 Which Sound Deadener is the best value? E-Dead? CoolMat? RAM-Mat? Heat Issue?
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
I'm looking up on puttin sound deadeners on my VQ swap car once the engine is done and I start working on the interior. I want to cover the entire cabin with them so super expensive parts are out of the question. I'll have them on the floor, under the roof, inside the doors and quarter panels. I'll even have them under the dash.
But the issue I'm worried about is that will heat have them drip off or peel off? I don't want to spend $400 on stuff that will die after one summer.
Thanks
For SALE: 2003 SE-R Spec V 6 Speed Manual with LSD Brakes =$150. Running Strong.
1991 - S13 Coupe KYB AGX + Eibach ProLine $475, Strut Mount $160, ClutchKit $150, ExhaustSet $300, WaterPump $50, Radiator $99, FanCluth $45, Clutch Master $30, Brake Kit $310, Chassis $150, Anti-Theft $XXX, Audio $250, Celica Seats $200, Alternator $115, Starter $130, NISMO Wheels, Stillen Strut Bar, RedCoupe Shell $1,500 NEXT>>Bushing, LSDStatus - Running Strong.
1992 S13 SE Coupe Being taken apart for VQ Swap VQ30DE $320, ECU $50, Harness $100, MAFS $50, Intake Manifold $99, Z33 6-Spd $380, Poly Mounts $125, Z33 Oil Pan $121
For Sale : FL, S13 Radiator, KA24DE, Automatic, ECU, Starter, EGR, FAN, Alternator, etc NEW LOW PRICES
EW
DFW
5-20-2005
If you use Dynamat Xtreme AND follow the directions (clean the surface with acetone, use a roller to bond the Xtreme, etc) it will not fall down. Xtreme is thicker than other brands and works great. I have 100lbs of Dynamat in my mustang and have done the roof of my truck with Xtreme and Dynaliner. More to follow in the truck when I install the system.
06 F150 Supercrew
98 Cobra
95 S14
AppleBonker
A/V Nut
'08 Altima Coupe 3.5SE Radiant Silver 6MT
Chicago Illinois
7-17-2008
 « Re: Which Sound Deadener is the best value? E-Dead? CoolMat? RA ... (Soravia)
Wow, dynamat is pretty expensive. I've only ever used Second Skin Audio Damplifier in my cars and I've been happy with it. It's significantly cheaper than dynamat and performs equally well, if not better (IMO). Check this out for more info and comparisons. Little bit old, but I think most of the info is still pretty good.
Read the A/V FAQ for all your mobile A/V questions!
Get on the map!
CEO
03 G35C s/c, 93 S13 Vert KA-T, 72 240Z, 63 NL320, 67.5 SPL311, 69 and 70 SPL311s, '69 510
Phx, AZ
4-29-2002
I think the last comparisons I read, the RAAM was the best for the buck.
I'm using it in a couple of my restorations.
TEAM NICO: 114,000 Nissan enthusiasts strong.
Add a link to NICOclub to your site!
...even the HITMAN is on MySpace
Stacey Lynn Childs 1970-2007... Love of my life, my best friend, Heaven's prettiest angel. I miss you so much.
Looneybomber
89 bronco 2 (Blu/tan) 99 R1 (red/wht/blk) 02 explorer sprt (grn) 03 S2000 (triple blk)
Topeka KS
3-7-2004
 « Re: (AZhitman)
If you really want bang for your buck, find out what panels/locations are letting in the most noise and which one's aren't too bad. Then only apply sound deadener to those "noisey" panels. Typically dense curvy panels wont need deadening where-as large flat panels (doors) may need multiple layers.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!" -Adolf Hitler, 1935
Soravia
Jacksonville FL
11-18-2005
I'm thinking inside doors, around the torque tunnel, behind the back seat, passenger fire wall, under the back seat and behind the doors. trunk seems un-necessary since blocking behind the rear seat will take care of that.
Looneybomber
Topeka KS
3-7-2004
 « Re: (Soravia)
How much noise do you think you get from the rear? You may not need to put anything on the floor or behind the rear seats.
krimsonviper
The Original
Online
06 Mazda 3i
Bay Area CA
12-9-2004
sorry to thread jack but i dont want to start a similar thread. Plus I'm also looking for the same info
how much would it cost to get just the trunk/back seat panel professionally done? Guestimates are fine, but real guestimates. I'm not looking to do it myself because its a b!7tch to do, but it its really expensive, i'm game
User was banned for this post
Quote, originally posted by jdm_master_X »
krimsonviper threatened me and I...
JIZZED IN MY PANTS
EW
DFW
5-20-2005
Depends upon how far you want to go (moderately covered?every square inch covered?layer of foam over Xtreme? etc) but I'll say $300 installed for Xtreme trunk kit and installation. Really, a monkey can install it* but it is hard work and time consuming.
*take apart car without breaking every clip or panel.
clean surface with acetone.
cut material to size.
peel backing, lay material in place, use roller tool to bond material to vehicle.
repeat until done.
reinstall panels into car.
pass out.
krimsonviper
The Original
Online
06 Mazda 3i
Bay Area CA
12-9-2004
 « Re: (EW)
Quote, originally posted by EW »
see thats what im afraid of. i know i going to break something. plus i work at night so by the time i wake up the sun is already more than half way gone, so i want this done professionally, but if its going to BMW then i might as well do it myself. i just want his incessant rattle gone really. its somewhere behind the backseats headrest, if i can get rid of it without spending too much, then i'll just fix that and be happy
D-Maxima
1992 Maxima
Perth Western Australia
3-4-2008
 « Re: (krimsonviper)
Again thredjack
My sub makes my parcel shelf rattle a lot and im getting tired of it ruining the music when Im driving.
Im not too worried about other panels in my boot, but would just sound deadening my parcel shelf be a viable option? Ive heard that to get to the parcel shelf its a PITB because you need to take the back seat out etc to do and Im not up for doing that.
is there an easier way? Or a way to tighten my speaker covers in the back? Ive had a look but cant find a way to tighten them.
or could I do the clean and roll method mentioned above just on the underside of the parcel shelf? And maybe carpet it to make it look nice?
Thanks guys
Quote, originally posted by themadscientist »
Open up Google, where you normally type "gay porn" type "currency converter"
Quote, originally posted by Dasoupdude »
I hope they serve beer in hell.
the converted
Airplaneburator
1991 240sx, 2003 Maxima 6 speed, building a Lotus 7 replica
Boston, Ma Danbury CT
2-21-2007
 « Re: (D-Maxima)
For stuff like that I tend to use carpet padding because its tons cheaper.
Cpl Dozier
1991 240sx
Fultondale Al
9-22-2007
I used fat mat on the ceiling, walls, inside walls, floors, firewall, doors and everywhere else I could. Used 150 sq. ft. and two layers on everything. I have four eighteen inch woofers in a wall behind the front seat in an explorer. No rattle anywhere, and road noise went away. Get it on Ebay for 50 bucks for 100 square feet. I bought two rolls for 110 shipped. so that was 200 ft.
D-Maxima
1992 Maxima
3-4-2008
 « Re: (the converted)
Quote, originally posted by the converted »
i was thinking carpet padding too...so i could just layer under the shelf and maybe the back of the seat and that could do the trick?
how would you stick that on?
Quote, originally posted by Cpl Dozier »
well i have only one 12 inch so if it did the trick for you hopefully It can benefit me
ds08versa
2008 Nissan Versa SL
Gardner KS
4-17-2008
 « Re: (D-Maxima)
Hushmat by far is the best, it does what what the others do but more it is east to apply, no cleanig( it will stick to anything) and it cuts with scissors and it also helps with the heat factor not just the dampining and it has been used in the oem side for 15 years thats all i use and it works.
just my 2cents http://www.hushmat.com
David Wilson
http://www.santafeautosounds.com
08 Versa SL
06 Maxima SE
This is why i love my job!! 200,000 cars to take apart and put back together, see my car in the background.
Image exceeds 600x200 sig size limit
EW
DFW
5-20-2005
No hush mat for me.
We worked on a car done with fat mat recently and the material was no longer bonded to any of the panels. It wasn't even sticky anymore. Garbage.
92socal240
1992 240sx
San Diego CA
10-20-2008
 « Re: (EW)
I've had good luck with Dynamat extreme. The only place I wouldn't use it is the headliner as it's weight may cause it to sag over time especially with the heat from the sun.
maximafan
Victoria BC
9-26-2007
 « Re: (D-Maxima)
Use silicone around the speaker frame to adhere it to the body. Best to do this from above (so the seats and cover need to be removed) This will prevent any vibrations. As for taking out the seat, it's easy. Let me know if you need info on that. as for the finishing cover, you might have some luck putting some neoprene (closed sell foam) weather stripping at strategic locations to bolster it.
EW
DFW
5-20-2005
 « Re: (92socal240)
Quote, originally posted by 92socal240 »
It won't fall down if installed correctly. When the Xtreme first came out, I noticed that on the package that they showed it installed on the roof. I called them and asked about putting it in upside down (since I knew the Original product could not be used upside down) and they confirmed that it will stay bonded. We have done MANY cars over MANY years with Xtreme on the roof (including my F150) and we have never had an issue.
rjdmmfl1
Birdman
2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
San Diego CA
9-25-2007
 « Re: (EW)
Best value.... RAAMMAT
Best Quality... Second skin Audio Damplifier PLus
http://www.sounddeadenershowdown.com/
C.O.L.O.U.R.S. .... MODS available HERE
WANT TO PURCHASE ILLUMINATED ALTIMA KICKPLATES, click here
and here's the ILLUMINATED KICKPLATE PHOTOGALLERY
CEO
Phx, AZ
4-29-2002
 « Re: (rjdmmfl1)
Quote, originally posted by rjdmmfl1 »
Again, I like the RAAmmat... Used it in my 240Z and my P71 and it's awesome... inexpensive, great sound deadening, great heat-blocking properties, and it sticks like hell.
phuphyter
1991 240SX SE
SoCal
8-22-2004
I've only had experience with E-dead myself, so I can't compare to other brands out there. I admit, I do own several ED products, but I'm not saying they're the best. I've used the older eDead mat (forget which one exactly), the new 120 Mil eDead, the Liquid eDead V3, and the TekLite V4.
The old eDead is no longer being sold, so discussing it is pointless.
I've used eDead 120 mat in my hatch, in the passenger compartment and under my seats. On top of that I used the TekLite to dampen higher frequencies. It did make the cabin quieter as expected, but what really satisfied me was (1) 20% off with coupon code "eDeadBA" (2) choice of thickness/material and (3) that it was so easy to deal with. The new eDead mat is easily cut with scissors and will not gum them up like the previous versions. I just simply cleaned the area with carb cleaner, let it dry, cut the mat, peel, stick and apply pressure.
The TekLite is ten times easier to apply.
If you're worried about deadening peeling off, you might want to look into the liquid deadening. I've used it on my door panels since they where vertical and I was worried of peeling mat as well. No issues here. Just apply thin coats to the roof and what not and you should be fine. You can even lay mat on top of it.
I like the different options for specific applications (ie TekLite for blocking higher frequencies mat/liquid for lower frequencies), the discount, the fact that you can buy the mat per square foot, and ease of use.
Just my .02
» Return to Nissan Audio / Entertainment / Security
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
