Why are muffler bolts heated before you put wrench to them?
vancouverbc
Car: 1991 240sx
Doesnt heating the bolt make it bigger? I thought you would heat the areat around the muffler bolt.
Hitting the bolt to break rust bond and allow the wd40 to penetrate faster makes sense.
sommmatt
Car: 1989 Nissan 240SX
lol wut
bt2s14
Car: 96 s14 VG30E swap on the way
Heating it makes it more malleable...Made that up...
ShopliftTHIS
Car: S13 Coupe
Anything colder will expand. Ever left a beer in the freezer? You get the idea. Metal is no exception.
kane2g
Car: 92 240sx 95 240sx
bull****cold - makes things smaller - think your balls being dipped in cold water
hot makes it expand - like that nice wet pus..... well you get the idea.
vancouverbc
Car: 1991 240sx
thats a phase change. liquid to solid
vancouverbc
Car: 1991 240sx
Heat and oilIf you have the time, several applications of penetrating oil over the course of a day or two can sometimes break a corrosion bond. Alternatively, repeatedly heating a bolt with a narrowly directed propane torch, then letting it cool, can cause the metal to expand and contract enough to break the hold. Direct heat to the fastener, not the material it’s threaded into, and try to work the bolt with a wrench during the process (wearing heavy gloves).
some people say heating the bolt makes it more likely that the bolt head will twist off. i guess if you wait for bolt to cool it is ok. use acetylene to heat it up fast so surrounding material does not have chance to get hot.
mapp gas might be good.
Crazyirish
Car: Nothing noteworthy at the moment...
ShopliftTHIS wrote:Anything colder will expand. Ever left a beer in the freezer? You get the idea. Metal is no exception.
Only water exhibits this behaviour. (Yes there is water in beer. I know. I've done extensive research on the subject ) Everything else shrinks when cold.
xckid
Car: 2004 Chevy Blazer ZR2
in short and less writing to loosen up the bolts
H8tred
In my prior line of work (Working on dry van and reefer trailers.) I've found that nothing beats heat for removing a seized bolt/nut. What my employer did not understand, and I'm sure part of the reason I don't work there anymore, is that when you heat metal, and let it cool slowly, it weakens it. Ultimately, it is best to replace what ever it is that you're heating, and use a generous amount of anti seize before assembly.
When you get a bolt cherry hot, the outer layer almost acts as a lubricant, plus, it's just soft enough to get past anything it was getting caught on.
murda-c
Car: 1996 s14
Ice shrinks when cooled down too.
VP4prez
Car: 93 240 bee-haaatch!!!
i work in a motor shop and the best way to get 99 percent of oil plugs out is to heat the block driectly around the bolt. but im sure this is the opposite because ur really just trying to smoke out all the gunk and road tar that has been there since the day the mani put the motor in. acetalene torch and a manual impact screwdriver, works like a charm
PorkChopExpress
Car: rb kouki
bismuth also expands when cooled.
Crazyirish
murda-c wrote:Ice shrinks when cooled down too.
No It doesn't. Go back to high-school chemistry.
PorkChopExpress wrote:bismuth also expands when cooled.
Ok, yes bismuth, stable plutonium isotopes, and a couple of other elements DO expand when cooled, but those are rare exceptions.
vancouverbc
Car: 1991 240sx
i think most solids get bigger as they increase in temperature. ice might be an exception but im not sure why.
