can see from the photo above, there are two variations of the anchor (one with a torx bolt and one without). Ideally, if you plan on keeping the 4-lug hubs in the rear, the torx style anchor is what you would want since S chassis hubs lack the proper spacer for the anchor. Either switch to the NA Z32 rear 5 lug hubs or run a spacer behind the non-torx anchor. Searching the forum, you should find the proper size washer involved in doing that.
supreamS14
1-4-2007
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (jdm_master_X) | 9:57 AM 1/20/2009 |
I'm going 5 lug so I need the z32 na 5 lug hub. correct? My z32 na spindle/hub don't have the rear drum/ebreak Assembly so I will have to take off the hub and switch the z32 na spindle for the q45 spindle that has the rear ebrake assembly. Thanks.
jdm_master_X
"Hard Gay"
Yay Area CA
7-23-2005
| « Re: Z32 parking brake hardware identical to Q45? GOOD INFO HERE! (supreamS14) | 10:30 AM 1/20/2009 |
| Quote, originally posted by supreamS14 » | | I'm going 5 lug so I need the z32 na 5 lug hub. correct? My z32 na spindle/hub don't have the rear drum/ebreak Assembly so I will have to take off the hub and switch the z32 na spindle for the q45 spindle that has the rear ebrake assembly. Thanks. |
you can still use the z32 NA hubs because it does have the necessary spacer for the smaller, non-torx style anchor. if you switch to the TT or Q45 hub, you would need to have the axles/diff that share the same 30 spline axle pattern vs the 29 spline S-chassis/NA/Infiniti J30 axle pattern.
