Old94Max »
https://forums.nicoclub.com/old94max-u102250.html
Mon Aug 04, 2008 12:28 pm
94 Maxima GXE with a S.O.H.C. engine with 221,000 miles. This thing started going through fuel injectors like candy. First the ecm showed a code 51 - fuel injector signal circuit fault. Found the # 5 injector was bad so I replaced it. Drove the car for about 2 weeks and the # 1 injector went out-replaced it. Drove the car again for 2 days & the # 6 injector went out so I replaced all of them. After that the car still ran rough as if it were missing or still had a bad injector but did not throw a code for a day or so. Then the # 3 injector went out again !!! I have checked several different things & replaced the TPS, Coolant TEMP. Switch, Ignition Module & Coil. The car has new plugs, wires, cap, rotor, button, & .PCV. The timing belt has not been replaced but I did inspect it about 20,000 miles / 1 year ago & it looked fine. Is it possible this thing jumped time even though it has cog style pulleys on the cam gears ?? I have started searching to see what makes the injectors pulse to dispense fuel but have found nothing. Could it be the timing belt or my ecm is fried sending incorrect voltage/signals to the injectors. There are no codes at this time and car still runs very rough !!!
