 Which LSX pullout to use..List of all LSx engine codes and vehicles they came in
DJ Raijin
1992 300ZX 2+0 T Top NA
Chambersburg PA
8-22-2008
  a quick LS1 question
I've been looking into LSx engines because I'm planning a swap into my Z32 and I was just curious about potential. Since most of the parts will be aftermarket, I should be able to save money by using the F-body package instead of the Corvette one right?
Also, is the gearing the same between the transmissions? or is one shorter than the other?
I'm currently planning out a budget and organizing everything into stages before I start purchasing parts.
thanks in advance
cnichols
96 Nissan 240SX, 99 Infiniti Q45, 93 Ford Fastiva
Balling Green KY
8-6-2002
I suggest using an F-body pullout, yes.
You cannot use the Corvette transmission...your options are the F-body one or the GTO. That GTO is basically an F-body case with the Corvette internals (shorter gearing on everything but 4th and better synchros).
Throw that budget out the window if you want to do it right. You will never be able to plan for everything in my opinion.
11.85 @ 123 mph | 98 LS1 | Cam only (MS3) | LS6 Intake | 6 Speed & N/A
C6 Corvettes are SLOW.
96 240SX SE...Single Cam Swap
DJ Raijin
Chambersburg PA
8-22-2008
 « Re: (cnichols)
thanks a ton cnichols, that's just the answer I was looking for
cnichols
Balling Green KY
8-6-2002
Not a problem...that's what I'm here for.
I'm currently putting an LS6 into an FD for a buddy of mine and we tried to budget even after I told him it was impossible.
Even though I had just finished mine, there was no way to remember all the little things that would be necessary. Even after giving a "Misc." amount of approximately $500, we went way over because I refuse to do it half ***.
CEO
03 G35C s/c, 93 S13 Vert KA-T, 09 Cube, 72 240Z RB25, 63 NL320, 67 WRL411, 67.5 SPL311, 68 510
Phx, AZ
4-29-2002
Chris, what can you tell us about the available LSx motors year-by-year?
Is there a "preferred" year or model? How about the truck motors? What "donor" vehicles should people be looking for?
TEAM NICO: 146,000 Nissan enthusiasts strong.
REGISTER NOW!!!!
NICOclub on Facebook
cnichols
Balling Green KY
8-6-2002
 « Re: (AZhitman)
Some might disagree, but in order to get the majority of the needed parts and not have to hunt for odds and ends in order to piece together your swap, I recommend an F-body pullout complete with engine, tranny, accessories, etc. so that you have almost everything you need and don't need to do as much work.
However, truck engines are very cheap and are a good way to cut costs if you don't mind the hassle of tracking down a manual tranny (if that's what you want), the F-body accessories, LS intake manifold, etc.
Hopefully the list below will help in the search for the right engine for your project....
GENERATION III - I recommend sticking with the Gen III engines due to the large production#s and the resulting cost effectiveness.
LS1 - 5.7 (346 CI) - Between 305-350 hp and 335-375 ft·lb
1997-2004 Chevrolet Corvette C5, excluding Z06
1998-2002 Chevrolet Camaro Z28, SS
1998-2002 Pontiac Firebird Formula, Trans Am, Trans Am WS6
2004 Pontiac GTO
*97-98 Had Perimeter Bolt Valve Covers
LS6 - 5.7 (346 CI) - 385(01 Vette only)/405 hp and 385(01 only)/400 ft-lbs.
2001-2004 Chevrolet Corvette C5 Z06
2004-2005 Cadillac CTS V-Series
*Basically the same as an LS1 but with better heads (243 head castings) a more aggressive cam, and LS6 intake manifold make up the power differences.
TRUCK ENGINES - STILL GENERATION III - 285-295 hp and 325-335 ft·lb
The truck engines are very much like the LS1/LS6 and are still classified as a Gen III engine. They are mainly iron with the exception of the LM4/L33, and as a result weigh approximately 80+ lbs. more. All the parts from the LS series can bolt on to these engines and is recommended for any swap as the accessories and intake manifold usually fit better from an F-body. The 4.8 and 5.3 can both be punched out to a 5.7 (346 Cubic Inches) simply with a bigger bore (the 5.3) or a bigger bore and the 5.3 crank (in the 4.8's case).
4.8 - LR4
5.3 - LM4, LM7, L33, L59
6.0 - LQ4, LQ9
LR4 - 270-295 hp and 285-305 ft·lb
*Iron Block
2003-present Chevrolet Express 2500-3500/GMC Savana 2500-3500
1999-2007 Chevrolet Silverado/GMC Sierra
1999-2006 Chevrolet Tahoe/GMC Yukon
LM7 - 285-295 hp 325-335 ft·lb
*Most common 3rd gen LSx engine - Iron Block
2002-2005 Cadillac Escalade 2WD
2002-2006 Chevrolet Avalanche
2003-2007 Chevrolet Express/GMC Savana
1999-2007 Chevrolet Silverado 1500
1999-2007 GMC Sierra 1500
1999-2006 Chevrolet Suburban/GMC Yukon XL
LM4 - Identical to the LM7 in power/torque
*Aluminum Block, limited production
2004 Chevrolet TrailBlazer EXT
2004 GMC Envoy XL
2004 Chevrolet SSR
L33 - 310 hp - High Output version of the LM7
*Aluminum Block
2005-2007 Chevrolet Silverado 1500 4WD
2005-2007 GMC Sierra 1500 4WD
L59 - Flex Fuel version of the LM7 (power/torque same)
2002-2007 Chevrolet Silverado 1500
2002-2006 Chevrolet Tahoe/GMC Yukon
2002-2006 Chevrolet Suburban/GMC Yukon XL
2002-2007 GMC Sierra 1500
LQ4 - 6.0L (364 CI) - 300-325 hp / 360-370 ft·lb
*Iron Block
Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
Chevrolet Suburban/GMC Yukon XL Denali
Hummer H2 SUT
GMC Yukon Denali
LQ9 - 6.0L (364 CI) - 345hp / 380 ft·lb
*Iron Block
2002-2006 Cadillac Escalade
2002-2006 Cadillac Escalade EXT
2003-2006 Cadillac Escalade ESV
2003-2007 Chevrolet Silverado SS
2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only 2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
GENERATION IV - Generation IV engines are very similar to Gen III and some parts can be interchanged. The Gen IV was produced with displacement on demand and variable valve timing in mind. Not all have these features, but they are available.
L76 - 360hp /385 ft-lbs. 6.0L (364 Cubic Inches)
2008 Pontiac G8
L98 - 362hp /391 ft-lbs. 6.0L (364 Cubic Inches)
2007-2008 Chevrolet Lumina SS
2007-2008 Chevrolet Caprice SS
L99 - 400hp /395 ft-lbs. 6.0L (364 Cubic Inches)
*Derived from the LS3 and with Displacement on Demand
2010 Chevrolet Camaro
LS2 - 6.0L (364 CI) - 400 hp/400 ft.-lbs.
2006-2007 Cadillac CTS-V
2005-2007 Chevrolet Corvette
2005-2006 Chevrolet SSR
2006-2008 Chevrolet TrailBlazer SS
2004-2007 Holden Special Vehicles (all V8 models)
2005-2006 Pontiac GTO
2008-2010? Saab 9-7X Aero
2005-2006 Vauxhall Monaro VXR
LS3 - 6.2L (376 CI) - 430 hp / 424 ft.-lbs.
April 2008-present Holden Special Vehicles (all V8 models)
2008-present Chevrolet Corvette
2009 Pontiac G8 GXP
LS4 - 5.3L (325 CI) - 303 hp / 323 ft.-lbs.
2006-2008 Chevrolet Impala SS
2006-2007 Chevrolet Monte Carlo SS
2005-2008 Pontiac Grand Prix GXP
2008 Buick LaCrosse Super
*Aluminum FWD Block w/ LS6 Heads
LS7 - 7.0L (427 CI) - 505 hp / 470 ft.-lbs.
2006-2008 Chevrolet Corvette Z06
2008 HSV W427
LS9 - 6.2L (376 CI) Supercharged - 638 hp / 604 ft.-lbs.
*Based on the LS3
2009 Chevrolet Corvette ZR1
TRUCK ENGINES - GENERATION IV
LY6 - 6.0 (364 CI) - Same as LQ4, but Gen IV.
*Variable Valve Timing
2007-present Chevrolet Silverado HD
2007-present GMC Sierra HD
2007-present Chevrolet Suburban 3/4 ton
2007-present GMC Yukon XL 3/4 ton
L76 - 6.0 (364 CI) - 367hp / 375 ft.-lbs.
*Basically the Gen IV replacement for the LQ9
*Variable Cam Phasing & Active Fuel Management
2007-present Chevrolet Avalanche
LFA - 6.0 (364 CI) - 332 hp / 367 ft.-lbs.
*Active Fuel Management
*Late-intake valve timing system
*Higher 10.8:1 compression ratio
2008-present Chevrolet Tahoe Hybrid
2008-present GMC Yukon Hybrid
2009-present Cadillac Escalade Hybrid
2009-present Chevrolet Silverado Hybrid
2009-present GMC Sierra Hybrid
L92 - 6.2L (376 CI) - 380/403 hp and 403/415 ft.-lbs.
2007+ Cadillac Escalade
2008+ Chevrolet Tahoe
2007+ GMC Sierra Denali
2009+ Silverado 1500
2008+ Hummer H2
2007+ GMC Yukon Denali/Denali XL
Quick summary of the major engines and their compression ratios and GM part #s:
LS1...346c.i. 5.7liter 10.19:1 25534322
LS6...346c.i. 5.7liter 10.46:1 12578104/12562190
LR4...293c.i. 4.8liter 9.47:1
LM4...325c.i 5.3liter 9.49:1
LM7...325c.i 5.3liter 9.49:1 12562201
L59...325c.i. 9.49:1
LQ4...364c.i. 6.0liter 9.41:1 12575147/12575148
LQ9...364c.i. 6.0liter 10.08:1 12499467
hannibal
1990 Integra, 260k miles
Atlanta GA
9-11-2002
 « Re: (cnichols)
^ sticky! thats the most complete list Ive seen...
Question: can all of these use the same mounts? and all bolt up to an F-body or GTO 6 spd tranny?
DJ Raijin
Chambersburg PA
8-22-2008
 « Re: (cnichols)
Quote, originally posted by cnichols »
Well, it really wasn't a budget as much as it was a parts list so I can put myself in the general area of how much i'll need for the basics. it's basically to tell me how much time i will be spending saving and allowing me to budget work time and project time accordingly. of course I know that's not including all of the extra nonsense that comes with hybridizations such as this one.
My project is a "cost is no problem" type...just time.
Anyone know of any good write ups or manuals for the LSx swap? I mean, I'm sure my buddy and I can do it on our own but a write up or some measurements will make this thing all that much easier. Anyone have any experience with Adlashwa's manual?
Also, how hard would it be to run some Ram Air with an LS1 in a 300Z? the LS1 has that nifty forward facing throttle body and you can get those slotted nose panels...I would think one could use a modified version of the F-body ram air box with an F-body filter and mount it up behind that nose panel, right?
cnichols
Balling Green KY
8-6-2002
 « Re: (DJ Raijin)
Quote, originally posted by hannibal »
Yeah, I'll sticky it for sure....took me a little while to put it together.
All the RWD ones should have the same mounts but I can't guarantee that. Obviously, I would avoid the FWD versions (although you can probably use the heads).
They should all bolt up to the F-body and GTO transmissions...the Corvette one is something you will NOT want to attempt.
Quote, originally posted by DJ Raijin »
There are too many variables (cost of your pullout can differ greatly) for me to give you an accurate amount to budget. Do you want an aluminum or iron block, standalone or not, driveshaft material, mods, etc? I would say $5000 will be a good starting point to get your pullout purchased and most of your major items. Everyone is different so I don't know how anal you're going to be in doing your swap.
I'll try to get up a sticky in the near future of my swap. In the meantime, hit me up on AIM: midcnichols with any questions you have or search here in the Hybrid forum.
Ram air is worthless for the trouble you'll have to go to due to the radiator and low profile front of the 240. Just build a nice cold air intake with at least 3.5" piping and you'll be good to go. If you want to get fancy, build a Y pipe and have dual 3" piping going to each side of the bay.
DJ Raijin
Chambersburg PA
8-22-2008
 « Re: (cnichols)
I got a Z32 not a 240SX. I figure with one of those nose panels, I could use the F-Body airbox with an F-body air filter and get ram air. If this guy had a nose panel, I think he'd have ram air.
http://forums.hybridz.org/showthread.php?t=123551
If I had a 240SX, I'd be looking at either a VH45 or a 2JZ. Probably the VH45. I LOVE that motor but there's no aftermarket for it...otherwise it would be perfect (aside from no 6 speed...which I want just for kicks and giggles).
btw, you are getting added to AIM, my screen name is Messiahs Oracle, so if you see that name message ya, that's me. thanks a ton.
cnichols
Balling Green KY
8-6-2002
Sorry about that...forgot you had a Z32. I would definitely try to contact CRZ SWAP and any other Z32 guys for more detailed info and things they ran into.
DJ Raijin
Chambersburg PA
8-22-2008
 « Re: (cnichols)
thanks again, you've been a great help
Dirtfall
Portland OR
9-12-2006
 « Re: (cnichols)
What clutch and flywheel did you use cnichols?
cnichols
Balling Green KY
8-6-2002
 « Re: (Dirtfall)
My first clutch and flywheel were stock (C5 Z06) and I am now running an LS7 clutch and flywheel combo (C6 Z06). I switched to the LS7 clutch when I installed the MS3 cam. I've never had a problem with either and the pedal feel is great.
DrifterXRPS13
Teh Learned'd Possum
Online
1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600
Evanston, Vernon Hills IL
9-19-2003
hey chris, did you ever get to doing that in depth writeup you were talking about awhile ago...i'm still debating on whether or not to do this swap and i've been following your build and the rest of the info here on the hybrids forum but there's no exact build list, i know it's different for eveyrone on what part they want and whatnot but i'm just looking for a list of parts that i absolutely need and approx how much it's gonna cost?
if you want you can shoot me an email, that would be much appreciated.
Don't Drink And DRIFT!!!
89 S13 - I/H/E, XTD Stg 2, Mint interior, 155k - SOLD
98 S14 - BD manifold & DP, Turbonetics T3/T04E 50 trim .48A/R , Tial 38mm WG, Greddy Type S BOV, 24"x6"x3.5" BD FMIC, TF 555cc injectors, Walbro 255lph fuel pump, SSAC 3" exhaust, 3" Catco cat, JWT ECU, SAFCII, MBC, Z32 MAF, Autometer Mechanical Boost Gauge, LC-1 wideband w/display, OBX Short Throw, Z32 front brakes, Eibach pro-kit springs, AGX struts, 18x8 MB Motoring Rev wheels
04 CBR 600RR - Disassembled and waiting for buyers.
05 GSX-R 600 - CF Gas Cover, CF Triple Tree Cover, CF Gauge Cluster Cover, CF Tank Slapper, CF Yoshimura TRS Exhaust, Removed Graphics from Tail, Suzuki No-Cut Frame Sliders, Suzuki Swingarm Spools, HotBodies Undertail, Pirelli Dragon SuperCorsas, Sportech Red Chrome Wind Screen
Beercandrifter
91 240sx fastback
melbourne florida
12-7-2006
 « Re: (cnichols)
have a quick question, while the majority of truck engines are quite easy to find for cheap, the issue seems to be finding ones with manual transmissions. I dont suppose you have any research on which truck engines came with manual transmissions or if there are any transmissions that bolt to the lm/ls series motors besides the t56.
thanks,
Arabrockermang
93 240sx Convertible
Fort Smith AR
6-28-2009
 « Re: (cnichols)
I'd like to get all the numbers how much wieght would I be adding to my convertible vs the KA24 mostly balance. I can get a free 5.3L so that cuts cost dramatically for me I know how to fabricate and what not but I don't want to make it a front heavy muscle car. I'll just get a new Tremec so that I'll never have to buy another for power upgrade unless I get a used one for the right price. and when I say the weight I mean the dressed fan to flywheel KA vs the fan to flywheel cast iron Chevy.
I got everything in multiple for the chevy so thats where the real sell point is also the wieght vs a rb25det would be good.
cnichols
Balling Green KY
8-6-2002
 « Re: (Arabrockermang)
Quote, originally posted by Beercandrifter »
thanks,
Don't know if they ever did to be quite honest. I would stick with the T56...this eliminates any clutch problems you might have and it's tough to find a stronger one. Bite the bullet and get a T56...you'll be glad you did.
Quote, originally posted by Arabrockermang »
You'll never notice a difference, trust me. You'll be too busy pedaling the throttle trying to make it stay straight. You could put two LSx engines up front and I'm willing to bet it would still be fun to drive. Move the battery to the trunk and forget about it.
» Return to Hybrids
