I have decided to try to get rid of my ongoing project. I am moving soon and everything has to go. I would like to see if someone would want everything together first if no i will sell seperate. 91 nissan 240sx. odometer says 200k, it has had a newer ka motor installed supposedly from a 95, approx 160k miles. Motor runs strong. It has an underdrive pulley, intake, header. The body, seibon carbon fiber hood, silvia front, the headlights were broken and i had plastic welded them but there not perfect, the bumper could use some adjustment. The pass fender needs to be replaced or repaired, where the sidemarker goes in the metal was twisted but the marker doesnt fit properly. Interior, i was going to rhino-line the floor so i pulled the carpet, dash is perfect, drivers doorpanel has a tear at the top center, seats are usual.
The frame rails are not rusted out small dents though, there is no rust underneath that i have seen and i have checked.
RB20DET. MOTOR IS COMPLETE. i had replaced oil pump, waterpump, nismo thermostat (new oe included too), greddy timing belt, new tensioner and idler pulleys.. Not yet installed, new oil pan, rear main seal, new crank pulley bolt, nismo clutch pivot ball, magnetic oil drain plug w/ 5 crush washers, Mckinney motor mounts.. Also included, ecu, complete wiring harness, lower harness, r32 rear end, j30 rear end, maf , ignitor, stock turbo very little shaft play, flywheel needs resurfced, 3" catback exh., side mount intercooler, There may be a few other small things but that pretty much covers whats all there.
I was asking 5k obo for everything listed and a few other parts i have laying around. I can deliver everything if need be for up to a reasonable distance. i will have pics up as soon as i can, if i cannot i will be able to email them.
Thank you, Make offers if my price is unreasonable.
2/08 - NRRBA - Where do i sign up
