Yellow4g63 wrote:Take the harness out of the car. Then put into a box with some good money and ship it to CarlH. He "might" be able to help you out.
I second that,that harness is totally butchered.
The lower harness stuff ie: Wires to alternator,starter,transmission,oil pressure switch etc you leave pretty much stock with the exception of swapping over a couple rb plugs to the ka harness like the oil pressure and the starter sinal wire.Ream the ringed terminals holes larger so the fit on the rb compnents.And transmission stuff just swap over the ka speed sensor and I can't remember if the rb reverse switch is the same or not I do think it is,my trans had this broke off to begin with.
Then all the EFI stuff like said take it out of the car and send it to Carl it will cost a couple bucks but it will work.
