 TN: 1990 300ZX Twin Turbo - Stage 7+ - All Show & Go - Must See
BCs300z
90 300zx TT
clarksville TN
2-21-2007
**FULLY REVISED TO MEET FORUM GUIDELINES**
The time has finally come for me to say goodbye to my Z...BCs300z...and move on.
As much as I love this car, I can't bear to see it spend another year plus, soley as a garage queen.
Too many military deployments and other family responsibilities have paved the way for me to part with the Z. Perhaps in another few years when things calm down...I can get back into the Z scene again.
Buy it now price is $15.5K. Please see the last link in this ad for auction details.
- After nearly 8 years of ownership, I have reached a point where it is just simply time to move on. Between having 3 children and being deployed multiple times in the call of duty, I just have no more time for the Z. It has unfortunately become completely impractical to hold on to.
- Don't let the mileage fool you, this Z has been the "Poster Child" for Garage Queens everywhere. I bought this Z with 192K on it, and in 8 years have only put 26K on it. About 10K of that was put on in the first 2 years of owning it. Another 13-14K was accrued on the Autobahns in Germany and Belgium during the 3 years I spent there. And the remaining 2-3K has been in the last 2 1/2 years going to different events and meetings.
- This Z car is the product of my imagination and determination. Meticulous attention has been paid to every little detail surrounding this car. Some may call it a form of therapy...but this Z has been carefully and patently pieced together with nothing more than perfection in mind.
- About 3 years ago, I hired a friend to paint the car. He stripped it down, smoothed out any dings necessary, primed and prepped the car...then left. And abandoned the project. Since that time, I moved back to the US from Europe, and been sent to war. Time and priority have not been on the side of finalizing the paint job. Hence the primer black that it is in now. I could very easily just take it down the street to MAACO for a cheap coat before listing...but I would not do that to this car. Besides, it has been holding it's own regardless.
- The engine was just built last year...from the ground, up! Not because the car needed it...but because I did. To feed the addiction, I built another engine.
Performance:
GD SS Super Split Down Pipes (gen 2)
GD Resonated Midpipes
GReddy SP Catback Exhaust
Dual Intake (POP) System
AshSpec ECU
Stillen SMICs
UR UnderDrive Pulley
AMS Water pump pulley
Twin Garrett GT28R BB Turbos w/ HKS Wastegates
HKS EVC 5 (PSI spec) Boost controller
NISMO 555cc Injectors
JWT Heavy Duty cam spring set
RPS Max Street Clutch
Z1 Motorsports Platinum DriveShaft
European spec TT Rear Differential w/ cooler and associated equip.
Apexi BOV's
Stillen Oil Cooler
Z1 chrome Lower Radiator pipe
Z1 Chrome Hard Pipe Kit
AMS Radiator
300* EGR Delete Kit
SS Braided turbo oil feed lines
- You may have recently seen this car at the Z Nationals 08, and Z Attack08. If so, you would know first hand that this Z is a brightly shining diamond in the rough.
On The Outside:
Nismo '99 JDM Front Fascia
Stillen Type III Side Skirts
Stillen GTZ Rear Valance
- Nearly every part to this car...minus the chassis itself...has been replaced with younger, low mileage pieces. No expense has been spared to bring this car back to near infant state. From T-Top metal and trim, to lower control arm bushings, this Z looks more like a 10K old car.
Wheels, Tires and Suspension:
TSW Mondello's (18x9 w/ 20mm offset)
Dunlop SP Sport Maxx (front) (255/35-18)
Yokohama ADVAN S4 (rear) (255/35-18)
Z1 Motorsports 13" Front Big Brake Kit
Brembo Cross-drilled & slotted Rotors in the rear
KYB AGX shocks
Eibach springs
300* front Camber correction kit
Suspension Techniques Sway bars (front and rear)
PowerTrix Adjustable front tension rods
PowerTrix HICAS Eliminator Bar
ES poly bushings:
- differential carrier
- ALL front and rear links
- steering rack
Greg Dupree Subframe Spacers
Greddy/Trust Front and Rear strut tower bars
- I have also installed things on this Z that can't even be found on US Z32's. One such example is the addition of a Rear Differential Cooler System, found on Euro Spec Z's to combat high, AutoBahn speeds.
- About 4 years ago, I decided to install a Car-Puter into the Z. Fully integrated into the consult port and the car's sound system, this computer provides the driver with a phenominal driving experience and keeps them completely in tune with the engine. All consult interface programs are being left installed, as well as the WiFi capabilities.
Creature Features:
GReddy Turbo Timer
GReddy Boost gauge
Autometer Oil pressure gauge
Autometer Water temp gauge
Autometer Differential Temp gauge – With Diff Cooler activation switch
Short-throw shifter
Sights and Sounds:
Pioneer DEH-P8650MP (WMA/MP3/CD) Head-unit
Infinity 5 Ό” components – Front lower
1 ½” Tweeters – Front door (upper)
Kenwood 2” Tweeter – Rear hatch (upper)
Kenwood 6 ½” Woofer – Rear
JBL 10” Sub-Woofers (2) – Rear custom boxes
Kenwood KAC-959, 800W Amp – Driving Woofers and Sub-Woofers
Fully Integrated Car-Puter consisting of:
- Pentium 4, 2.8GHz, 504Mb RAM
- 120Gb HDD
- Lilliput 7” touch-screen, VGA monitor
- Sony 5” Display monitor
- USB2 DVD Drive
- WiFi enabled
- Nissan DataScan / Consult cable installed
- Conzult (free) and Ztalk also installed
- This summer I planned to swap out the transmission, rear diff, axles, and subframe. I planned to do so, to simply cut down more age on the car, and strengthen the drivetrain. I am changing out the TT subframe with an NA subframe, to be able to install rear connecting rods...in leu of the HICAS Elimination. Again...this is all just for personal preference. The current transmission does have a small grind getting into 4th (when done so quickly), and is the reason for it's replacement. I planned to then rebuild the old tranny. However, I have been again called away and cannot perform the swaps. But because I have no use for all the items that I have obtained for the change-out...they are being included with the car.
Extras include in auction:
• 5-speed tranny (42k miles) - USDM
• Rear Diff and Axles (28k miles) - JDM
• NA Subframe (60k miles) - USDM<
- The car has absolutely no body damaging rust what-so-ever. It has been garage kept for the entire time its been with me. An extremely minute amount of surface rust has developed in the hatch area just above the tail lights, where the primer is thin on the edge of the metal. This is easily removed with a wire brush. It is normal and absolutely nothing of concern and only lingers due to the primered state.
Please visit my Photo Album for more pictures of this car. OVER 65 PICS IN ALL!http://webpages.charter.net/carderbw/ForSale.html
- Payment Options: Paypal or Cash in Person. Other payment options may be available, but only on a case by case basis. No personal checks, money orders, or cashiers checks will be accepted.
- Shipping: Shipping will be at buyers expense. In Person pick-up is also accepted. In the event that car is to be shipped, I do know a couple carriers in the area that I can recomend and assist in arranging.
- If you have any questions... PLEASE don't hesitate to let me know. I am more than willing to answer any questions and will post Q&A on this listing for others to see.
Thanks for viewing my auction. I truly hope that you are the one that can give this Z a good home and a driver that can stretch her legs often...instead of living out her days as a Garage Queen.
More Information and Pictures Available Herehttp://cgi.ebay.com/ebaymotors...ZWDVW
Modified by BCs300z at 10:19 AM 9/6/2008
Modified by BCs300z at 6:07 PM 9/6/2008
LaterZ
...tearin' up the Dragon!
Rex
Super Moderator
Online
1995 SC400 Red/Black 1993 Maxima Black/Tan
Cincinnati OH
4-5-2003
 « Re: TN: 1990 300ZX Twin Turbo - Stage 7+ - All Show & Go - Must See (BCs300z)
I added your BIN as an asking price, as (per the Classified Listing Rules) you need to have a price listed.
Rex - Not THAT Rex ____ Teh Coupe Killaz #0
Tutorial for pics/avatars Donate To NICO: PayPal acct 'advertise@nicoclub.com'
The 3 R's - Read/Research/Reply
BCs300z
90 300zx TT
clarksville TN
2-21-2007
 « Re: TN: 1990 300ZX Twin Turbo - Stage 7+ - All Show & Go - Must See (Rex)
Very much appreciated...thanks
sampsonJ
85 300zx NA / 92 Fairlady Z TT.
edmonton AB
3-13-2008
call me weird but i actually like it in primer black!
Beautiful Z man and I wish you a safe return.
http://92fairladyz.blogspot.com/
BCs300z
90 300zx TT
clarksville TN
2-21-2007
 « Re: TN: 1990 300ZX Twin Turbo - Stage 7+ - All Show & Go - Must See (sampsonJ)
It has, in many ways, grown on me too.
My wife has actually suggested many times, that I just have it professionally painted satin black. Seems to be a popular things these days.
Thanks for the well wishes.
BCs300z
90 300zx TT
clarksville TN
2-21-2007
4 Days left. Low Reserve.
1sikS13
1992 S13 240sx
Green Bay wisconsin
9-17-2006
would you take testicles in for trade. this car is hot
Quote, originally posted by FlatBlackIan »
Trying to lower an S chassis car on stock length dampers, is like laying on the floor and peeing into your own mouth. It will quench your thirst, but in reality, its not the best idea.
Get coilovers.
BCs300z
90 300zx TT
clarksville TN
2-21-2007
 « Re: TN: 1990 300ZX Twin Turbo - Stage 7+ - All Show & Go - Must See (1sikS13)
Thanks, but this car has all the balls it needs!
1 day left! Thanks for looking
BCs300z
90 300zx TT
clarksville TN
2-21-2007
Auction is in it's final hours. Don't miss out
BCs300z
90 300zx TT
clarksville TN
2-21-2007
SOLD ON 16 SEP 2008. THANKS FOR LOOKING
» Return to Nissans For Sale
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
