I've been looking for the same (actually all four shocks) ... no luck yet.bavauto325i wrote:I need a good source for Front struts for my 2003 M45. Is the Infiniti dealer the way to go or is there another sorce.
Thanks
Z
Darn, I forgot about that. I should contact One Ton Garage first ... thanks, Brian, for the reminder!maxnix wrote:Did you follow up on the IOM thread?
If you do, please update this post with what you find out. I would be interested too but I would like a bit stiffer setup. The reason I didn't go with the springs is that I couldn't find aftermarket struts to go with them. Thanks Zszhosain wrote:
Z
My car is currently at about 66k. For the past few thousands of miles, I have noticed that it is simply not handling well ... going over bumps, particularly on curves, there is small but distinct sideways lurching and rear wheel "hop" (not large, but it is there). Straight-line is pretty much okay, of course, and there is no floating or anything like that, but it simply does not handle as well as it did when new.CakeDaddy wrote:What symptoms(sp) are you all having? And, what mile mark are you all at to be considering replacing front struts?
Good! Please let us know how it goes!bavauto325i wrote:after reading the service manual it looks like I will be able to do the work myself. I just have to go and get a few specilty tools.
