240sx VG30DETT swap help please
Lockleaf
Car: 1990 240sx
I'm working on getting the wiring out of my parts Z right now. I have completely removed the ecu wiring harness. Is there any other parts of the wiring harness I should plan on removing from the vehicle? Or do I just tap into the stock 240 wiring for the relays and fuses and such. Any help would be appreciated, or if someone could point me in the right direction seek that help. Thanks guys.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
That should be all that is needed to get the engine running. There's a chance the Consult harness could be separate so if you want to keep the Consult capability I'd go ahead and pull that out as well (if the 240 doesn't already have it).
Lockleaf
Car: 1990 240sx
Pardon if it's a lame question. What is a consult harness? Is that going to be the harness that does the OBD stuff? There was only one large set of wires connected to the ecu and everything connected to that is what I pulled out. There are 4 connectors on that harness that tied into the body harness of the Z and the fuse boxes. I am going to try to identify them with wiring diagrams and tie them into matching places on the S13 body harness. Any other tid bits of wisdom anyone? thanks guys
mtcookson
1992 Iinfiniti Q45
and much much more
On the driver's side of the Z there is a white plug, basically for diagnostics with Nissan's Consult program. What's nice about keeping it though is you can buy a sort of adapter and get some software that will read the data from the Consult plug giving you a lot of information that the ECU is seeing.
jdefelic
Car: 1993 Nissan D21 Pickup
I have emance's consult software and adaptor. I bought it for my pick up and it isn't the right one. I will check and see if it works on your 300zx ecu. What year is it? If it will work its yours (just pay shipping). I know I will never use it.
John
Lockleaf
Car: 1990 240sx
My Z is a 1990 TT. Thanks for the offer man. I appreciate it.
jdefelic
Looks like it will. It says it has been tested with the 300ZX Z32 VG30DE/TT (Z32 chassis is 1989 and on). Looks like it should work. FYI, I bought it off of ebay, here http://cgi.ebay.com/ebaymotors...32789.
The thing works like it shows. At least the software and cables, lol . My truck doesn't have the DDL connector (it's a 93?). Oh well. Send me a message/email and i will drop it in the mail as soon as i can.
John
Lockleaf
Car: 1990 240sx
Hey John, I got that consult adapter. I just wanted to say thanks for sending me that. Let me know if there is anything I can do for you.
Lockleaf
chuckd502113
whats up man? i dont know how much you have done or what you are willing to spend but my motor went on my 240 was thinking looking into the vg30de i use my car too much for turbo but the guys at z fever said that they would do my harness for $400 alittle steep but they are the only place that said they can do it. just a thought
jdefelic
Lockleaf wrote:Hey John, I got that consult adapter. I just wanted to say thanks for sending me that. Let me know if there is anything I can do for you.
Lockleaf
No problem, glad i could help. Just wondering, how is the swap coming?
importdragon240
Car: 1989 Nissan 240sx
Hey I'm doing the same swap on my 89 240sx next weekend if all goes well. Is there anything you've done or experienced that I need to know about? My roommate and I are putting the motor in. Also I'm thinking of converting to a single turbo. Do all I have to do is change the intake manifold and whatnot to make it a single or should I just stay with the TT? I know it'll probably be a tight fit. Was looking for the DET since it's a little smaller but couldn't find one, so got the DETT instead. Thanks for any info.
Z_LiFe
You dont need to change the intake manifold to make it single turbo. You'll need to have a custom exhaust manifold made for the single turbo setup.
Return to “VG30 / VE30 Forum”
