any one using these?
nzmoman
Car: 240sx 2 of em' and always lookin for more
http://www.frsport.com/Turbo-Q....html
I am considering playing a little cleanup under the hood. I was thinking about getting some of these to shorten lines for the boost controller/wastegate and the boost gauge.
anyone try these and have feedback?
garagelu
Car: 1995 240sx w/ sr
Why not just weld a nipple onto the intercooler piping? It would look so much cleaner. If you have stainless steel intercooler piping, I have some leftover piping that I used for making a nipple on the intercooler pipe. Email me at [email protected] if you want some.
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
I just ordered that. I'm using it for my synapse BOV. I'll let you know how it does.
nzmoman
garagelu wrote:Why not just weld a nipple onto the intercooler piping? It would look so much cleaner. If you have stainless steel intercooler piping, I have some leftover piping that I used for making a nipple on the intercooler pipe. Email me at [email protected] if you want some.
my piping is aluminum...
I don't have access to a welder on hand and I hate trying to get the retards at the local muffler shops to do anything....they make it seem like brain surgery.
moyea wrote:I just ordered that. I'm using it for my synapse BOV. I'll let you know how it does.
I am definitely going to be looking for your feedback.
schanne
Car: 93 Hatch-Sr20
My piping is aluminum as well and no body wants to do it right. The "best" welding shop in town put some liquid weld on my tap for the pipe with a big FAIL. Thinking about caping the hole and using this item....
Neil
Car: shooting laser guns
Those things are probably okay, just be sure to use a decent fiberglass reinforced coupler.
I considered using one but I ended up drilling my stock compressor outlet and tapping it for a brass fitting that I got at the hardware store. used a little JB weld to make sure it was air-tight and it's been perfect.
Dont take your aluminum pipes to the muffler shop. They won't have the right kind of rod to use if they even TIG at all. Check the yellow pages under Welding for people who advertise TIG and get a price quote. cuz I went to the first douchebag I found in the book and he charged me $50 to zap on my intake's recirculation fitting. it was a 2 minute job. I don't think re-filling the tank of Argon for the welder is more than $20. ><
Emperor_Tha
I got mine epoxy to my turbo outlet pipe on my t25. I went from 2200 rpm starting boost on the old set up to 1800 rpm in 3rd gear. I see full boost at 2300-2500 at 15 psi. Before it sees full boost at 3.5k
nzmoman
Neil wrote:Dont take your aluminum pipes to the muffler shop. They won't have the right kind of rod to use if they even TIG at all. Check the yellow pages under Welding for people who advertise TIG and get a price quote. cuz I went to the first douchebag I found in the book and he charged me $50 to zap on my intake's recirculation fitting. it was a 2 minute job. I don't think re-filling the tank of Argon for the welder is more than $20. ><
The argon is $60 for a large tank. I found a place....I just gotta get there with a truck
Emperor_Tha wrote:I got mine epoxy to my turbo outlet pipe on my t25. I went from 2200 rpm starting boost on the old set up to 1800 rpm in 3rd gear. I see full boost at 2300-2500 at 15 psi. Before it sees full boost at 3.5k
pics please...I would like to see this...
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Man, if any of you guys lived closer to me, I'd weld it for next to nothing! lol
moyea
PhopsonNY
Car: 1989 Nissan 240SX
Yeah,
I installed one of these when I upgraded to the gt2871r and had been working for a few months now with no problems.
Just make sure it is on tight.
good luck
redsx13
Car: 93 240sx 03 350z
that thing is sweet, much easier that welding one in
Emperor_Tha
I can only send to your email from my iPhone
nzmoman
Seishuku wrote:Man, if any of you guys lived closer to me, I'd weld it for next to nothing! lol
Then I think its time you relocate to north atlanta!!!
moyea wrote:
this is an excellent idea...I just want to avoid having another hose running across my engine bay...but this is definitely an option
moyea
This comes up right below my air filter (driver-side front wheel well). You wouldn't know it was there unless I showed it to you. The only reason I got this tap was because the Synapse BOV required a boost only source. My job frowns on bringing your home projects to work and this is just as easy. Like you said, one of many options.
nzmoman
Yeah, I am becoming pretty convinced that I should at least try it.
thanks moyea
