 lsd (again)
sonsters
06 blue 350z...
Lake Charles LA
2-27-2008
  lsd (again)
ok so im needing an LSD is this a good one? if not LMK which is... thank you!!
http://www.z1motorsports.com/3...=2397
Beancooker
Spoolin' Past You
'09 Failwagon
Rain City WA
6-26-2006
 « Re: lsd (sonsters)
Get the Nismo LSD. It's only $773 from Tacoma Nissan.
http://www.nismoparts.com/catalog/?section=382 It's about 1/2 way down that page.
I priced one out for installation through Nissan, and it was $390. to install.
It's adjustable in 60, 80 or 100% ratios, and will be a little more friendly as a daily driver.
Quote, originally posted by WDRacing »
you Star Bucks drinking cock pirate...
Go tax something...
sonsters
06 blue 350z...
Lake Charles LA
2-27-2008
 « Re: lsd (Beancooker)
ah sweet man thnx dude!!!
sonsters
06 blue 350z...
Lake Charles LA
2-27-2008
and thats all ill have to buy to convert my base model to the lsd?
Beancooker
Spoolin' Past You
'09 Failwagon
Rain City WA
6-26-2006
No problem. I was planning on getting that, until I found out that I did have the preformance wheel and tire package, which also included a VLSD. Would rather have a clutch style, but VLSD isn't bad for free.
Dasoupdude
TIE FIGHTER, 5,289 hp 350z
Palm Beach Flawda
3-17-2008
I'm looking into get one of these too, seeing as that I have a base, i hate open diffs.
I'll just go weld them spiders and save me the money. (yeah right)
bullsh*t free zone.
Quote, originally posted by Tulsa_S-13 »
I'm too lazy to read this thread, however, I do live with a ****sexual.
Nissansportmag forums:
http://forums.nissansportmag.com/zeromain
sonsters
06 blue 350z...
Lake Charles LA
2-27-2008
 « Re: lsd (Dasoupdude)
ok so whats clutch style mean? like it disengages when the clutch is pushed in?
Slider4105
2008 G35 Journey 5AT
West Palm Beach FL
3-17-2008
The clutch type LSD responds to driveshaft torque. The more driveshaft input torque present, the harder the clutches are pressed together, and thus the more closely the drive wheels are coupled to each other. With no / little input torque (trailing throttle / gearbox in neutral / main clutch depressed) the drive wheels are still coupled somewhat as the clutches are always in contact to some degree, producing friction. The amount of preload (hence static coupling) on the clutches is determined by the general condition (wear) of the clutches and by how tightly they are shimmed.
The viscous type is generally simpler, and relies on the properties of a dilatant fluid - that is, one which thickens when subjected to shear stress. Silicone-based oils are often used. Here, a cylindrical chamber of fluid filled with a stack of perforated discs rotates with the normal motion of the output shafts. The inside surface of the chamber is coupled to one of the driveshafts, and the outside coupled to the differential carrier. Half of the discs are connected to the inner, the other half to the outer, alternating inner/outer in the stack. Differential motion forces the interleaved discs to move through the fluid against each other. The greater the relative speed of the discs, the more resistance the fluid will put up to oppose this motion. In contrast to the mechanical type, the limiting action is much softer and more proportional to the slip, and so is easier to cope with for the average driver.
wikipedia ftw
Quote, originally posted by charlieo »
The only thing you've shown close to cutoff is that it's what your dad should have done mid-coitus.
08 Blue Slate on Stone G35 Journey 5AT w/ Sunroof
35% front 15% rear tint - Landing Strip - Smoked Tails - White LED Interior & License Plate Lights
evildky
Classic Z Moderator
71 240ZT, 87 300ZXT, 91 300ZXTT, 93 SE-R
Louisville KY
1-31-2004
I'd take the quaiffe over the Nismo in a heartbeat, and cliffnotes, cluthc type holds the drive wheels together till the brakeaway torque is achieved, viscous slips first it's the slip that engages the the lsd
"if I had all the money I ever spent on cars........I'd spend it all on cars"
"The Rusty Mistress" 299.3 whp and 305 lbft TQ, 2105 lbs, new engine on the stand, will it make 400whp?
Z31: 315 whp 416 lbft,now with higher compression, about to get returned to near stock
Z32: now with sport 500's!, waiting for some finish painting
sonsters
06 blue 350z...
Lake Charles LA
2-27-2008
 « Re: (evildky)
why quaiffe?
Dasoupdude
Palm Beach Flawda
3-17-2008
 « Re: (sonsters)
It acts normal under normal conditions, until you really start pushing the limits.
Beancooker
Spoolin' Past You
'09 Failwagon
Rain City WA
6-26-2006
 « Re: (Dasoupdude)
I am at work right now, but have a great article on LSD's on the PC at home. I'll post it up when get home tonight.
evildky
Classic Z Moderator
Louisville KY
1-31-2004
quaiffe has been the dominant LSD in motorsports for years, they are tunable and rebuildable, and I'd be willing to waer quaiffe rebuild kitss are cheaper and easier to get ahold of than the Nismo pieces which as far as I know are still sold as individual friction disks and shims, Nissan has a history of running short on R200's and parts
» Return to 350Z / 370Z Forum
Car Finance Advice Nissan Infiniti News Archive
240sx technical information Nissan technical information
Infiniti technical information Nissan Infiniti Car Owners Homepage
Advertisers Marketplace
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
