 Any tips to remove the Alternator on a '92 Q-45?
67fire
1992 Q-45
Reno NV
7-28-2008
Besides removing the radiator and fan, loosen tensioner and remove belt remove alt. bolts.
Then what? How do I "clock" the alt. for the rear "ear" to clear the mount? TIA!!!
Eric
3Q Jay
94Q45a, 97Q45t, 95Q45a, 95altima(daughter's), 94altima (son's)
Huntington Beach, CA
5-8-2004
 « Re: Any tips to remove the Alternator on a '92 Q-45? (67fire)
sounds like you might have searched for an old thread or two. there are several and by reading, digesting, and visualising an approach you will be bettwer off.
key things: remove the a/c compressor (reposition it near the frame rail), removing right tension rod and bracket (to lower radiator support) helps a lot.
HG50(x2)/FGY33/U13(x2)
3Q Jay
5-8-2004
 « Re: Any tips to remove the Alternator on a '92 Q-45? (3Q Jay)
Eric- i see you are new here. please, please tell us you have documented proof of your chain guides being replaced.
67fire
1992 Q-45
Reno NV
7-28-2008
3Q Jay,
Thank you! It would appear that the A/C Compressor, would have to be moved.(Without compromising the Freon, I hoped.) Is it just the two bolts on the bottom and then it slides out? (sort of? After, removing the belt of course.)
Eric
67fire
1992 Q-45
Reno NV
7-28-2008
3Q Jay,
My paperwork states that the motor was replaced with an ATK Rebuild, 10/29/99.
Installed by Sacramento Infiniti. (60,000 miles ago ) I was hoping that the Dealership was aware of the chain guide problem at that time? (I read about the defect, on this site about two years ago.)
I only run Full Synthetic Oil in all of my cars, trucks, Motorcycles (dirt and street.) and even my lawn mower.
I change the filter and add oil as necessary, every 1-2,000 miles. (A little "Anal" about lubrication.)
Change it, every 20,000 or when it finally looks a little dirty (Can no longer see through it on the dip stick.)
What "tension rod", that is , attached, to the radiator support?
Thanks, again!!!
Eric
maxnix
NICO Supporter
1995 Q45, 1995 Q45t, 2000 Q45
Austin TX
7-22-2002
Don't for a New York second think that the dealer replaced the timing chain guides! Call the dealership and verify with the installing technician! Other wise visually confirm.
It is indicated to us that extended OCI seem to degrade the original chain guides faster. 20K is at least 15K too long even for the best synthetic.
Study the FSM and the posts here.
http://www.nicoclub.com/FSM/Q45/
Brian
1995 Q45 & Q45t & 2000 Q45
67fire
1992 Q-45
Reno NV
7-28-2008
 « Re: Any tips to remove the Alternator on a '92 Q-45? (maxnix)
Well, I must applaud this site and the many visitors that have given some EXCELLENT ADVICE!!!!
Yes, I did have to remove the two bars between the pass. side lower control arm and the radiator support. As well as the tensioner for the alternator. What a P.I.A. for a "Simple " Alternator replacement!!!! (the alternator was working fine, bearings were starting to make noise.)
I did find a thread from 6/30/05 posted by GreenQ45a (not, with the help of the search mode.) I just started reading every post that mentioned alternator or A/C Compressor.
This site is very difficult to comb through (with all of the different possible locations to find an answer) yet, I managed to find the info anyway.
Much thanks to ALL that did in fact help me!!!!
Eric
Q451990
Old School Q Guru
1990 Q45 - 91K, 2005 G35 Sedan - 32K, 1997 Nissan Truck - 133K
Columbia, SC
7-23-2002
Quote, originally posted by 67fire »
I only run Full Synthetic Oil ... even my lawn mower.
Wow... someone more nutty about mechanical things than I am!
Glad you got your alternator changed out... it is a pain for sure...
Heath
1990 Infiniti Q45 - AKA "Q2"
2005 Infiniti G35 - Sedan A/T FOR SALE
1997 Nissan Truck - XE - 5 Speed M/T
67fire
1992 Q-45
Reno NV
7-28-2008
 « Re: Any tips to remove the Alternator on a '92 Q-45? (Q451990)
Nothing "Nutty" about taking the best possible care of your "Junk".
I have never had an oil related problem since 1976 (the first year that I started using Synthetics exclusively.)
Motors, Transmissions and rear-ends as well as wheel bearings and U-Joints/Ball joints/Tie rods.
Nice to find a bunch of people that "Have a Clue!"
Hard Core American Iron. But if it must be Foreign, it should be a technological marvel and lot's of H.P. with decent mileage for the fun involved.
Once you remove the Resonator/Muffler on the Q-45, It sounds like a lambo or a Ferrari.
I just added 2.25 duals to replace the restriction in the exhaust. (Have yet to try a mix of 100 UL Race Fuel) It still enjoys shifting at 7,000 RPM in all gears with no transmission modifications. (Extra cooler, is in the plan.) Third gear, goes to 135 indicated. (Check location, Nevada.)
235/60-15's on the Front and 255/60-15's on the rear. (Firestone Indy "Something" HR Rated.)
It GOES!!!
Next, must add that 20mm rear sway bar and all will be RIGHT!
Eric
P.S. My '97 SC Saleen 281 4V Cobra, has a bit more GO!!! (550H.P. W/ 10.5 lbs. of Boost.)
Modified by 67fire at 12:20 AM 7/30/2008
Modified by 67fire at 12:21 AM 7/30/2008
67fire
1992 Q-45
Reno NV
7-28-2008
I forgot to add that I currently run the Diesel spec. Synthetic oil, More Zinc for friction modifiers.
5W-40. 15W50 Auto Syn. in the summer time. (With one quart of Valvoline 60W Race Dino Oil. (Highest in zinc content PPM.)
Eric
maxnix
NICO Supporter
Austin TX
7-22-2002
Yes, the moderators did something rather stupid and moved all the archived content to current, so lonly archived seraches by poster's name are available, not good for the newbie. There are 3 Forums to search, this one, Q45 and for the really good old stuff, Infiniti General.
There is a tutorial stuck in the Q45 forum that is good for how search once worked.
Modified by maxnix at 7:26 AM 7/30/2008
maxnix
NICO Supporter
Austin TX
7-22-2002
I just added 2.25 duals to replace the restriction in the exhaust......(Extra cooler, is in the plan.) Third gear, goes to 135 indicated. (Check location, Nevada.) 235/60-15's on the Front and 255/60-15's on the rear. (Firestone Indy "Something" HR Rated.)
Actually, if you measeured before and after performance, you would find at most 2% improvement open vs. OEM exhaust. Nissan did their homework on intake and exhaust, much more than big 3.
20mm rear bar is good, but suspension rubber and shocks are also critical.
HR in the summer are no way safe over 130 in the summer, and only when new and unpatched. While the V rated SZ50EP was a great tire, Firestone is the second level brand for Bridgestone.
Presume the timing chain guides and tensioners are new?
» Return to Infiniti Online Mechanic
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
