 xm to sirius
dnicect
2009 nissan murano
stratford ct
8-18-2008
  xm to sirius
i have a 2009 murano and i want to put sirius in.can i change over from xm to sirius.i have been reading mixed reviews on this topic.
Timmbo
Armada/QX56/Murano/EX35 Moderator
'08 Nissan Armada LE & '08 Nissan Altima 3.5 SE
Green Bay WI
11-20-2007
 « Re: xm to sirius (dnicect)
This is very important, do you have the SL or the LE, and do you have the Navigation System?
'08 Nissan Armada LE (Timberline) & '08 Nissan Altima 3.5 SE (Dark Slate)
dnicect
2009 nissan murano
stratford ct
8-18-2008
 « Re: xm to sirius (Timmbo)
i have a LE with no navigation
Timmbo
Green Bay WI
11-20-2007
Quote, originally posted by dnicect »
Well, then you are set, you currently have an XM tuner that is located near the spare tire. On '09 Muranos WITH Navigation, the XM tuner is integrated into the audio control unit under the dash, thus not replaceable or interchangeable. If you have any questions, let me know, I actually have a few pages of the service manual printed off, but the tuner is located just in front of the spare tire (between the spare and the back seat). All you need to purchase is a new Siruis tuner, and pull out the XM tuner. The antenna lead will plug into the Sirius tuner (you have to cut off a small piece of plastic for the antenna lead to plug into the new Sirius tuner).
Hope this helps, please let me know if you have any questions!
dnicect
2009 nissan murano
stratford ct
8-18-2008
i have 1 more ?. can i use a tuner from an 2006 murano w/o nav and it has a bose system.
Timmbo
Green Bay WI
11-20-2007
I believe so, I can't say I am 100% certain, but I see no reason why it would not work, I believe they are all the same.
dnicect
2009 nissan murano
stratford ct
8-18-2008
ok.I thank you for you time and info
Timmbo
Green Bay WI
11-20-2007
Glad to help, when are you planning to switch out your tuners?
dnicect
2009 nissan murano
stratford ct
8-18-2008
i order the tuner on firday when it comes in i will be installing the tuner some time next week.
Timmbo
Green Bay WI
11-20-2007
Keep me posted and let me know if you have any questions!
bruceabosco
2009 Murana LE
Phoenix AZ
9-1-2008
I just purchases a 2009 Murano LE with no navigiation and am also looking to swap xm for sirius.
Is this the receiver to get? Will I need to purchase anything else?
SiriusConnect Vehicle Tuner
Model: SIRIUSConnect Vehicle (SCC1)
Price: $49.99
http://www.sirius.com/servlet/...98317
dnicect
2009 nissan murano
stratford ct
8-18-2008
 « Re: xm to sirius (bruceabosco)
i really dont know if that would work.i order a sirius tuner from mynissanparts.com. the tuner kit cost 194.00 the cheapest i could find anywhere.
dnicect
2009 nissan murano
stratford ct
8-18-2008
i will let you guys know when i put the tuner and if it a success.
Timmbo
Green Bay WI
11-20-2007
Quote, originally posted by bruceabosco »
Price: $49.99
I don't believe that unit will work. dnicect is correct. You need a Nissan Sirius tuner, you can order if from any Nissan or Infiniti dealer. http://www.mynissanparts.com is a good place to purchase from. I also found it here: http://www.grubbsperformance.c...=2905
Let us know if you have any further questions!
bruceabosco
2009 Murana LE
Phoenix AZ
9-1-2008
Thanks guys for the info. I will probably wait to order mine until I hear how it goes with Dnicect. Then I may attempt to do it myself if it's really easy. I dont know alot about cars so I am very reluctant to do this myself. I was thinking about asking the dealer's service dept if they could do it for me.
Any info on if the dealer would do the swap?
Timmbo
Green Bay WI
11-20-2007
I doubt the dealer would want to do it, and if they did, they would probably really sock you for the labor. It is actually a really easy swap out, totally easier than changing a spare tire, that is for sure. I think just about anyone can handle it, you locate the receiver (near spare tire) and switch out the tuner. You will have to unplug a few things from the existing tuner and then plug them into the new Sirius tuner.
joe603
Super Moderator
05 G35 coupe
Hampton GA
11-21-2005
Another future option....
Since XM and Sirius have merged, they may come out with a converter device...
Read the G-Series FAQ! - G-Series Forum Main Page - Tire Size Calculator
"A person who never made a mistake never tried anything new." -Albert Einstein
Leftarm
Grande Prairie AB
9-9-2008
Should work out fine. I pulled the receiver out of my 2005 before I traded it in and installed it in my 2009 in about 20min. Only modification was to the antenna connector. Had to cut off the Sirius teeth so that the XM antenna plugged in.
Timmbo
Green Bay WI
11-20-2007
 « Re: xm to sirius (Leftarm)
Quote, originally posted by Leftarm »
Leftarm is CORRECT! All you have to do is cut off the teeth on the antenna plug, and it will plug right in.
Timmbo
Green Bay WI
11-20-2007
Anyone complete the change-out?
dnicect
2009 nissan murano
stratford ct
8-18-2008
 « Re: (Timmbo)
just recieved the tuner today and will be installing today.will let you guiys know how it turns out.
dnicect
2009 nissan murano
stratford ct
8-18-2008
 « Re: (dnicect)
Hey guys just got done hooking up the the tuner and it works great.I insatalled Sirius tuner part number 999U9-AS006.I got this pat from mynissanparts.com .All you need to change this tuner is a 10mm and 13 mm socket.IT took about 1/2 hour to take everthing apart and pu t back together.
Megatron26
09 Nissan Murano SL
Clermont fl
10-6-2008
Timmbo,
Can this be done with the 09 SL no navigation ???
Gotta have my NFL....
Thanks
MT26
Timmbo
Green Bay WI
11-20-2007
 « Re: xm to sirius (Megatron26)
Quote, originally posted by Megatron26 »
Timmbo,
Thanks
MT26
Greetings to NICOclub! Glad to have you here in the Murano Forum!
Yes, as long as you have XM on your particular vehicle, you switch out the XM tuner with a Sirius tuner just as dnicect did. Let me know if you have any questions!
spastic
Murano 09 SL
Keller TX
10-2-2008
For those that have listened to both, can anyone comment if one sounds better than the other? Or are they the same. I'm not so much interested in programming choices 'cause I can look that up but I find alot of the XM channels just have poor sound quality that's grating to my ears.
Megatron26
09 Nissan Murano SL
Clermont fl
10-6-2008
 « Re: xm to sirius (spastic)
Just found out XM has a package that's called XM with "the best of Sirius"
$16.99 month. Should solve my problem because I want the NFL games incase I'm on the road. That way you don't need the new hardware.
MT26
Timmbo
Green Bay WI
11-20-2007
I was wondering about the new packages. I have heard that some of the older tuners can't pick up the signal, PLEASE let us know if the new Sirius packages will work on the XM on our '09 Murano. THANK YOU!
Timmbo
Green Bay WI
11-20-2007
According to XM's website, all XM radios can receive the "Best of Sirius" programming.
545ipath
2008 Pathfinder LE V8
Granby CT
10-12-2008
Quote, originally posted by Timmbo »
How about on a 08 Pathfinder with Nav?
am I screwed because of the Navtraffic
I hate XM, reception is way worse that sirius
would love to convert it
Thanks
Timmbo
Green Bay WI
11-20-2007
 « Re: xm to sirius (545ipath)
Welcome to NICOclub! Thanks for visiting the Murano Forum, we welcome Pathfinder owners as well!
If you DO NOT have the navigation, and you do have XM, then yes, you can switch out the tuner. I am surprised you have issues with the XM, I don't know that the Sirius will be any different, they are technically now the same company.
» Return to Murano Forum
