SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sun Aug 24, 2008 3:13 pm
If you replaced the sensor and you are still detecting the code there are a few things it could be, none of them are very fun though. The ECM sets a PO500 when there is no speed signal detected to the computer while it knows it should be driving based on other inputs. Check your power supply, ground and speedo head. If the speedometer is not processing the signal correctly which is fed directly to the speedo head where it is converted in to digital pulse signal and then fed to the ECM.A problem anywhere in the circuit will cause the light to come on. What was the condition of the teeth on the old sensor?
