sr hotpipe and intake on a KA-T
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
if i run a bottom mount t25 can i use a hotpipe and intake made for an sr? i assume yes because i have read that it puts the turbo in the same location but i just wanna check first. thanks in advance!
DevilMB3017
With some couplers and clamps and a willingness to cut up the pipes if you need to, it's cake.
Most bottom-mount T2 manifolds try to put the turbo near where the SR piping works from what I've seen, but I have no first hand experience with this.
I use the same cold pipe on my KA-T as the SR20 from FMIC to throttle body, it just requires a coupler.
240sxvaj
1994 MKIV TT-Daily/Track
YES it works. i have sr hks hotpipe/ssqv combo and bolts right into my sr greddy type-m FMIC. didnt need hump hose couplers but recommend it, some ebay sr FMIC might be a little off so hump hose will save you on that. And if you use the sr FMIC you would need a longer coupler for the coldpipe to throttle body.
Tyler
cool thanks a lot, does anyone know if an intake kit made for the sr will bolt up? i wanna use the hks shroom style
DevilMB3017
TJG wrote:cool thanks a lot, does anyone know if an intake kit made for the sr will bolt up? i wanna use the hks shroom style
Personally, I just bolted the filter right onto the MAF.
Tyler
i thought that messed up the reading or soemthing? and did it bolt dicrectly on or did you need an adapter?
92KA-T
Car: 96 240sx
92 240sx hatch -sold
DevilMB3017 wrote:With some couplers and clamps and a willingness to cut up the pipes if you need to, it's cake.
same here i used a buddies 1 peace SR cold pipe and it fit right up to the TB with no issues... now the Ebay kit didnt really do much for me.. cold side i didnt use cuz we had a 1 peace i could use... hot side only peace i used (didnt have to cut) was the 90 that came right off of the intercooler.. rest we had laying arround and had to make it ourselves.. when we fit the ebay kit to the car it didnt even come close to the turbo..
DevilMB3017
I think you're thinking about the distance of the MAF from the turbo. It should be 14-18 inches away. I need to do this...it does cause problems IMO.
As for it bolting on, it depends on what filter you buy and what MAF you're running. Just buy the right one and it should bolt up.
Tyler
okay cool, thanks alot
esahuque
Car: 95 240sx KA-T, 04 frontier
yes it will all work. my friend has a gti-r t28 setup on his ka-t. sr intercoller kit w/stock sr intake tube.
my catchy user name
Car: Chucki fastback.
2 45 degree's will also work.
bruinbear714
TJG wrote:if i run a bottom mount t25 can i use a hotpipe and intake made for an sr? i assume yes because i have read that it puts the turbo in the same location but i just wanna check first. thanks in advance!
Yes. If you use a T25 it'll bolt right up if you use those bottom mount KA T25 manifolds that are sold everywhere.
If you use a T28, your options are the t28 reclocking adapters or the greddy suction kit if you have z32 maf
