Car has a RB25DET motor with appox 59800 miles on motor. Swap was done in CA by a shop, so every detail was covered. A Syko Performance kit was used for the swap which is one of the best motor swap kits you can buy. Car has 5 lug with big brake Z32 brakes with upgraded rotors in front. Front rotor is crossdrilled. Car has been lowered about 1.25" with Bilstein shocks and Eibach springs. Kosei 18" x 9" wheels with 20mm offset There is a oil cooler with fan added to cool things down with a remote oil filter, drove car from CA to FL in summer and no problems. Remote oil filter, so oil changes are really easy. All the lines are stainless with AN fittings, oil filter is off a 350z. Only used K&N oil filters. Royal Purple oil in motor and tranny. Spark plugs have been changed to NGK Iridium. Battery has been moved to the trunk on passenger side. Everything on car works perfectly, heat, defrost etc. NO AC. Car runs very strong. Car has Blitz electronic boost controller which is great, put it at 5psi and get 30 mpg all day long. Turn up the boost, well, who cares about gas milage then. Car has massive intercooler in the front, enough to support 600hp. Fuel pressure gauge was added that can be seen next to the oil filter. There is a brand new Nismo adjustable fuel pressure regulator. There is a boost gauge mounted in a carbon fiber pod on steering wheel with another pod which has an oil temp. gauge. All cluster gauge lighting has been updated to a red color, looks really nice at night. Interior is stock, no rips or tears in fabric seats. Dash looks great, no cracks. Nismo shift knob. Eclipse head unit. Car has full RSR exhaust for the S14, this system is very expensive and sounds spectacular. Car has J30 with LSD. One piece drive shaft Competition Stage 3 sprung 6 puck. This has to be one the best "feeling" clutches, I have ever driven. Solid engagement, yet easy in traffic. Car runs strong, turbo spools quick and car drives straight, no problems. Motor is stock, RB25's put out between 275 to 310 RWHP stock. This car is an excellent starting point for a modded car. A few bolt on's with tuning and 500rwhp is easily attainable. I have looked around at car's comparable to this one, with RB25DET with only108000 on the frame and believe this is a very decent price for this, as clean as it is. Take a look at the photobucket link. Asking price is $11500.00 but welcome offers. Moving new price $10700
