 steering angle mod?
neverlift
brain fart
PIGNOSE #19 turbo piggy
sunshinestate
4-24-2006
  steering angle mod?
ok what have others done to prevent the "locking" at full lock? I've heard a couple things and am uncertain.
The main thing I get is put something on the stopper so the hub doesnt bottom out and stick, makes good sense to me. HOWEVER wouldnt that kinda defeat the purpose of the mod?
I didnt think it would be a problem, then come to find out it changed everything
PIGNOSE SQUAD MEMBER # 19
r.i.p. Lee
09/01/89~09/28/06
Slappy
1993 240 sx coupe
DriftingInsider.com
12-27-2004
 « Re: steering angle mod? (neverlift)
Theres a triangle bar that Brian from MA Motorsports welded and it prevents that binding your talking about. Send him an email...
http://www.mamsparts.com/down_...fb05a
Slide Asylum
neverlift
brain fart
sunshinestate
4-24-2006
 « Re: steering angle mod? (Slappy)
hey man that site has been " down for maint." since 07
so give me an idea of what you talking about..???
thinking of removing one of the two per side and seeing if that helps the bind issue.
Slappy
1993 240 sx coupe
DriftingInsider.com
12-27-2004
Its hard to explain. Catch him on aim at JDM Fresh
sdtouge
1990 240sx coupe
san diego ca
7-5-2004
its f difficult to explain because you dont know what youre talking about
a triangle bar whatever that is wont stop the binding
the only way to stop the binding is to either move the steering rack, or change the pick up point for the tie rod on the knuckle. thats what brian has, thats what i have too.
these are the ones i have, thats my green car. they rock, you should get them. sooo much angle and it doesnt lock anymore. if it does lock, you can switch to the second hole or add plates that the kit comes with to remove a little bit of angle and keep it from locking.
http://www.gtfactory.jp/cms/page.php?15
MastaYu
Online
92 240SX HB SE
MD
10-3-2007
 « Re: steering angle mod? (sdtouge)
^ those look really beefy!
Shift_up
My S13 Ressurection/Rebuild
Joe
Tucson, AZ
2-9-2003
 « Re: steering angle mod? (MastaYu)
i sent my knuckles/LCA's out for those last week. they should be here tomorrow/tuesday.
i cant wait.
-Joe
1997 240sx SE - LS1
2005 Nissan Titan SE - Tow Vehicle/Daily driver
eDmSiL80
sil80
Elwood NJ
12-2-2005
 « Re: steering angle mod? (Joe)
yeh i always knew about spindles and wanted to try em out. i have to get use to my car first in order to get to that level.
^ those look amazing sick, i know ppl diy most of the time, i think brian of ma motorsports is in the works of mass producing these. but now that i saw those i am most likely gonna get those. leme know how they feel and everything. i no the west coast guys are lovin it.
my question is will those tie rods hit when u get full lock or does it have a little play before hand? i see it has a plate to where itll hit. i had that problem before when i had peak pro inner/outer and it would smack my lca like nuts.
http://www.pride-performance.com
sdtouge
1990 240sx coupe
san diego ca
7-5-2004
 « Re: steering angle mod? (eDmSiL80)
they are amazing. steering is faster too. feels wierd at first, but then its soooo sick for initiation, you can throw the car super hard this way. also its a **** load of angle. i hardly spin and ive only hit the bump stop a few times. its awesome.
do it!
joe, i know martin from psm has been cranking those things out, so im sure yours will be back soon. id do the first hole at first, and see if its binding still, then if it is go to the second. im just switching to the second now. hope its coo!
Joe
Tucson, AZ
2-9-2003
im going from a 100% bone stock system to these, peak pro inners, and a 10mm spacer on top of it.
i might be happy with the "low" hole on the knuckles haha
eDmSiL80
sil80
Elwood NJ
12-2-2005
do the s13 knuckles have to be cut? or can just be welded up with that U shaped piece like on the s14 knuckles...
sdtouge
1990 240sx coupe
san diego ca
7-5-2004
joe, i was at part shop max today and i saw your knuckles. they were being painted and will be shipped out tomorrow. the knuckles take a while to do since they mod the lower control arm too. holla!
no, s13 knuckles receive the same treatment as s14 ones.
Joe
Tucson, AZ
2-9-2003
awesome. i hope they ship today lol i have an event on saturday haha
neverlift
brain fart
sunshinestate
4-24-2006
Quote, originally posted by sdtouge »
thank you sir!!!!!!1
also I found another much cheaper option, 16" steering wheel ftw
15 would probably cut it, whatever the stock steering wheel is didnt have enough leverage... I'm good now
Slappy
1993 240 sx coupe
DriftingInsider.com
12-27-2004
No need to be a Dick , Dick , you could've been decent and said something like "I dont think thats right slappy" , but no , you had to be a typical car forum cock......and what i mentioned does help , because i was just at MA last week.
Schuey7 time: exlpain to me one more time what that support weld does on the FLCA that you were showing me the other day
JDM Fresh: it braces the oem tie rod stop on the arm so it doesnt bend
Schuey7 time: does that help with binding or no?
JDM Fresh: yes in that if you have one bent stop that it will bind, so you make sure they are straight up and down, then weld brace on there then they are good
JDM Fresh: yeah
JDM Fresh: like
JDM Fresh: if one stop is bent on one of your FLCAs it will bind , cause it will go over center , reason you need to center your rack
JDM Fresh: make sure its equal or damn close to equal amount of turns form full lock left to full lock right
BOT
Brian from MA Motorsports is doing that mod as well.
http://forums.driftinginsider....=1328
Modified by Slappy at 2:04 AM 8/26/2008
neverlift
brain fart
sunshinestate
4-24-2006
FFS grow the teh eff bomb!!!1!!!eleven!! up guys, its teh webnetz, slappy you have been rude to plenty of people on here including myself, hint if you cant take it dont dish it....
now stop the bs in me thread
now this centering of the rack, thats when you measure the amount of shaft on both sides trying to make them as equal as possible?
» Return to Nissan Drift Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
