Word up to you guys, i emailed autoluminations, asking if its bad to turn down the dimmer switch with LED's (it says they are safe from 9v-15v) and this is their reply:
autoluminations wrote: It is a good idea to set your dimmer to about 80% with your gauge lights. It will help the LED bulbs last longer.
I thought they were supposed to have ridiculous longevity?
bmlawless wrote:It's interesting that the "red line" on the tachometer looks like it has basically disappeared with the new bulbs.
I'm still lost on which replacement bulbs you use and whether or not you have to do anything with the bases. What parts did you use for your mod?
Wow i didnt notice that... ill take a look tonight to see if that really is the case.
i just bought the bulbs and used the stock nissan bulb bases (which are actually made by toshiba) the only problem is it can be tricky to pull out the nissan bulbs. You might want to just spend the extra 0.29 each for some bases, it will save you several minutes of pulling and wiggling the bulbs.
