 Finger chopper be gone! (Electric fan install)
karism
1992 Nissan 200sx. CA18DET
Pretoria
4-22-2008
Halo Everybody.
So i got tired of the viscous fan sound when driving.Decided to put on a nice electric fan.
I bought the fan,and ordered the controler.
Finished up the install last night.
Specs : 14" Fan
Electronic fan controler,with water & oil temp display,and variable fan on and off setting.
Enginebay space after the fan is installed
Temp probe installed into thermostat housing
Fan temp controler showing water temp
Finger chopper where its supposed to be,on the ground where the dog can chew it
Karis
1992 200Sx.Maroon.Safari T25 Turbo.Custom Exhaust.17"wheels.>>Datsun!
1974 Vw Beetle.13B Rotary.Allmost everything Custom made >>Beetor
2004 Opel Corsa Utility.1700 Diesel. 50mpg!! >>
http://www.myspace.com/darkrotor >>Have a look at my cars ?
ThuG LyFe
95 S14
NY NY
2-18-2007
lucky i wish i could do this...
zenki love
gone but NEVER forgotten
Ghost_silvia
1991 nissan silvia s13
Hutto tx
5-18-2005
 « Re: (ThuG LyFe)
How much did the whole setup run you? I need a thermo probe and temp sensor, cause I turn the fans on manually Also where are the parts from and is the oil temp actually hooked up to tell temp?
MIDNIGHT-MILITIA (DRIFT SQUAD)
JOIN* Special Forces or Fall to our Wrath!
Co-worker Qoute "Why do you call him dik-do"? Cause his stomach sticks out farther than his dik-do"
karism
Pretoria
4-22-2008
The whole setup ran me R1000.I sourced it locally here in RSA
Only the water temp is hooked up at the moment.The next step will be to wire on the oil temp sensor.
Stay tuned,i`ll come tell you guys about it
sloweighty
sileighty
Sacramento CA
11-20-2007
 « Re: (karism)
where did you get that efan controller?
kornmanz
NICO's DJ - Mixmaster Kornmanz
89 240sx Hatch
Santa Fe NM
9-26-2007
 « Re: (sloweighty)
guys I can take a few pics of my setup if you wish but it is by far the easiest and cheapest way to do it.
get a 12 inch fan (35 bucks at autozone) and wire it into your fuel pump fuse. This way when you turn the key the fan turns on. Its always on but its ok, keeps the car running perfect.
My "build" thread
http://forums.nicoclub.com/zer...nally
http://www.soundcloud.com/djz
http://www.myspace.com/kornmanz
AZ89two4Tsx
Sparkles like a Twilight Vampire
of turtletastic gold.
Scottsdale fail AZ
3-8-2008
So how much did it cost?
Click here if you like turtles
Ilvemynissan
240sx s13
spanaway WA
7-22-2007
 « Re: (AZ89two4Tsx)
$R1000?
I say it if you're skinny, I say it if you're thick, I just washed it, don't scratch the whip!
EnjoiNismo
93' sr20_240sx coupe
Tucson AZ
7-24-2007
 « Re: (AZ89two4Tsx)
Quote, originally posted by AZ89two4Tsx »
sputnik
indio CA
9-9-2007
 « Re: (Ilvemynissan)
I only have R500
ddgsxr504
Thread Jacker
1995 Nissan 240SX SE 2009 Nissan Altima SL
Oceanside CA
1-8-2005
 « Re: (sputnik)
Quote, originally posted by sputnik »
I only have R500
Ditto what kind of Fan Controller is that and where/how much was it?
TimTurboZ
The Muffin Man
96' 300zx TT, 90' 240sx Coupe, 87' Supra N/A, 65' Mustang GT
Sacramento CA
10-6-2008
 « Re: Finger chopper be gone! (karism)
Guys I belive the cost of this set up is clear
"The whole setup ran me R1000"
Never heard of an "R" denominational bill. The ratio of "R100" to a US Dollar is rougly the same as the ratio of unicorns to leprechauns.
Yeah I tried hooking an E-Fan to one of my cars this past weekend didn't run a relay (big mistake!!!) I guess like "kornmanz" did running power to the fuel pump fuse essentially ran it off of the fuel pump relay thus not running to high of an amp to any wires and frying them like I did.
I hope he responds and really lets you know how much this set-up cost!
96' 300ZX TT 5spd (Jade) 90' 240sx Coupe 5spd (Kenji: The Ducket Snatcher)
87' Toyota Supra NA 5spd (Doesn't deserve a name) 65' Mustang GT Coupe Auto (Linda)
~Flowmeisten~
TimTurboZ
The Muffin Man
Sacramento CA
10-6-2008
 « Re: Finger chopper be gone! (TimTurboZ)
Did a little searchin from his myspace he's from south africa
1 US Dollar = 9.39761 South African Rand
1 South African Rand (ZAR) = 0.10641 US Dollar (USD)
1000/9.4= roughly $106
Ta-Dah!!! 2 min of research and you can stop scratching your heads!
Welcome!
Ghost_silvia
Hutto tx
5-18-2005
I liked the unicorns to leprechauns ratio better
Does that fancy search thingy majiggy tell you what brand its?
karism
Pretoria
4-22-2008
I leave for 5 minutes and it turns into this?hahaha
Let me provide a link to the Fan controler,it is made by autogauge :
http://www.autostyle.co.za/pro...6&str=
The fan controler consisted of the following :
1x fan controler
1x wired 30amp relay
2xtemp probes with long enough wires,and clips
1x double sided tape for fixing the controler
3 x cable tie for the wires
Cable tie = Tie strap/ Honda clamp/whatever it is called in your neck of the woods.haha
I will not run a single 12" on a turbo charged engine.It will not keep the temp low enough if running off a switch,and not constantly
The 14" fan fits the core perfectly like it was made for it
Karis
redclaw05
1993 s13 caged vert
CARROLLTON Texas
6-10-2006
clutch fan + shroud > *
RIP JORGE LOPEZ "DRIFT PURPLE"
karism
Pretoria
4-22-2008
 « Re: (redclaw05)
Quote, originally posted by redclaw05 »
Each to their own i guess!
I hate that the fact that it makes it sound like pickup with the viscous.
Crap!I cant believe i spelt controller wrong the whole time haha.
Unstock240
89 240sx se
7-9-2008
I heard doing this can around 10-15 horses from less strain on the engine, did you notice any gain?
B-Metts
92 240sx hatch, 91 C1500 pick up, 92 hardbody
lake mary Florida
1-18-2007
 « Re: Finger chopper be gone! (Unstock240)
Quote, originally posted by Unstock240 »
i dunno about that much, but i know e-fans do free up horses. i was wondering the same, i'm about to put some electronics on my truck...
dtowndrifter
s-14 kouki
dallas TX
10-19-2005
looks good...i dont think one fan cuts it here in Texas..
7anshin8r
Online
96 Nissan 240sx
Gainesville FL
3-10-2007
 « Re: (dtowndrifter)
Quote, originally posted by dtowndrifter »
That is what I was wondering about the hot Florida summers.
Zenki clear covers, how's your visibility?
WTB: 4-lug's, LSD & clear covers, mail me if you can help.
Short on $$$ but rich in life!
ZX88
s13
north nj
9-8-2007
 « Re: (7anshin8r)
clutch fan > electrics
Revolution Motorsports: http://profile.myspace.com/ind...42327
My car: http://forums.nicoclub.com/zer...age=1
SHRIMP SLUSHIES ALL AROUND!
ddgsxr504
Thread Jacker
Oceanside CA
1-8-2005
 « Re: (ZX88)
Quote, originally posted by ZX88 »
Uhhh.... no. Please explain your thought process on this.
mrgreeneyes
Built Coupe
Lancaster PA
1-11-2006
 « Re: (ddgsxr504)
no wiring, no failing, etc.
i plan to run a combo of the two when i boost the car... single high cfm e'fan on the rad, then a clutchfan behind it... keep that SOB ice cold
THE BUILD
THE BLOG
Quote, originally posted by MMaxeyJR »
I will need your Moses abilities
Quote, originally posted by blacksrjdm »
If we cant install an intake, then we shouldnt be modding our car.
Quote, originally posted by JustDriftMore »
yea its MGE he knows
ahhh input from the lancaster kedz, it adds flavor to these threads i.e. reason why im on 240sx.org at 2:48 am
s13gebala
99 maxima , 91 sr hatch
Chicago il
4-15-2008
you have any pictures of how its like in south africa ?
would be nice to see :]
karism
Pretoria
4-22-2008
 « Re: (7anshin8r)
Quote, originally posted by 7anshin8r »
We were running 97 here yesterday ,and we are still in spring..... It held up fine to the temperature,even sitting in traffic for a few min.
I read up on the specs of the fan,and it looks like a 14" straight blade fan flows 1000 CFM.
>> According to heat dynamics ,a radiator only needs postive airflow of 30% of the core size,to cool the water sufficiently. << Now my fan covers 100 % of the radiator in the height ,and more than 60 % in the width.
Hence working fine!
One fact that is more important for airflow ,is how well the radiator is sealed off,and able to utilise the air porvided.Air leaking around the side and top/bottom decreases the capacity of the air cooling the core.
This is one of the reasons that the Rad fan (when not using a factory shroud),should allways be the same size,and not larger than the core.The edge of the fan blades that are not over the core,will pull the air around the core,and not through it
Practical example : If i fitted a 16" fan ,the would have been overhang of 1" per side of the fan.the specs of the fan says that it flows 2000 cfm.Now the 1" of the blade that protudes,is allso the most curved part of the blade,that generates the most flow.The curved part now disrupts the flow (not flowing through the core) ,and flows less than the given CFM.This sometimes knocks of 100s of CFM,not just 5 or 10
Fan placement ,fan shrouds , clean core and correctly working thermostat is much more important than the size of the fan in the end.
Ok,my fingers are going to fall off now...
Karis
karism
Pretoria
4-22-2008
 « Re: (s13gebala)
Quote, originally posted by s13gebala »
I have some photos of camping trips?and some of the seaside.
Would that do?
mattblancarte
1989 240sx Coupe
Seattle WA
6-21-2008
 « Re: (karism)
i wish i had room for a pull-fan in my engine bay have two 12" spal push fans though
1989 240SX RB26DETT
karism
Pretoria
4-22-2008
 « Re: (mattblancarte)
Good thing you are using SPAL fans.They are one of the best,if not the best on the market.I will be using SPAL fans on my beetle when it runs
