1999 Nissan Pathfinder Rear Jack Point?
JohoTehAzn
Hello,
I have a 1999 Nissan Pathfinder. I can't seem to figure out where the rear jack point is from the owner's manual. Could I receive some assistance regarding this?
The manual states that it is on the "rear of stabilizer bracket on rear axle case", but I cannot locate it visually.
Thanks!
fueler
Car: 2 Nissan's
2 BMW's
Well if you have an aftermarket floor jack, ive found that the easiest is just jacking up the pumpkin of the rear axle and jackstands on each end of the axle But if u are using the stock jack, im pretty sure its on the rear axle where the struts are connected, theres a special adapter piece for the stock jack u use in the rear and not in the front (or is it the other way around?)
Metallica98
Car: 1998 Nissan Pathfinder
yeah i always do what fueler said, it's the easiest and safest way
