a while back there was a post of a diagram containing the type x ecu pinout and the red top ecu pin out. does anybody have that diagram on here? i tried searching for it before and i cant seem to find it
Maximum sig size is 600x235 (including images AND text): Maximum picture size is 600x200 within a sig along with two lines of default-sized text. Text only should be no larger than 235px high. This means that if you're picture is 600X200 pixels and you have a couple lines of text you should be in the clear. However, the text is additional, the picture itself may not exceed 600X200 pixels. If you are not sure if your signature meets these limitations, ask. Be a jerk to one of my staff again and you can find a new place to play. - AZhitman
Can someone help me, can't seem to figure this out. This is wiring for e5 to j4 ecu, since you have to move pin #9 to #25 where does pin #25 go to? Also what is going into pin 102, 104, 111 and 115 from the image below? I want to have a/c so do i move #106 to #11, because in the direction the last step is from #10 to #11, but i don't have pin #10(green/yellow). My green/yellow is at 106 and it is bigger then the smaller #11 pin which i can't plug in. Please help out.
