1st Gen Fan Swap-Info Inside
A general discussion forum for G35 and G37 owners and a great place to introduce yourself to the NICOclub G-Series Forums!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Sean, Joe,
I'm starting the thread here, if you need to move it, that's cool.
Ok, there's been a lot of talk about swapping the belt driven fan on the 03/04 Sedans to an electrical one.
Here are some facts that Tony at Riverside Infiniti was able to drum up for us.
-If your 5 speed Automatic Sedan has a build date between 08/02 and 10/03, you have the belt driven/clutch style fan.
-The 6mt Sedans have the electric fan
-Both the 6mt and 5at have the same radiator
-The fan and shroud are different between to two systems
I spoke to Tony about a GB or discount and he was able to work something out for us. Email me about the discount, because I don't want to get him in trouble.
From the preliminary research, it looks like there isn't a relay in the engine fuse box, so some sort of custom electrical harness will have to be fabbed. If I get a chance, I'll check out the FSM to see if the electrical diagram gives any answers.
4drmadness
Car: 04 g35 infiniti sedan
My cars mfg date is 03/04. where does that fall in
Sentientbydesign
96 I30 - Sold
That should be March of 04 meaning you have the electric fan.
It's actually pretty easy to verify visually.
Just pop your hood and look at the fan(s) between the radiator and engine.
If the fan is attached to the engine with a belt turning it (or possibly not turning it depending on how hot it is), you have the mechanical fan that robs HP.
If you see the fans sitting in their own little shroud with small electrical motors, then you have the electrical fans and don't need to convert anything.
G_whizz
Car: 2010 G37 Coupe Sport
No worries Nate. It can stay.
joe603
Car: 2014 Durango R/T
I may add a link to the G-series FAQ page if the thread proves worthwhile.
Thanks for the heads up!
Sentientbydesign
96 I30 - Sold
Hey Sean, Joe...Check out the OP date hehehe
G_whizz
WTF?? How did I miss this??
Sentientbydesign
96 I30 - Sold
Not sure. It was one of my projects. Nobody really did much with it, so I didn't persue additional info.
G_whizz
So how did it end up here all of a sudden at the top of the forum??
Sentientbydesign
96 I30 - Sold
I linked to it in another thread and 4drmadness replied to it.
TeflonG35
Car: 2003 G35 Sedan
The fuses on our cars were pissing me off. So I did the sure fire way of just hooking the fan to a switch with 2 fuses. Both 15 fuses. Have to keep it safe.
I don't have pics of my fuses but I do have a pic of my 14 mishimoto fan.
Here is how I mounted my switch.
The switch looks better in person. Looks pretty stock.
Sentientbydesign
96 I30 - Sold
I know you like your way, but it seems that the rest of the guys want to make theirs turn on and off automatically like it's "supposed to" be.
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
1+ for automatic power relays or whatever, thanks for this post, the fools at the Infiniti shop here couldn't seem to give me this much info... lol
I would be interested in getting one, if we can arrange a GB, I'm in!!!
srv2nv
I actually did a lot of research on this a month or so ago as I wanted to do it at the same time as my pulley upgrade. Unfortuantely from what I've learned the stock electrical fan for the 350z/g35 won't work as the relays and hook ups aren't the same and the amount of work required to hook them up properly along with the cost is too much.
Theres a guy on another site that came up with a pretty good system (with 3-4 variants on connections...ECU...AC...etc) that incorporates an aftermarket fan along with some other parts from the same company that basically creates the same thing as a stock electrical fan (what you're looking for I believe). A quick search on google can help you find the thread that he started with his information on contacting him to find out the actual schematics of the whole install.
Honestly though, theres little proof of any real hp gains, and for the price of the parts plus the time required for the install (hope you understand all the electrician mumbo jumbo also) its really not worth it unless you have someone experienced in doing the conversion to help you for the day.
Sentientbydesign
96 I30 - Sold
I personally disagree regarding the worth issue.
I don't have the pulley fan and I don't make any kits for it either, but I can see a definite benefit due to the parasitic loss inherent with crank driven accessories.
I personally don't like systems whose efficiency is directly related to how fast my engine is running. If I could make my A/C run efficiently independent of the crank, I would. Hearing it spool in the summer heat when I decided to floor my throttle isn't a wonderful sound and the power loss is sad.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Any accesory that is being run by the engine is robbing you of horse power.
The electric fan conversion is an old school mod that has been done by drag racers for a while...reason being that it frees the engine to do what it was made to do.
BrandAidDesignG35
Now, that we've cleared up this misunderstanding, are there any kits in the works for our cars? If not, why?
Sentientbydesign
96 I30 - Sold
Because I don't want to make one hahahahah
Sentientbydesign
96 I30 - Sold
Ok. This should be pretty simple to make.
Anybody in SoCal with the belt driven fan want to do this?
Your money, my expertise lol
If something comes of it, I can do an article on it and also offer a "kit".
Return to “G35 and G37 General Discussions”
