I have searched this website and could not find anything related to this.I have a 2003 G35 sedan with 65k miles. In the last two weeks, the steering wheel has started making a squeaking/rubbing noise when being turned.
The noise is coming straight from the middle of the steering wheel. It is from inside the car and happens when turning the wheel in either direction. It's not wheel noise or anything else that has been described on this board. It is also not coming from the steering assembly next to the break pedal. It sounds like two pieces of plastic rubbing together but I've looked and the back of the steering wheel isn't touching anything.
This only occurs after the car has warmed up and been running for about 10 minutes and then it's consistent until the car has been shut off and cooled down for a while. The noise occurs while driving and idling and also happens when turning the wheel in either direction and also while in park. Also, I've raised and lowered the steering column and that has no effect either.
I just had the all the power steering fluid flushed and drained and new power steering fluid added three months ago at 62k miles. I checked today and it has plenty of power steering fluid. It reads right between the max and min lines (hot) in the resevoir. It's 105' in Dallas today.
I think if it were simply two peices of something rubbing together it would happen all the time.
The dealer wants $138 diagnostic fee. I'm inclined to spray some WD40 on it but that's pretty close to the airbag. Also if they do have to work on it, WD40 will make the mechanics life much more difficult. Plus I don't think that's really the problem since the car has to warm up before it starts making the sound.
I would hate to pay the dealer $138 to spray WD40 on it or tell me not to worry about it. The noise is actually pretty annoying. Also, I have a little baby girl and need to make sure the car is safe and the steering isn't going to fail. Hope you guys can help!!
Modified by WaylonJennings at 1:49 PM 8/5/2008
